How can I remove water based paint from lcd monitor?
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 177 Answers
To remove water based paint simple, using cleaner based water to or using a damp cloth, wipe the plans. do not stress on the surface of the LCD. swab of the outside area where the circle pattern. lcd tv is better placed facing upwards, with the LCD panel on top. Good luck.
Posted on Mar 27, 2011
Used filler for filling nail heads rubbed back next day perfect two weeks later painted wattyl undercoat water base and filler went soft
The wood filler, a water based product, pulled the water out of the latex paint and softened. To preclude this in the future, you can cover these repairs with shellac or another sealant to provide a barrier between the filler and the paint. Spray shellac is available in hardware stores, and is used on water stained ceilings before repainting.
May 20, 2015 | Timbermate Wood Filler Water Based 8-oz...
Can I paint over this with a water based paint
Don't use a water-based paint for any purpose on a motor vehicle.
It can damage the finish of existing paint, and will NOT stick to the original paint. If this is just a stop-gap measure to cover some imperfection(s), and you don't care about perfection in the result, just purchase a can or two of spray touch-up paint and "have at 'er"!!!
Mar 24, 2015 | Cars & Trucks
Hello, I can not split the base for the monitor hp 1730, can assist me please, stuck in the laptop position
You have to remove four screws in order to separate the monitor base from the monitor.
Check the manual (section "Setting Up The Monitor", subsection "Removing The Monitor Base") for images of the location of the screws.
You can download the manual using this link: http://bizsupport2.austin.hp.com/bc/docs/support/SupportManual/c01129544/c01129544.pdf
Jun 13, 2011 | HP 1730 LCD Monitor
I am an experienced spray painter, but I have been out of the game for a few years and things have changed in that time. I am familier with most types of paint, including synthetic, cellulose, 2 pack and...
water base paints are out there but as far i know i think you should error on the safe side and use a resporator with most all paints........ as far as i know they havent fully improved waterbase paints to the point that they hold up on metal correct me if i am wrong when the car companys use them for all cars then i will! ( base coat clear coat is the best so long as you follow the mixtures as directed on the cans ( call some paint suppliers , savage dupont ect they can guide you on most types of paints)
Feb 24, 2011 | Air Tools & Compressors
How do you dismantle AL1917W LCD monitor?
Remove the base and all the screws, base plastic attachment cover will have to be remove to get to the base mounting screws. Use flat blade screw driver, starting at the botom edge and work you way around.
See service mauals here: http://elektrotanya.com/?q=showresult&megnev=ACER&megnev2=AL1917&kategoria=&kat2=all
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
Jun 25, 2010 | Acer AL1917W LCD Monitor
Stem on lcd monitor can't be removed
Usually the stem has a plastic cover that hides the securing screws from view. You must pry up the cover to reveal the screws securing the stem to the monitor. This is most easily done with a Plastic pry bar or plastic putty knife. Hope this helps you with your problem.
Apr 27, 2009 | Computers & Internet
Remove base completely from envision monitor
after removing all the screws, i used a knife to remove the plastic casing surrounding the monitor. that exposed four screws that when removed, released the base from the monitor. it was just a matter of putting the casing back together. thanks
Jan 30, 2009 | Envision 19" Widescreen Flat Panel LCD...
Viewsonic vg2021m base mount
Gently lay the nonitor, face down, on a table such that it will not be damaged while you remove the base. You will find a curved strip of plastic about 1 1/4 inch wide and 4 inches long. Near the center of this strip, you will find two parallel plastic ridges. These are clips that hold the base to the monitor support post. Squeeze these clips together to remove the base from the support post. I was able to squeeze the rear strip toward the rear of the base and ease the rear of the base off that clip and it came apart ok. It is a bit tricky, but doable. Good luck.
Orval
Dec 08, 2008 | ViewSonic VG2021m LCD Monitor
LCD Monitor
1st remove the base cover by by squeezing to release the clips and remove the 6 base mounting screws. 2nd remove the 5 screws in the back cover. 3rd push and pry at the parting line to release the clips. 4th remove the base mount by removing the two attaching screws and sliding it down about a quarter inch. 5th remove the steel cover by removing the 4 wires, two screws from power outlet, two bolts from vga plug, and the other screw in the cover. and there you have it.
Oct 26, 2008 | Acer AL1717 17" LCD Monitor
Removing oil-based primer from LCD monitor screen
paint thinner is about the only thing that could be safe for most plastics. but as its dry that will not likely work.
try some extra virgin oil or penetrating oil and rub it into the dots.
if you can get it to take the oil then it will come loose.
but you may have plastic damage anyway where they melded.
Jun 04, 2008 | Computers & Internet
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
