Question about Nooka Unisex ZUB Polyurethane Watch ZUB-ZOO-BG-38
Beeps all the time and the screen keeps on blinking. i cannot reset it. i tried presing all the buttons but it doesnt work.
I had the exact same problem with my watch, it wouldn't stop beeping or flashing and the reset would not work. I fixed the problem an hour ago by replacing the battery in the watch.
hope this helps!!
Posted on Feb 21, 2012
It seems that that continuous beeping relates to the battery being about to die off
Thus, replacing the battery will fix the issue
Posted on Nov 23, 2014
How to stop the hourly beep in sonata fibre watch
you could try this
hold the reset button for a few seconds and then your timings will be blinking.press the start button to adjust your time and mode button to go on min and sec clock
May 04, 2016 | Watches
My Sportek Watch (Alarm Chronograph Water Resist 30 m, with velcro band).... I can't reset it...lost manual
you may find a manual from the manufacture. hold the mode button down 3-5 sec's. the hr should blink ,use the opposite side buttons to change the number, then press mode again mins blink change, do this and set hr,min,sec, am or pm? then date month,day yr. press final time and time should be shown with no blinking. you can also hold in all buttons and let beep 5 times it resets to zero defalt settings
Jun 17, 2011 | Watches
KADIO KD-3806 Model watch. How can we set date and time.
ALL PARAMETERS CAN BE ADJUSTED BY USING KEYS
GIVEN BACKSIDE...KEYS ARE
MODE (LONG PRESS-4 SEC) TO ENTER INTO SETTINGS;
UP/DOWN TO CHANGE THE PARAMETERS; \
*C/*F KEY TO TOGGLE BETWEEN TO TEMPERATURE FORMAT;
SNOOZE BUTTON TO SET SNOOZE IN ALARM-MULTIPLE SNOOZE CAN BE SET;
RESET KEY CAN BE USED TO RESET CLOCK TO DEFAULT;
DAY COUNTDOWN , AND TIME COUNTDOWN CAN BE ADJUSTED;
DETAILED INFORMATION TO SET THE CLOCK
INSERT CELLS;-SCREEN SHOWS DEFAULT VALUES-INITIAL MUSIC WILL RING;
LONG PRESS MODE BUTTON-KEEP IT PRESSED UNTIL 12 STARTS BLINKING;
USE UP /DOWN BUTTON TO ADJUST HOURS...
THEN SIMPLY PRESS MODE AGAIN, NOW MINUTES 00 IS DEFAULT WILL START BLINKING;
USE UP/DOWN BUTTON TO ADJUST MINUTES;
AGAIN PRESS MODE, SCREEN WILL SHOW YEAR 2002 DEFAULT BLINKING, USE UP/DOWN KEY TO ADJUST YEAR;
AGAIN PRESS MODE, SCREEN WILL SHOW MONTH BLINKING, USE UP/DOWN KEY TO ADJUST CURRENT MONTH;
AGAIN PRESS MODE, SCREEN WILL SHOW DATE BLINKING, USE UP/DOWN KEY TO ADJUST YEAR;
AGAIN PRESS MODE, SCREEN WILL SHOW 12:00 BLINKING WITH ALARM SIGN (FOR ALARM SET);USE UP/DOWN KEYS TO SET ALARM, FIRST HOURS AND THEN MINUTES FOR ALARM; THEN ON PRESSING YOU CAN SELECT SNOOZE MINUTES;
AFTER SNOOZE ON PRESSING MODE AGAIN YOU CAN SELECT DAY COUNTDOWN TO SELECT 999 DAYS COUNTDOWN FROM CURRENT DATE;
when watch displays time and everything .....
each and every buttons has some function;(shortcuts)
press down to toggle between 12hr/24hr format;
press up to enter contdown timer;
press snooze to set snooze in alarm;
press c/f to toggle between two temperature formats;
press mode to toggle between alarm time and current time
Nov 12, 2010 | Watches
How do I change time on a KADIO clock 3809
press mode to toggle between alarm time and current time;
Nov 08, 2010 | Watches
I bought the water resist watch from walmart this evening it doesnt have a name brand on the watch but i think its a casio but it didnt come with the instructions on how to use it, the number on the back...
Thank you for contacting FixYa.
  • There should be four buttons: mode, reset, start and light. Find the mode button and press it three times until it is in the set time mode.
  • 2 Find the reset button, which usually is located on the bottom right side of the watch face, and hold it until the time starts blinking.
  • 3 Press the start button to change minutes.
  • 4 Press the reset button again to switch to hours. You will know it worked when the hour starts blinking instead of the minutes.
  • 5 Press the start button to change the hour. The watch can handle two modes: standard and military. As you press start, the hour will change from AM to PM, noted by an "A" or a "P" in the top right. When you get through 24 hours, the watch will change to military time and an "H" will be displayed instead of "A" or "P." Keep pressing start to go through another 24-hour cycle and it will revert back to standard time.
  • 6 Press the reset button to switch to the date, starting with the month, and press start to change it.
  • 7 Press reset one last time to switch from month to the day, and again press the start button to switch days.
  • 8 Press the mode button to finish the changes.
  • Sep 14, 2010 | Watches
    Aw60447w digital watch. I cannot turn off the hourly beep. help
    Hourly chime on/Off:
    1.) Press and hold the lap/reset button (bottom right) to display alarm time
    2.) While holding lap/reset button, press the mode button (bottom left)
    3.) If the all the day of week indicators our lit, beep is on. If they are all off, beep is off.
    Alarm On/Off:
    A press of the lap/reset button (labeled) will show the alarm time, Unpress will show the time of day. Press again toshow the alarm time. Press and hold the lap/reset button will show the alarm time again, but it will hold there. While holding this lap/reset button, press the start/stop button (labeled). This will turn on (or off) the alarm (tiny indicator). Press this start/stop button repeatedly (while still holding the lap/reset button and you will see the indicator turning on and off with each press. Stop this button pressing with the indicator OFF, let up on the lap/reset button, and the time will return to the screen. The alarm will now be OFF.
    Jan 26, 2010 | Swi Watches
    Lost instructions to set my solo digital watch
    I think I have the same watch and was just looking here to see if I could find how to stop the alarm going off every hour! However, I think I do know how to change the time: press the mode button three times (the first one brings up something like the stopwatch, the second brings up what may be an alarm time). On the third press you should get the time appearuing with the seconds flashing on the far right of the display. You can then change the second by pressing the"start" button. To change the minutes or hours, oress the "reset" button until they start flashing and use the start button again. pressing the reset button again will bring up the date to change. keep pressing until nothing is flashing any more and poress mode and it should bring you back to the current time. hope you can follow this and it works!
    Jan 11, 2009 | Bulova Watch
    Setting watch
    Press and hold the top left button (mode) until the numbers start blinking. On mine this is the alarm time set. Press the mode button one more time to get to time set. The hour will be blinking. Press top right button (start/stop) to cycle through hour, minute, date, etc. and press bottom right button (adjust) to change the number which is flashing. Press mode to finish.
    To turn off alarm, press and HOLD Adjust button, then press Start/Stop to cycle through alarms on/off.
    Mar 25, 2008 | Timex 1440 Nylon watch
    Setting Bench Watch
    Reset Instructions Bench. (BC0013BR)
    Time and Location
    If you hold in the light, start and the reset button for a few seconds a screen will appear with the 12h or 24 h clock setting and also the date and country.
    Once you have that screen if you press the mode button it will move over the date and clock etc then you just press the reset button and start button to choose the date and time.
    Once you have changed the date and time to the correct date press the light button, start button and reset button and it will save the settings.
    Alarm
    Hold in the light, start and the reset button for a few seconds a screen will appear
    press the mode button it will move over the date and clock etc then you just press the reset button and start button to choose the date and time. Use the light button to set the screen.
    Feb 27, 2008 | Watches
    Nooka Unisex ZUB Polyurethane Watch ZUB-ZOO-BG-38 Logo
    466 people viewed this question
    Top Nooka Watches Experts
    Raymond Richards
    Raymond Richards
    Tom Chichester
    Are you a Nooka Watch Expert? Answer questions, earn points and help others
