Question about Leadtek WinFast PVR2000 Video Capture
Audio only capturing through one speaker
I am having a real problem with my audio when capturing video using Winfast DTV2000H. When viewing the video or DVD through Winfast the audio is present in both speakers, however once I capture it and play it back it only records through one speaker. I have tried a number of different combinations in the set up without any luck.
I am at my wits end as I don't know what to try next. It may just be a simple setting that I have incorrect but I feel like I am going around in circles. Any help would be greatly appreciated...
Regards, Rachel
  • 2,794 Answers
Check the mixer and make sure that the recording source used for capturing is enabled and that the channel is set for stereo by making sure that the balance is in the middle.
Posted on Aug 04, 2008
Can i use microphon on winfast pvr 2000 on audio in?
No , you cannot use microphone on WinFast PVR2000 . The two audio jack is for audio input ( L & R).
Thanks
Please rate me if you got a satisfied answer
Mar 20, 2011 | Leadtek WinFast PVR2000 Video Capture
Audio
if you are having trouble with the sound on your computer
if your computer came with a motherboard disc the sound drivers could be on it
you might have to uninstall then restart your computer then reinstall both the sound drivers and the sound card make sure you have both of these devices backed up to a disc before uninstalling
a yellow? question mark means you need to install/update driver to do this
right click to install driver also
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question mark? Right click to reinstall drivers
click start control panel sounds and audio,volume,advanced,speakers select appropriate speakers also audio you will find 3 drop down lists make sure you have the correct settings there
also
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar
if his does not fix the problem
have you tried this control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check
the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the sound card and the CPU central processing unit dust causes static to build up in a computer
hope this helps
Feb 05, 2011 | Leadtek WinFast PVR2000 Video Capture
HOW T DO I CONECT A VHS VIDEO RECORDER TO MY WINFAST TV 2000XP EXPET TV CAPTURE CARD ?
Your VHS recorder has a Coaxe output! So does your card the sound will be replicated there as well, now it would not hurt to get a capture card that has those plugs as you rendering would be much more prestine. Pluag you VHS into the coaxe input on your card set the channel to 3 and you got it bud!!!
Rulds2008
May 25, 2009 | Leadtek WinFast TV 2000 XP Expert...
No sound from WinFast PVR2 tuner card
i looked at my windows xp winfast and i discovered that the audio was working only with the realtek hd audio
now the link is here and u can chose the driver:D:
http://www.realtek.com.tw/downloads/downloadsView.aspx?Langid=1&PNid=24&PFid=24&Level=4&Conn=3&DownTypeID=3&GetDown=false
May 08, 2009 | Leadtek WinFast PVR2000 Video Capture
Using TV card on PC video perfect no audio
SOme PVR cards need a small cable from PVR card to the Sound card input to play sound via the sound card.
Jan 16, 2009 | Leadtek WinFast PVR2000 Video Capture
Easycap usb adapter - shows images from video but there is no audio sounds
i c ant get sound on my pc,driver detactive saying i neet up date multimedia audio controller,anyone can help me p,lz?
Sep 16, 2008 | Leadtek Winfast PVR 2000 (663001C) Video...
WinFast PVR2000 - recorded video has no sound
check the software configuration for the tv card to see if it using the correct audio device
Feb 24, 2008 | Leadtek Winfast PVR 2000 (663001C) Video...
No sound
It uses your computer's standard sound card. You should plug the audio output from the TV card into the Line In on your computer's sound hardware.
Dec 09, 2007 | Leadtek WinFast PVR2000 Video Capture
Capturing audio with my DVT 2000
Double click the little yellow speaker icon in the bottom right corner of the screen. Click 'Options'. Click on 'Properties'. Check the boxes, click 'OK'. Make sure nothing is muted. You can also go into 'Control Panel' and then 'Sounds and Multimedia'. Check you see if that is set properly. Write back and let me know.
Jun 24, 2007 | Leadtek WinFast PVR2000 Video Capture
Winfast tv2000 xp
first you must have this kind of cable connector also known as "internal audio connector analog"
Apr 15, 2007 | Leadtek WinFast TV2000 XP Video Capture
Leadtek WinFast PVR2000 Video Capture Logo
119 people viewed this question
Top Leadtek Televison & Video Experts
Are you a Leadtek Televison and Video Expert? Answer questions, earn points and help others
