Question about Dishwashers
After a few minutes of washing, Vulcan Supreme dishwasher stops washing and fast wash cycle light starts flashing while doing nothing.
  • 5 more comments
  • breneliz Mar 27, 2011
    the fast wash light flashes continiously, no screen to show an error code, serial number 1015562101, manufacturer number A8934WW
    We have the manual which seems to be telling us that the dishwasher is not filling but when we open it there is water in the bottom. Have turned off power now and will see if this works in 10 minutes.
    Rick
    We have had the power off for 10 minutes. Put back on, ran a fast wash, dishwasher fills then stops with flashing fast wash light. Manual says flashing fast wash light means inlet blockage or tap turned off but the bottom of the dishwasher is full of water. To empty it have to press a wash cycle, dishwasher empties then sounds like it runs for a short time and is now flashing rinse & hold which according to the manual means that the outlet blocked but there is no water in the dishwasher now so obviously it is emptying out and its hot so hot water has run through it.
    Thanks Rick its now late sunday night our time and in order to do all of this our unit needs to be removed from the cabinet. We will try these suggestions tomorrow and get back to you.
  • breneliz Mar 28, 2011
    have checked all hoses machine will fill then stop and fast wash light starts flashing then i have to select another wash cycle to empty the machine it emptys at a good rate into the bucket it just wont go into a wash mode
    i have reset the water level and now i have a flashing eco save light which the manual tells me to contact service division how do i just reset the machine i have tried turning off the power when i turn it back on it just tries to empty with flashing eco light
  • breneliz Apr 03, 2011
    have sent photos to adrian at vulcan
  • 1,998 Answers
How many times is the light flashing and does your unit show any error codes?also what is the model number of your machine as well Thanks Rick
Posted on Mar 27, 2011
  • 7 more comments
  • Rick Ead
    Rick Ead Mar 27, 2011
    do you happen to have the manual for that unit for some reason its not coming up for me under the troubleshooting section should say something about the flashing light im going back to looking for your service manual message me back if you have your manual thanks Rick
  • Rick Ead
    im going to contact directly to the manufacturer on this issue if you do not have the manual thanks Rick
  • Rick Ead
    also have you tryed turning off the breaker for 7 minutes this causes the control board to reset and then flip on the breaker and try running a wash to see if reseting the control has cleared the error less then 50 percent of the time this fixes the issue so I do not expect this to but do try this while I await your reply on the manual Thanks Rick
  • Rick Ead
    hello I have sent an email off to vulcan to obtain myself a copy of these error codes but seeing how you have your manual we can alleviate the problem that your having with yours first thing to do is shut off the water that goes into the machine. Following shutting off the water you would then disconnect the drain hose from where it goes into either your sink or garbage disposal make sure to check the end of the hose as well as where the hose plugs into for any blockages. Following your checking the hose and where it plugs into you would then try to test the unit with the drain hose going into a bucket on most units if you start the unit and await for it to fill and then you press cancel this activates the drain pump when this happens check to see how the flow of water is coming out the hose if the flow is a fast steady flow and you are still getting those lights we would then have to check the impellar on your pump and the flow sensor on the inside of the machine if the flow was weak or trickling then you would have a blockage still located at the other end of the drain hose or near or inside the drain pump itself in which you would then have to de-install the entire dishwasher and pull the entire unit out and first disassemble the drain hose from where it plugs into the drain pump and if needed the drain pump as well following this if you still were getting this drain error which is not saying the unit is not draining it is saying someting is obstructing the flow of water that is going out of your machine so perform the first test and run the drain hose into a bucket and observe the flow of water that goes into the bucket after checking for any blockages on the drain hoses end that goes into you piping remember to look inside or take something like a screwdriver to stick inside the hole to assure there is nothing jamming the hole and message me back with your finds Thanks I await your reply Rick
  • Rick Ead
    kk I will be awaiting your reply Thanks Rick
  • Rick Ead
    Rick Ead Mar 28, 2011
    ok if its emptying at a good rate yet it isnt going into an actual wash the next thing to check would be the sump and motor assembly you have proven the drain in the unit is working properly by completeing your test you would need to watch the motor with the unit once again pulled out when it fills then it should go into the wash stage what is the motor doing is it doing nothing at all is it humming during this stage does it move at all? Hopefully vulcan will send me my request by tomorrow so i can see your unit and have the service manual as well for your specific unit I await your reply Thanks Rick
  • Rick Ead
    shut off the power at the breaker leave the unit off for 7-10 minutes this usually resets the control so it doesnt tell you whats the flashing eco light means in your manual as well? This is actually silly of this company not to post what there error codes like other major appliances do especially to techs il check my email in the morning and see if they have responded yet thanks again Rick
  • Rick Ead
    hello there saying they are unable to find the serial or model number lookup for the unit and would like to know if you have a picture of the unit at vulcan
    Tel: (011) 249 8500
    Fax: (011) 249 8504
    Email: adrianc@vulcan.co.za
    www.vulcan.co.za
    send the picture of your unit to adrian and he will message me back Thanks again Rick
  • Rick Ead
    Rick Ead Apr 03, 2011
    great now we just have to wait for him to reply to one of us if i dont hear from him monday i will message him again Thanks Rick
Fast flashing
The outlet pump could be triggered because the "anti flood device" polystireen float and micro switch at the base of the washer has detected a water leak from a leaky hose or water spil) This device automatically puts the pump out motor on and stops any washing process.You need to dry the base of the washer and determine what caused the water spill. This should start the washing prosess.
Mar 20, 2010 | Dishwashers
Kenmore Dishwasher 5871525 stops running after a few minutes
sounds like a stuck key pad since you said the normal wash button flashed.. the other thing is try holding the door shut while you run it.. to see of it is maybe not latching properly..
Apr 10, 2009 | Kenmore 15762 Dishwasher
Kenmore Elite Dishwasher clean light ind flashing and won't start
You will have to reset the console. To do this, close the door and press these buttons in sequence...
-high temp wash
-heated dry
-high temp wash
-heated dry
...all the lights will turn on briefly and the machine will start a diagnostic cycle. You can press cancel or let the diagnostic cyle finish (1-2 minutes).
You should now be able to run the dishwasher as normal.
Feb 17, 2009 | Kenmore 24 in. 15142 Built-in Dishwasher
Kenmore Ultra Wash Dishwasher LIghts are blinking....
I suspect for either of these units that the timer control boards are bad.
Jan 24, 2009 | Dishwashers
Unable to reset wash program
Press and hold the start/stop button for a few seconds.
Nov 25, 2008 | Asko 24 in. D3112 Free-Standing Dishwasher
Dishwasher flashes on Fast Wash
I am hoping I have just fixed mine with same problem. Couple weeks ago started stopping at start of cycle with fast button flashing. Check filters so one on top of unside machine and one on tap if you have one on there. Mine were blocked but still wouldnt work. I pulled out machine to find a kink in the water pipe. I have straightened this out and up to now its working. Fast button flashing refers to water inlet problem.
Feb 27, 2008 | Dishwashers
I just read this for the same problem: push sanitize, then heat and dry, sanitize, heat and dry, sanitize, heat and dry, cancel, then open and close the door. It worked. The dishwasher is running correctly even as I type this.
Feb 11, 2008 | Kenmore 24 in. 17262 Built-in Dishwasher
Dishwashers Logo
104 people viewed this question
Top Dishwashers Experts
