Question about Dishwashers
Dishwasher stopped midcycle. Panel not lighted,nor start button. No fuse has tripped and other appliances in the area work fine. What is the problem?
    Problem Solver:
  • 17 Answers
Brand of dishwasher???? Under warranty ???? LG appliances have serious problems with motors. Stay away from LG appliances.
Louie Almond
Posted on Mar 27, 2011
My Bosch SHU66C02UC dishwasher stopped midcycle with water in the bottom. We checked the fuse and it is fine. I'd rather not pay for a repairman as it is quite expensive.Thank you.
Some suggestions: try pushing the drain/cancel buttons and see if that drains the water; check the filter or trap in the bottom of the dishwasher for blockage; check the hose that links the dishwasher to the under-sink drain pipe for blockage. You could google the model number and find the owners manual, which might have trouble shooting suggestions.
Sep 05, 2017 | Bosch Dishwashers
Dead Washing machine
seems issue with the control panel. try unpluge the unit and pluge back after 10 min and chk.
Aug 12, 2008 | Washing Machines
My Kenmore dishwasher 16023 stopped working yesterday. I'm not sure if it stopped working midcycle, because the dishes were not clean when I I took them out and there some water pooled at the bottom....
Firstly be very careful working with electricity.
Try plugging a lamp or similar into the outlet to see if it has power.
If it does sounds like it then has internal problems.
Most older appliances cost more to repair than they are worth. I suggest time to upgrade.
Nov 02, 2017 | Kenmore 24 in. 16023 Built-in Dishwasher
Dishwasher stopped midcycle and the fuse is not tripped
Some dishwashers work the wire nuts loose in the connection box. Especially those that
are wired to aluminum wiring (these require the purple "IDEAL" brand wire nuts).
Make sure to secure power to unit before servicing.
Mar 06, 2011 | Whirlpool Gold GU2475XTV Builtin...
Control panel will not light up, the dishwasher was running and now it has stopped mid cycle and will not do anything. I just replaced the control panel (black plastic with buttons, not control...
I have a kitchenaid dishwasher model # KUDC10FXBL1 I went to start it and none of the buttons were working. I have checked the breaker and the wiring and everything seems to be in order.
Jan 13, 2011 | KitchenAid 34 in. KUDP01FLSS Stainless...
No Power, No Lights on MDB7100AWQ
HI, there are four problem spots that i recommend checking. these are the most common hot spots for a non responsive dishwasher. Check each area thoroughly to address this issue.
1. No power to the dishwasher
Make sure there's power getting to the dishwasher. Check for a tripped circuit breaker or a blown fuse. Check the wall socket for power. Sometimes the power cord disconnects at the dishwasher (inside the junction box, behind the bottom kick panel), if this is the case, the wiring must be repaired or replaced.
2. Door switch
Replace if defective.
3. Timer
Replace if defective (note: uncommon problem).
4. Selector switch
Jul 13, 2009 | Maytag MDB7100AWB Dishwasher
Whirlpool dishwasher stops midcycle and control panel goes blank
and the controls dont advance? to the end of cycle?
Feb 26, 2009 | Dishwashers
No power to dishwasher - no lights, etc.
check ,,fuse on control board..onthejob
Feb 18, 2009 | Dishwashers
Kenmore dryer stopped working, start button does nothing
hi thanks for the question i would check the thermal fuse at the back remove back panel . by the air duct theres a small thermal fuse with 2 smaller blue wires to it check that it does cause this thanks appliance doc
Sep 13, 2008 | Maytag PYE2300AY Electric Dryer
Dw stopped in midcycle.
There is a thermal fuse located on the electronic control board housing that may have failed.This replaceable part (gray or white) is clipped on to the side of the housing.
May 31, 2008 | Kenmore 24 in. 17032 Built-in Dishwasher
Dishwashers Logo
141 people viewed this question
Top Dishwashers Experts
