Question about Brother MFC 490cw Color Inkjet Multi-Function Printer
My mcf490-cw brother printer has been printing wirelessly for years. Now, out of nowhere, it indicates it is off line and neither of my wireless computers can find it on the network. On the computer, it indicates that the printer is off-line. How do I get it back on-line?
    Guru:
  • 89 Answers
Connect it to wireless network again
possible reason could be it goes offline because it looses connection to your network/router
reconnecting it again same way during the first time can resolve the issue
also check the printer if it has sleep mode/power saving mode options then turn it off
you can refer to call brother support or checking their website.it could be really helpful for you
I hope I help you even a bit
Posted on Mar 27, 2011
My brother mfc 665-cw is saying offline no matter what I do to try to print wirelessly
Go to system settings and select the 'Printer' option.
Right-click on the printer and enable the 'Use Printer Online' function.
Cancel all the printing jobs till that moment and redo the process.
Sometimes the 'Printer Offline' message occurs due to a 'Job Stuck' issue.
Check all network connections and functions.
Be sure the network interfaces work properly.
Turn the printer off and on to see whether the device is working properly.
Apr 25, 2011 | Brother MFC-665CW All-In-One InkJet...
How to use brother mfc 495 cw wireless to my computer do not have manual
i am trying to install the printer software and it is saying it needs to be configured to the wireless router, HOW DO I CONFIGURE IT TO THE ROUTER? I HAVE A BROTHERS MFC495-CW WIRELESS PRINTER.
Apr 23, 2010 | Brother MFC 420CN All-In-One InkJet...
How do i scan? using a brother MFC 685-cw..can't seem to use the scanner.. anyone help?
I have a Brother MFC 7840W and have struggled with the wireless features. Not sure how you have this configured but if wireless suggest you find a way to connect via LAN or USB...I cannot make mine work via wireless but hardwired works fine. To fix, I had to 'reset' the MFC (functions on the MFC itself) and then reinstall the software selecting USB as the connection method. Sounds crazy but once I did it worked.
Apr 18, 2010 | Brother MFC-685cw InkJet Printer
Will no longer print via wireless network and indicates that it cannot find the printer
I just had this issue yesterday.
Step 1. Turn off your Brother
Step 2. Turn off your Wireless DSL/Router
Step 3. Turn on the Wireless DSL/Router
Step 4. Turn on your Brother Printer
Apr 06, 2010 | Brother MFC 7840W Printer
My MFC 685 CW will not print.
Hello ,
First, we will have to make sure the printer is properly connected to the network
  1. Go to your printer.
  2. Press “menu” and scroll down to network, then WLAN
  3. Go to TCP/IP
  4. Go to IP address. Make sure there is an IP address here (not 000.000.000.000). Change the last 3 digits to “050”
  5. Change the boot method to “static”
If your IP address is not a valid one (all zeroes) or is an APIPA address (starting with 169.254.#.#) you will need to run the wireless setup wizard again as the machine is not properly connected wireless
If you had a valid IP address before changing anything, it means that the printer offline is caused by the computer not being able to locate the printer.
This is usually caused by the printers IP address changing.
Changing the boot method to static will make sure the IP address on the printer does not change.
Now we will have to make sure the computer knows where to find the printer.
On your computer, go to your start menuè control panelè printer
Here you should see your brother printer. Right click on the printer and select “properties” (If you are running windows Vista, make sure select “run as administrator” and then properties)
Go to the “ports” tab
Select “add Port…” and then double click on “standard tcp/ip port”.
This will bring you to the add port wizard, click next.
In the field for “Printer name or IP address” enter in the new IP address of your printer and then press next and finally “finished”.
Make sure to apply the changes.
You should now be able to print.
Thank you,
Mar 28, 2010 | Brother MFC-685cw InkJet Printer
I have the MFC-490CW, I am trying to install it to be wireless. But I can't figure out some of the items. How do I find the WEP key?
My brother MFC490-CW is connected wirelessly to the router. It printed OK wirelessly yesterday when I set it up but today it will not print. The printer has a strong wireless connection to the router. My PC also has a strong connection to the router. But the printer seems to have lost the connection to my PC. How to I re-establish the wireless connection from the printer to my PC?
Nov 03, 2009 | Brother MFC 490cw Color Inkjet...
Offline wireless printer
Please make sure that printer is turn on, before doing ensure you do power cycle of printer.
Add printer on Standard TCP/IP port.
Sep 13, 2009 | Brother MFC 490cw Color Inkjet...
Networking a Printer on a wireless network
Deanna, if the mfc is not that old, take it back to the dealer and ask for changing it to a wireless printer (extension: CW). Do you really need the fax function? If not, try this printer: DCP 750CW. If yes, get the MFC 845 CW. The CN printer have to be connected directly to router or pc/laptop.
Sep 27, 2007 | Brother MultiFunction Center MFC-440CN...
Brother MFC 490cw Color Inkjet Multi-Function Printer Logo
533 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
