Question about RCA 24F512T 24" TV
How do u add and delete channels on a rca 24F512T
  • RCA Master
  • 5,479 Answers
1) Make sure that the current input is TV. Then press Menu on either the TV or the remote.
2) Press Ch+ or Ch- to highligh Setup then press OK.
3) Press Vol+/Vol- to highlight TV or CATV as needed for the channels you wish to add or erase.
4) Then use Ch+/Ch- to highlight Channel and then press Vol+/Vol- to enter the channel number that you want to add.
5) Press Ch+/Ch- repeatedly to highlight Add/Erase then use Vol+/Vol- to select whether to add or erase the channel selected above (step 4).
6) Press Menu repeatedly to exit the OSD (or wait until the OSD closes after a period with no key presses).
Then use the Ch+/Ch- buttons to scroll through the channels in memory to see the change.
The manual for your 24F512T is available here: http://support.ttetech.com/RCATV/Assets/pdfs/24F512T_1641309F_IB_e-06.pdf . See page 13 of the manual for extra information on manual tuning and page 15 to add and remove channels from the channel list.
I hope this helps.
Posted on Mar 27, 2011
  • yogi_bear719 Aug 26, 2011
    my tv only goes to ch.13 how do i add the rest on a HV207, I go to menu, tv set-up theres add/erase when i try that it just erases. i tried the auto scan and it only went to 13. please help me!
  • Cindy Wells Aug 26, 2011
    What brand of TV do you have? I see a Proview HV-207 with an NTSC (analog) tuner.
    What is your signal source? Make sure to select the OTA or cable source as needed in the TV setup menu. (If you have cable, check where the analog channels are being broadcast. I lived in an area with 24 cable channels. They were provided as channels 2-13 with a manual A/B switch.)
    Try adding the channels in the add/erase tv setup menu by typing in the channel number with the remote numerical keypad. This works on most of my TVs where the initial list in the add/erase menu is only those found in the initial scan. (If you do not have a remote with a keypad, get a universal remote with one that is newer than your TV. You should find a code that works with the TV.)
    If you can't manually access the channels, then the UHF section of the tuner may be damaged or there signal is attenuated. (If you have an amplifier in the system, remove it. They can become filters blocking the signal when they fail. Mine usually block the VHF channels though.)
    You may need to replace the tuner. This may not be a good option today since sources are switching to digital signals.
    I hope this helps.
Hi, my kids deleted channel 3 & 4 on my Sony
You may have to conduct a channel search as you would for initial setup
Mar 08, 2013 | Televison & Video
How can I add a channel to RCA tv
direct enter the channel you want with the number buttons on the remote and if it goes there in the customer menu there will be a manual add or delete you can use to store it into memory.
Dec 04, 2012 | Televison & Video
My rca hd52w58 on autoscan will only find 4hannels MY Visio fines 38 suspect digital tuner any suggeationas?
Could be a tuner but a simple way to find out is DIRECT ENTER with the remote (numbers) a channel and hit enter---if it goes to missing channel you can manually in the menu with the remote ADD each missing channel one at a time--tedious but will rule the tuner out.
Almost every set made is able to add or delete channels one at a time.
Apr 15, 2012 | RCA HD52W59 HDTV Projection Television
Want to put rca 24f512t 20" tv in unheated garage.
CRT Based TV Operating temperature: 32° to 95° F (0° to 35° C)
Storage temperature: -4° to 113° F (-20° to 45° C)
Feb 18, 2011 | RCA 24F512T 24" TV
The tv will not get but 24 channels Is there a menu setup? I don't see one and does it get more than 24 channels?
there should be a menu button on the TV, once you get there, look for something that can add/delete channels, switch it to add, and then click the button that allows you to scan for channels
Jul 14, 2009 | RCA TruFlat 27F520T 27" TV
RCA 24F512T 24" TV Logo
859 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
