Question about Amana 19.6 cu. ft. / 555 liter Upright Freezer Deepfreeze AFU2067AW
I am having watr pool at the bottom of the freezer- it is a frost free unit Model number AU2067AW The unit is about 8 years old and works fine otherwise
  • Amana Master
  • 4,655 Answers
This is about time I believe your defrost drain has become blocked and is not allowing your defrost condensate to exit your freezer. Click here=> AFU2067AW Drain System Service Information.jpg This will explain just where to begin and Click here=> Leaking Refrigerators Just What may Be Happening Once there click on all of the links and read just what it will take to solve this problem. If you have any questions please ask. Please rate these solutions, Thanks, Sea Breeze
Posted on Mar 28, 2011
Freezer stops working and then over cools to -10
Sounds like the thermostatic control is worn out. Replacing it should fix the problem.
Hope this helps.
Bob
Oct 17, 2014 | Kenmore Freezer 20.3 cu. ft. Frost Free...
My upright freezer freezes everything fine my only pro.blem is that it builds up ice/frost on the ceiling of the freezer first and then works its way down i have taken everything out,started fresh and...
Since you didn't give a model number, I don't know if it is frost free or not. If it is, then you have a problem with you defrost system: defrost heater, thermostat or defrost timer.
It also sounds like your door seal is not making solid contact and most air is leaking into the freezer.
If your unit is a frost free, then water should drain down and out.
Jun 24, 2011 | Freezers
2 year old Kenmore freezer won't keep cold. It
Check underneath the unit and make sure the compressor is running and that the compressor fan is turning.
Oct 15, 2009 | Freezers
Frost-free fridge-freezer; internal floor icing up
drain plug and or line probably plugged should be clear if ice was problem in between the casing shouldnt be a problem let unit run normal and check temp the amount of high humidity and usage [open and closing of doors] has caused a lot of frost free and regular units to frost and or ice up
Sep 29, 2009 | Freezers
Water pooling and freezing on bottom of freezer. Cools poorly.
Check door gaskets if sealing properly? Check to verify freezer is level? If all of the above are fine then look at your drain for the condenasation. It's located at the bottom of your back wall underneath the aluminum evaporator that the cold air comes from. (You will need to remove the back panel inside of freezer wall To get to the drain. It's probably plugged and frozen over. Do not use a chisel or knif instead take a cup of hot water and pour it Oder the drain area and let it sit. (Your freezer will not be running for an hour or so so think ahead or work fast). That being said you have to unplug unit first :-) once you remove all ice push a straw or something through drain to verify its draining through. You can also flush more water down it to watch it drain showing you that it's working. Start with this first.
Jun 22, 2017 | Kenmore Freezers
BEKO Frost free freezer not as cold as it should be!
Sorry I don't have a solution for you, however would like to know if you found out what was wrong. I have an identical problem with my Beko fridge/freezer. It's only 14 months old and the freezer just wont freeze. I've turn it off for 24 hour and let it defrost completely (even had the panel off to make sure there was no ice left). I've turned it back on again and it still wont freeze. Everything seems ok, ie fan blowing, motor running etc. I really am beginning to regret buying Beko. thanks
Apr 12, 2009 | Freezers
Freezer frost
An upright freezer that is not frost free will have the coils in the shelves (shelves are non-removeable) and that is where the frost will buildup.  If your model is like this then it will have to be defrosted periodically.  If your not sure then give me the entire model # from the sticker inside the freezer and I will look it up for you.
Oct 16, 2007 | Amana 19.7 cu. ft. / 558 liter Upright...
Kenmore® (46-26072) Elite® 20.6-Cu. Ft. Frost-Free White Upright Freezer
Check these two things first.  1.  Is there a thick frost buildup on the back panel at the bottom half of the freezer?  2.  Do you hear the fan running inside the freezer?  Let me know what you find.
Oct 12, 2007 | Maytag Freezer MQU2057
Hoover HNU271AFFAL
as an ex hoover eng. these so called frost free units were never frost free!!!! if the unit was over gased in the factory it will over freeze. some early units were fitted with faulty modules and sensors. which were recalled thru engineer van stock but not to the public. call the service there service dept. but be careful not all hoover/candy/gias engineers are trained in refrigeration ( ask for a senior engineer. the staff turn over is huge!
Aug 13, 2007 | Hoover 9.9 cu. ft. / 280 liter Upright...
Ice build up in my frost free upright freezer
I looked at the BACK at the bottom underneath of my Sears Kenmore frost free upright freezer and what was causing the ice buildup was very simple. At the factory, the assembler looped the little hose too high and when the water went into the hose it could not get out due to being too high in one spot! An ice dam will form, blocking ALL water coming through
and freezing up any more water coming down giving you a HUGE wad of ice that is scary!!! I just removed the screw holding the loop that holds the hose and put a bit of warm water down the little hole on the INSIDE (Behind the grate) to melt the remaining ice in the tube.You need to take out 4 screws and remove the grate to see this. I could not believe that this was the problem! I haven't had any ice build up since.Now don't tear your freezer apart before you try this trying to fix the compressor, thermostat etc. It may be the only thing wrong with it!
Nov 11, 2006 | Kenmore 16.7 cu. ft. / 473 liter Upright...
Amana 19.6 cu. ft. / 555 liter Upright Freezer Deepfreeze AFU2067AW Logo
232 people viewed this question
Top Amana Freezers Experts
Victor Nwachukwu
Victor Nwachukwu
Charles T Nevin
Charles T Nevin
Sal De
Are you an Amana Freezer Expert? Answer questions, earn points and help others
