Question about MSI Computers & Internet
I just recieved my 785gtm-e45 from msi that was replaced oe no video through the vga or dvi ports n an rma and now i installed my MOBO and now I have no video through the vga or dvi ports???
  • 961 Answers
Aparently there have been some very bad reviews about the ATI 4200 chip on this board. I'm not sure what you bought it for but, if was for gaming you might want to upgarde to a PCIe card. I'm not going to paste the site btu Newegg has the reviews. How did you get ypur drivers for the board? I beleive your going to have to put some time in to making this card work. I am a firm believer that the initial software package should be from an installation cd but thats it. I've even done custom installs and left the garphics drivers out only to immediately download them from AMD. Waht i would try is an uninstall of all software and reinstall and try again. If that doesn't work, or at least I would do it anyway, either install the all software off of cd or, do a custom install and leave out the integrated driver whuch you can get from AMD. AMD's site;
http://support.amd.com/us/Pages/AMDSupportHub.aspx
Good luck with this and if you have any questions, let me know at "add a comment"
Posted on Mar 27, 2011
MSI MS-7549 USER'S GUIDE
please go here for your motherboard manual
Support For 785GTM E45 MSI Canada Motherboard The world leader in...
your motherboard model number is 785gtm
thank you
Nov 25, 2016 | MSI Computers & Internet
Mercury h61 problem vga port display problem while we r powering the system it is powering on and keyboard lights also coming but vga output is not comming.....i sure that it is problem with onboard...
Try using one of the other video output ports. Such as the DVI or HDMI port. Make sure you have RAM in the mobo. Also make sure all cables are connected correctly, and are securely connected.
Oct 08, 2013 | Computers & Internet
Connecting MSI M670 laptop to Dell U2412M Monitor
There is an adapter VGA to DVI, I suggest going to a computer store to locate one.
Mar 07, 2012 | MSI M670 Notebook
I have an HP m9000z that was previously used with a DVI cable/monitor. I only have a VGA cable/monitor and the pc doesn't access the monitor.
This PC has a VGA and a DVI ports? Are both ports on the motherboard or a Video card? Or is the VGA onboard video and DVI is a Video card? You may have to disable the DVI port to get Video to vga or enable the vga port.
Jan 13, 2018 | HP Pavilion Elite M9000z PC Desktop
I was using my pc to stream netflix when two capacitors "blew up", they made a loud popping noise and the was a burnt electrical smell and when I opened the casing there were the two capacitors...
I would recommend you to get a new motherboard, even though it still power on and post and stuff, i belive those compacitor are important in providing voltage current. If not replacing the motherboard, future wise it can short circuit the other hardware.
Apr 17, 2011 | MSI 785GTM-E45 Motherboard w/ AMD Phenom...
I wana download vga driver
you can download drivers from this link
http://www.nvidia.com/page/fx_5700.html
Oct 17, 2010 | MSI GeForce FX5700LE 256MB DDR AGP 8X...
DVI output problems with Acer Veriton M464
If you are comfortable with opening the case, you can try this: Unplug the power supply, make sure are constantly grounded (touching metal)remove add-in video card. Locate the "Clear CMOS" jumper (usually 3 pins in a row with two shorted via a plastic jumper). Remove the jumper and short the other 2 pins (if originally pins 1-2 with 3 open, short 2-3 with 1 open) for a few seconds. Then replace on original pins. Plug monitor into motherboard video port and power on. If it works, you can leave as is or try to re-install your video card following the same precautions when opening the case and probably changing BIOS settings to utilize the add-on card.
Sep 12, 2009 | Acer Computers & Internet
Dvi-dvi connection to a ati radeon hd4670 does not recognise monitor,ie no display. Using a supplied adapter dvi-vga and a vga cable their ia screen display but in device manager it is a generic monitor?
Was there an installation disc that came with it in the package? Some monitors require software to be used. If you don't have the installation disc, you will most likely find the necessary software on the manufacturer's support site: ProLite Support Driver Download Site.
If the monitor software doesn't solve the problem, try using a different DVI cable. More often than not, these types of problems can be traced back to a faulty cable or port. If the DVI port on the monitor is bad, you will have to use the VGA port as you are now or replace the monitor.
If the DVI port on the video card is bad, you will need to replace it. A good way to test this is if you have another monitor with an available DVI port you can connect to the video card.
Hope this helps! Good luck!
Aug 10, 2009 | iiyama ProLite E481S-B 19" LCD Monitor
EMachine stopped displaying video (card not working, just mobo)
Hi there
I would say it's the graphics card that's failed. You might get the same beeps for faulty card as removed card....
Take it to a shop where they can test a compatible card, before they sell you one or install one for you.
Jan 09, 2009 | E-Machines eMachines Desktop PC
Nvidia GeForce 7200 GS PCIE - Multi-Display does not work
This card does not allow you to Multi-Display with the VGA port and the S-video port. If you put a DVI to VGA port adaptor (not supplied) on the DVI port, you can Mulit-Display two VGA monitors and (presumably) a VGA (from the DVI port) and S-video monitor.
This is not explained anywhere and the card does not come with a DVI to VGA port adaptor, so I wa only able to work this out after I bought the DVI to VGA port adaptor.
May 21, 2008 | Nvidia GeForce 7200 Graphic Card
Computers & Internet Logo
222 people viewed this question
Top MSI Computers & Internet Experts
vsri9
Alun Cox
David
David
Are you a MSI Computer and Internet Expert? Answer questions, earn points and help others
