Question about Euro-Pro Shark 9110 Sewing Machine
What is wrong with the mach if it misses the stitch on the bottom, it doesn't catch the tread? It doesn't make a clunking sound but doesn't sew.
  • Euro-Pro Master
  • 1,133 Answers
Could be the needle is in backwards, not pushed all the way up into its housing or blunt. Try changing it first, rethreading machine top and bottom and try again.
If that fails and it is not forming a stitch at all, then the timing could be out and will need servicing.
Posted on Mar 27, 2011
My singer curvey 8763 is making clunking noise when start sewing and then stop working
possibly out of time with the bobbin . take in to a shop for checkup
Feb 05, 2015 | Singer Sewing Machines
Why is the bobbin thread being cut on bobbin after a few stiches? machine will sew a few stiches and this happens.
your bobbin is place in the wrong position and you need to tighten the stitch....adjust it a bit.....play with it till you get the desire result
Sep 11, 2014 | Singer Sewing Machines
The chain stitch on my Viking Huskylock S25 does not work
Check your tension settings clean out the track all the way down starting with top it sometime sticks at the top then doesn't feed also a net over your tread will give you more tension as well.
Clean little metal track, I use a small pipe cleaner .Dollar tree has them now
This also it depends on what your sewing You have to play with it a bit on the scrap fabric I noticed as mine got older my self adjusting tension did not so self adjust You move it slightly up and down from zero just barley moving and then trying it out.
I could almost bet though its 1. needles needs to be changed out or 2. threaded incorrectly What I did is I looked my book up on line and compared it you can make your view as large as you want . That's how I found out I was missing one step in treading which made bottom loops bad.
Also I was setting up in wrong order which is most important. It says 1 2 3 4 you feed it just like that in that Number 1 all the way Then 2 all the way and so forth order.
when I did all that Mine now works perfect. Good luck and God Bless
Scarlett
Apr 10, 2014 | Sewing Machines
Thread wont loop, it doesn't sew?
It loops, it's just that your shuttle isn't catching the loop. The loop is formed on the upstroke of the needle on the back or "scarfed" side of the needle. If the shuttle point doesn't catch that loop, no stitch.
First make sure you have a fresh needle. If still no stitch... take it in for service. (clean, lube and time)
Oct 03, 2012 | Brother SE-270D Computerized Sewing...
My singer 2010 sewing machine will not stitch. it has a cruchy noise when turning the wheel :( The bobbin wont catch with the needle under as well :( is it me doing something wrong or the machine?
Sounds like it could be a broken bottom or top gear, you would need to take the bottom and top off to check but don't touch any electronic parts
Aug 24, 2011 | Sewing Machines
I change the presser, for a walking foot, and the nedlee started to stucked, and then I change for the presser again and now doesn't sew at all, now only sew a few stitches and then the tread loses both...
This sounds like you have one of two things going on:
1. the tension, probably upper, is too tight or the thread is looping or catching along the way somewhere...ie threading isn't right
and
2. the needle is bent.
Try rethreading and check the tensions and then also make sure and try a different new needle. Make sure the stitch type is set right for the presser foot too! :)
May 04, 2011 | Brother Sewing Machines
Treading sewing machine
these are the best setting i have found for sewing through thick materials, specifically leather and vinyl:
top tension- between 8 and 9 bottom tension- between 4 and 5 stitch length between 3 and 4 stitch type: 2
that is just what works best for me, i have a brother xl-2600i
Jun 23, 2009 | Brother XL-2600
Sewing maching making randon loops bottom stitching
Sounds like you are getting some skipped stitches. Have you tried changing your needle? You may want to make sure you are using a ball point, those help alot with skipped stitches.
Dec 15, 2008 | Kenmore 15516 Mechanical Sewing Machine
Brother Sewing Machine model:CS8150 bobbin thread problems
The top of the machine is not threaded correctly. First raise the presserfot then rethread the machine. Bottom looping is usually caused by a lack of top tension. There could allso be a bur on the hook.
Feb 22, 2008 | Brother CS-8150 Computerized Sewing...
Euro-Pro Shark 9110 Sewing Machine Logo
94 people viewed this question
Top Euro-Pro Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you an Euro-Pro Sewing Machine Expert? Answer questions, earn points and help others
