Question about Kingston Technologies 512MB DataTraveler I (DTI512KR) Hard Drive
Pen drive is not opening and at times coming to b write protected and cant format it
  • Kingston Master
  • 27,725 Answers
USB drives can be write-protected by modifying the StoreageDevicePolicies Registry key and WriteProtect Registry value.
click Start>run>regedit to open Registry Editor. and press control+F to open the find dialogue box and type "usb device" or "driverdesc" to open usb mass storage device or type "usb mass storage device" in the search windows. And right click on it and delete. This will set the policy value to 0. then insert your usb device. It will work fine.
# Remember: do not delete any unknow files in the registry as this will make some programes not work as usual.
also
If you are running a Windows XP OS then you might be able to:
- click start right click on my computer select open
- Right click the icon of your Flash Drive (It should be F:/ or something)
- Click Properties in the menu that comes up
- Click the Sharing tab
- Click permissions
- And finally, click Allow next to Full Control.
hope this helps
Posted on Mar 27, 2011
I am running a window 7 ultimate, but when I tried to format a flash drive kingston 2GB, the windows says "YOU DO NOT HAVE SUFFICIENT PERMISSION TO PERFORM THIS OPERATION" write protected, un...
You can download this Write Protected Small tools and try to format your pen drive, many times i have use this tool and was success too.
NOTE: before running the tool you should insert your pen-drive to your PC.
All the best.
Jul 18, 2011 | Computers & Internet
Tip
Removing Write Protection
Trouble:
In the past we had received so many problems from the readers who have a problem in copying files on their USB portable devices like pen drives, memory card and iPod etc.
According to the mails we had received about this problem, people have seen the following errors when their thumbs drives, memory card etc becomes write protected.
  • Cannot copy files and folders, drive is write protected
  • Cannot format the drive, drive is write protected
  • The disk is write protected
  • Remove write protection or use another disk
  • Media is write protected
Some times people say that suddenly their drive become write protected and they are not able to delete any files and folder on the drive and also not able to copy new files and folder to USB portable drive.
Let’s see how can you remove write protection on your portable devices like pen drives, memory cards, iPod and other USB mass storage devices.
Fix:
Write Protection on any portable USB Device can be applied by the physical lock provided on the card adjuster or some times provided on the pen drives, so make sure to make your drive not write protected by moving the lock in right direction.
But even after moving the physical lock for write protection the problem can happen due to some virus action. This happens when some virus or script which applies the registry hack to make any drive write protect when connected to the computer, In that case follow the procedure below to remove write protection from your pen drive.
1. Open Start Menu >> Run, type regedit and press Enter, this will open the registry editor.
2. Navigate to the following path:
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\StorageDevicePolicies
Note: If the registry key StorageDevicePolicies key does not exist, you will need to create it
Download this batch file called add.bat from here, and double click after download the key will be automatically added to registry.
3. Double click the key WriteProtect in the right pane and set the value to 0 in the Value Data Box and press OK button disablewriteprotection_thumb.png
google_protectAndRun("ads_core.google_render_ad", google_handleError, google_render_ad);
4. Exit Registry, restart your computer and then again re-connect your USB pen drive on your computer. That is it, done.
In case you still find an issue, please leave a comment below.
Updated on 28th May 2009
After a lot of user comments telling that the above method does not work for them, we tell you another method which you can follow to solve the “Pen Drive is Write Protected” problem.
If the above method does not work for you, follow the below steps:
1. Copy all the important data from this drive to your computer because this method will format the drive and erase all the data on the pen drive.
2. Now download the Apacer Formatting Utility, Unzip this utility to a folder on your hard disk, preferably on a folder on desktop screen for easy access (Do Not Try To Save it on pen drive). Keep your pen drive plugged in, and double click on the Start.bat file in the folder where you unzipped the above utility. This will start formatting your pen drive, wait till the formatting completes and the LED on your pen drive stops blinking. Remove your pen drive after than and plug it in again.
The above two steps will solve the problem. If you still face the problem, follow the below steps:
1. Goto Start > Run, type cmd and press enter, this will open command prompt.
2. Type the following command on the command prompt replacing X with the drive letter of your pen drive.
CHKDSK X: /F
The above two methods will help you fix the problem.
Note: For all those who are out of luck in fixing the problem with their portable drives, I would suggest you to get your drives checked or replaced by the manufacturer to fix it for you
on Jun 19, 2010 | Computers & Internet
I have transcend 2GB pen drive. when i insert my pen drive in system it shows the removable disk icon in MyComputer window . when i click the removable disk it shows 'please insert disk' ...i cant open the...
may be the flash drive is locked...unlock the pendrive and then try again.
formatting can be done in other way.
goto run,type cmd,press enter,then type format f: in the cmd and press enter.this formats the drive
Sep 09, 2010 | Transcend Computers & Internet
How to format write protected pen drive
visit this website for steps:www.techsupportforum.com
Jul 30, 2010 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
I cant format my kingston pen drive
try this...
connect it to PC then... go to My Computer icon on desk top >> right click >> manage >> Disk management >> select ur USB Flash Drive/pen drive >> right click >>format ....ok......
Jun 24, 2010 | Fuji (MAP3367NP) 36.7 GB Hard Drive
When i connect my pen drive to my pc then it gets connected but after that if i try to copy or delete or format the drive i cant because i get error as remove write protection mode and try again
HI there its a reason for virus infested system with pen drive. Your PC & pen drive both are infested by virus. That's why you are not able to deleted or copy or format that Drive. Its a trozonhouse or warm32 virus. I suggest you format the OS and install it again. After that connect the pen drive but remember do not open the pen drive. Straight way format the Pen drive first then open ok. Other wise your PC again virus infected by pen drive virus. Thanks.
Apr 02, 2010 | Computers & Internet
Hello sir i am having 8 GB transcend pen drive some of them did password fom my pen drive i tried to format so many times but it showed as the device is write protected after some time i tried...
1. Download this tool:
http://dl.dropbox.com/u/4040651/LLFTOOL.EXE
2. Format
(WARNING: After running this low level format tool,
the whole USB flash disk surface will be fully erased.
Therefore, data restoration will be impossible after using this utility!)
Feb 02, 2010 | Computers & Internet
Cant format write protected of my pen
Refer to the user's manual. It may be available from manufecturer's website's support or download section..
Jul 12, 2009 | iLO (2 GB) MP3 Player
Write protected
First try to see is there any lock in your usb pen drive and see if its not locking the pen drive, because some pen drives comes with that option to protect usb ..if its not
Use the Registry Hack to Disable Writing to USB Drives
Here is the link .just download the zip folder and after opening the folder you will find a file just double click on it..
http://www.howtogeek.com/wp-content/uploads/DisableUSBWrite.zip
Low feed backs hurt my ratings and I tried my level best to resolve the issue. so show your appreciation by rating it.
Thanks for using fixya support..You have a wonderful day
May 12, 2008 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
Computers & Internet Logo
49 people viewed this question
Top Kingston Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Kingston Computer and Internet Expert? Answer questions, earn points and help others
