Question about Emerson Black Microwave Oven
It dont strart to hoting - Emerson Black Microwave Oven
  • 2,382 Answers
Hi, the problem you are having with your microwave is a common one. Not heating is a problem that can be caused by three things. I'll list the most common solution first, the magnetron that actually does the heating is what is making that noise and has gone bad. It is possible for you to also have a bad high voltage diode that has opened up, solution two, or solution three is the high voltage capacitor is not working properly as well. From my experience with microwaves I am positive that it is your magnetron that is bad. If you are not do it yourselfer you'll need to take it to a repair shop to replace. However, if you know how to use a screwdriver and can unplug a couple of wires with spade terminals on them, then you can take it off yourself, find another one and replace it the same way you took it off. The magnetron sits behind the control panel of your microwave but on top. It has cooling fins on it and has 2 terminals maybe three depending and make and model that plug into it. It has 4 screws that are easy to get to that actually holds it in place. If you do not have a good local source like an electronic parts supply place then you can find the right magnetron at www.mwoparts.com. Be sure you always unplug the microwave before touching or trying to take the he cover off and then when you take the magnetron off also.Good luck and God bless.
Posted on Mar 27, 2011
My microwave oven dont turn on i can put the minutes but when i turn on dont start
It's probably a bad door switch or door switch mount.
See these links:
http://031d26d.namesecurehost.com/mwd/safety.txt http://031d26d.namesecurehost.com/mwd/disassembly.txt
http://031d26d.namesecurehost.com/mwd/doorsw.txt
You can find links to helpful exploded view diagrams and part ordering help here.
I recommend that you bookmark that link to your favorites.
Oct 24, 2012 | GE Microwave Ovens
Microwave keypad dont work
The problem is in the keypad control board, cost will run high making a new microwave oven attractive.
Apr 06, 2012 | Hotpoint Microwave Ovens
GE microwave: model 1840 circuit breaker trips when strarting micro wave
Circuit Breakers do weaken over usage. It is not usually a time factor as much as a load factor. Each time a circuit breaker trips, it loses its ability to carry the same load as it did previously. In other words, a 15 amp breaker only carries the ability to carry 15 amps once. I recommend replacing the circuit breaker with one that has a matching rating. If you do feel up sizing is necessary, check the load rating of the appliances to make sure the additional size really is necessary. Increasing power to appliances that shouldn't need it increases the risks of potential electrical fires and masking real issues. Try changing it with higher amp breakers.
Please accept the solution if it's helpful. Do get back to us for any further query.
Thanks for contacting fixya.com
Sep 27, 2010 | Microwave Ovens
How to install new light bulb
unlike the older models were there was a small compartment were you could take of a small covering and unscrew / replace the globe they are now a sealed unit if you take the entire top of youl see the globe and black globe holder dont try to unscrew it they dont unscrew if you can order a new globe holder included then simply install as per removal but be carefull microwaves hold a lot of power even when disconnected from power dont touch the capacitor or it will shock you
good luck
please rank me ..
Jul 04, 2010 | Microwave Ovens
The inside finish on the oven door is coming off--is this harmful?
its not harmful at all,,,it just dont look to nice,, the microwave will still work fine as any microwaves will just bounce off the inside of the door and be reflected back inside the oven just as they do on all the other sides of the oven,,, after all the door is only coverd in paint,, and that dont stop microwaves so dont worry about it,, all the paint has come off the inside of my microwave door,,, and its been working like this for years now
Feb 19, 2010 | GE Advantium SCA1001SS Convection /...
Stopped working normally, makes low grumbling noise
have a look at the glass plate rollers first if there sticky free them off, but if the noise is from the inside of the microwave its likley to be a short in the mains coil witch case dont even think of fixing it
it would be far cheeper to buy a new microwave insted
a word of warning,,, dont think you can fine an easy fix for it, if its an internal fult, and dont go tinkering inside of it, there is very high voltage inside this microwave it can kill you if you tuch the wrong part have ever seen a police stun gun working???????
it realy hurts you,,,
your microwave has the stun guns very big brother inside of it,, it dont stun,, it kills!!!!
best to plat it safe dump it and buy a new one
there only about £50 today
so is your life worth more than £50???????/
Oct 27, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave dont work after short with light bulb
your internal unit fuse has opoened
Sep 30, 2009 | Microwave Ovens
To make rice they said to touch 3 times but dont work
you may also have to enter the serving size then hit start..
Feb 14, 2009 | Goldstar MV-1615 Microwave Oven
Display and lights dont come on
Since you don't want to check it further yourself, I would suggest calling Sears for service.
Dec 24, 2008 | Kenmore 62622 Microwave Oven
Emerson Black Microwave Oven Logo
Top Emerson Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Jerry Greenberg
Jerry Greenberg
Are you an Emerson Microwave Oven Expert? Answer questions, earn points and help others
