Question about Peavey Audio Players & Recorders
Have a VK100 head which lost 90% of the volume on the lead channel. Still works fine on the clean channel. Changed power and pre-amp tubes with no difference. All other functions of the amp work properly. Any suggestions would be appreciated.
  • glp79fs01 Mar 27, 2011
    I have a Peavey VK100 guitar amplifier which has a low volume on the lead channel. The clean channel has normal volume and all other functions operate correctly. All of the power and pre-amp tubes have been replaced with new tubes. All cables and speaker connections are fine since it operates correctly on the clean channel.
  • 2,418 Answers
Do you feel confident with getting into the guts of the amp? If so you need to gain access to the circuit area. Look on the back of the input on the Lead jack circuit, follow the circuit, on the tip contact of the jack (if you plug in you jack cord the tip will contact one of the metal prongs) look for a resister on this circuit that will be soldered to the contact and then solder to the chassis as a ground. It should be a 1meg ohm resistor. If you use a good hot pedal and run it hi on the input this can cause the resistor to overload and break down. Look for a cold solder joint (failed solder joint) also on this input circuit. Hope this helps.
Posted on Mar 27, 2011
    Brigadier General:
  • 3,513 Answers
Hi
First check to make sure the speaker cone or cones are properly connected and the connections are not loose. This is often the cause of intermittent sound in an amplifier. Check the speaker connections. Make sure the wiring connected to the speakers is firmly connected and is not loose. On some cases you may have to remove the chassis with a screwdriver to do this.
Use a continuity tester to check the continuity of the cabling that you are using to connect your guitar to your amplifier. While this is not a problem directly associated with the amplifier itself, it is a very common cause of intermittent sound. Make sure there is no oxidation on the input or output jacks of the amplifier. Replace any jacks with oxidation with new, clean jacks. Remove the chassis and cover with a screwdriver, unscrew the jack and put in the new one.
Swap your vacuum tubes one at a time if you are using a tube amp. While this is a somewhat long procedure, an overheating tube is a very common reason for a guitar amp to have no sound or intermittent sound. Turn off your amp to swap out tubes. Remove the tube and insert a new one. You may be able to tell if a tube is extremely hot by simply putting your hand near it and repeating the process with the rest of the tubes, although this is shoddy at best. Check for any loose solder joints on the inside of the amplifier. When an amplifier gets particularly hot after a long period of use, solder joints can start to open up and disconnect themselves. Check solders joints by removing the chassis while the amplifier is still warm.
Please get back to us if you have further query else please accept the suggestion.
Thank you for contacting fixya.com
I own a Peavey Valveking vk100 and when using the distortion channel on high gain it makes a weird whistle-like noise (not a feedback sound). The strange thing is that if i lower the gain, the sound...
Sounds like Tube Microphonics to me...
Change the 12AX7 (I guess) for that channel for starters.
If not, some condenser went crazy.
Nov 12, 2017 | Music
Right speaker terminal not working - tested out both speakers and they work fine when independently tested on the left speaker terminal. Sony MHC GX45 Shelf System, 2 speakers and 1 sub.
If the sound is also dead on that channel on a pair of headphones. Then you have probably lost the main power amp for that channel. To be certain. With you headphones on, slide or turn the balance control so you can only hear the faulty channel. With some music playing turn up the volume. If you can hear "faintly" music playing then the pre-amp is OK and the power amp has gone.
The power amp will be located on a heat sink. It will consist of 4 transistors (2 for each channel) or one big device (or two) (an IC). If it is transistors you only need to replace the two for the right channel.
Aug 31, 2013 | Sony COMPLETE PWB, MP-45 Shelf System
Peavey Valveking head strange feedback.
Sounds like one of your tubes going bad and becoming microphonic...
Google "Microphonic Tube" for additional info.
Oct 25, 2012 | Peavey Valveking Vk100 Guitar Head
My Fender Hot Rod deluxe makes a popping noise when switching back to the clean channel.
This is because your clean channel only runs through the pre-amp section, requiring an increased volume level to match that of the volume of the drive section which is overdriven by the pre-amp circuit. my suggestion is to use lower volume level on the clean channel of the amp. To get any volume boost you may need to match the two channels you could use a signal/volume booster or overdrive pedal between your guitar and amp input, switching it off and back on when you switch back and forth between channels.
Jul 15, 2012 | Fender Hot Rod Deluxe Guitar Combo...
My Peavey vk100 head is running through a Carvin Legacy 2x12 cab. On the clean channel there is an inconsistent popping sound. It will happen loudly for a few seconds, and then not at all for a while, and...
You may simply be overdriving the clean channel and causing it to "flat top" . See if it occurs when you back the gain down a bit. New tubes PROBABLY will not help and be a waste of money. You may be unconciously playing harder during the popping episodes. You cannot hear level variations smaller than about 3 Db BUT the electronics will sense much smaller variations. You could gently tap the tubes with a lead pencil to listen for any pops... NOTE: tubes can be slightly microphonic so some sound from tapping is normal.
Yes, a cable can be noisy and not show itself when using intentio0nal distoprtion... try another to verify it is not the problem.
Jan 02, 2011 | Peavey Valveking Vk100 Guitar Head
Fender HRD - clean channel works fine, drive & more drive VERY low volume, like a headphone across the room w/ all 3 volumes at 10. LED works fine in drive/more drive. All same w/ footswitch,...
Wayne, There's a time to take the amp to a pro shop andf get it done right. It' saves time and headaches, and also keeps you from inadvertantly smoking other parts or yourself. Now is that time.
Apr 17, 2017 | Fender Hot Rod Deluxe Guitar Combo...
Fender Stage 100 dsp, solid state amp volume (or power) problem
The Deluxe may have more efficient speakers....which would cause it to sound louder. Also, the EQ settings could play a part in this. If the EQ's aren't set the same there could be a noticeable difference in sound.....usually the mids can have quite an effect on overall amp volume....
May 31, 2009 | HHB Radius 50 Tube Amplifier
8 track player moters run but it doesnt pick up the music.
Sounds like either the head is open circuit or more likely the pre-amp for the 8-track has gone. Follow the leads from the head and it should lead you to the PC board of the amp. Check for broken connections first. You should get the pre-amp to buzz by touching the terminals where the head leads join. As you are getting no sound from either channel it might be the power to the board. But if you see a single IC it might have gone. For the power option (if the channels are seperate) suspect the largest electrolytic capacitor on the pre-amp board first.
By the way if you get a buzz from both channels the head has gone.
Apr 19, 2009 | Audio Players & Recorders
Hi i use a peavey 6505 Amp head and when i run a seymour duncan pickup booster through the effects loop it blows the amp (possibly the pre-amp fuses) i want to get a volume boost in a distorted setting...
Hi bmwz43
Odd that you keep blowing the head... and with 5 12axl preamp tubes even more surprised that you cannot get enough gain... :) Get the correct pedal for the 6505 and change yo levels that way. Hard to beat classic tube amp for tone:)
Check the the amp has the correct impedance setting for the quaddy you are using.
One more thing, what sort of cable do you have connecting the amp to the speaker box. If you use a cheapo guitar jumper lead arrangement, expect that to give you trouble AND **** tone. The 6505 has 120watts of cranked up tube output. Tube output stages need a solid at least 18 gauge cable and quality connector jacks, like Switchcraft. They can blow fuses if you don't use a decent speaker connector lead.
Get back to me here if it does it again, and check to see exactly which fuse you are replacing. It can help sort out the problem.
regards
Graeme
Apr 27, 2008 | Audio Players & Recorders
79 people viewed this question
Top Peavey Audio Players & Recorders Experts
 Grubhead
Grubhead
Michial Gueffroy
Jaime Hernandez
Are you a Peavey Audio Player and Recorder Expert? Answer questions, earn points and help others
