Question about Samsung WEP650 Bluetooth Headset
How to connect blue tooth headset to samsung mobile
SOURCE: pairing a samsung wep200 headset to a samsung blackjack
Great solution. I threw away my instructions. The key is the 0000 pass key!
Posted on Jul 25, 2007
SOURCE: Bluetooth problem
I have an lg sprint muziq and I cant get my blue tooth headset connected. The phone can't read or see the blue tooth head set
Posted on Jul 04, 2008
  • 8 Answers
SOURCE: I didnt Connect my Blue tooth Headset to Samsung
hold the power button till it flashes blue an red with a fast pattern the pick search on your cell when it finds it click pair then type in (0000) as the pairing code if that one doesnt work try (1234)
Posted on Aug 08, 2010
casouzaj
  • 1118 Answers
SOURCE: Is Blue tooth headset Plantronics Explorer 210
Your headset must be in paring mode, in order to be paired with your phone. If, after turning it on, the indicator light doesn't alternately flash in red and blue (thus indicating it is in pairing mode), it has, most probably, been paired to another phone before. In this case, turn it off, wait for the indicator light to turn red, and, then, off. Then, turn your headset on again, and hold the call button until the indicator light is flashing alternately in red and blue. Either way, make your phone's bluetooth application search for new devices. After a while, your headset should appear on-screen. Make it connect. If a pairing code (or PIN, or passkey) is requested, enter '0000' (four zeros). If the pairing process has been successful, your headset will enter the stand-by mode.
Hope it works for you.
By the way, if your headset's user guide happens to be missing, feel free to download it from this location.
Regards, Carlos
Posted on Sep 10, 2010
casouzaj
  • 1118 Answers
SOURCE: I can not connect my
Starting with your headset turned off, press and hold the call button for some seconds as if you were turning it on, but keep the button pressed until its indicator light is steadily lit. It is in pairing mode now. Then, make your phone's bluetooth application search for new devices. After a little while, you headset should appear on-screen. Select it and make it connect. If a pairing code (or PIN, or passkey) is requested, enter '0000' (four zeros). If the pairing process is successful, your headset should enter the stand-by mode. There could be an indication on your phone that a headset is connected too.
Anyway, please, let me know if I can help you out any further.
Regards,
Carlos
Posted on Jun 30, 2011
I try to connect my blue-tooth headset model NOKIA BH-209 with my Nokia E63 mobile phone , but My NOKIA E63 mobile phone does not search NOKIA-BH-209, my NOKIA blue-tooh BH-209 is working with an other...
PLEASE MAKE SURE THAT YOUR PHONE BLUE TOOTH IS WORKING PROPERLY IF YES TRY CONNECTING YOUR PHONE WITH OTHER BLUE TOOTH HEADSETS. IF IT GETS CONNECTED YOUR PHONE DOESN'T SUPPORT YOUR HEADSET. IF IT DOESNT YOUR PHONE ISN;T WORKING GOOD.
Jul 18, 2011 | Cell Phones
Tip
How to connect a (Motorola) Blue Tooth headset to a mobile phone!
The following procedure is dependent to the phone in use! However it is mainly for Motorola brand but it works with many others too!
1. Turn on your mobile phones bluetooth function and go to search for new devices menu.
2. On the headset, From turned off state, Try holding down the power button for at least 5 seconds.
- The light should stay constantly on (or in other brands flashining very fast) which means the headset is in receiving/searching state!
3. search in your mobile phone for blue tooth devices(the phone and headset shouldn't be more than 5 meters away from each other )
4. When you find your blue tooth headset, chose it and hit "connect" or "pair" with the device!
5. you will be asked for a pin, put in "0000" and ok!
now your headset should be paired with your phone (the light flashes slowly) and will be ready to receive calls!
Best wishes
Bruce
on Jan 27, 2010 | Cell Phones
I'm not able to pair my bluetooth to my new samsung intercept
-Actiaved your blue tooth in ur mobile keep it in visible mode
-then switch on your bluetooth make sure that light on bluetooth should glow
- then search for devices from ur mobile.
-you can find the blue tooth device ( it will requst for some Code just enter 1111 o 0000 )
- then you can use it
Oct 20, 2010 | Samsung WEP301 Bluetooth Headset
I has sony ericsson blue tooth, my phone is nokia E72 how to connect?
By sony ericsson blue tooth i think you mentioned the headset. If you got the manuals for that headset, just check for the default pin code for the headset. But if not try these pin codes such as 1111 or 0000 or 1234 etc.
To Connect:
1. goto connectivity in ur mobile nokia e72. you will find it as a seperate icon in your menu, or you can get it from setting/connectivity.
2.in that switch blue tooth on.
3. now go to the next tab, and select options. from that select new paired device.
4. Now it will find the blue tooth headset. If it didnt detect, make sure your bluetooth headset is switched on.
5. then select that headset fro the search result and then it will ask for confirmation with the pic code.
type the pin code you hv gt from the manual or try these(1111 or 0000 or 1234 etc.). then it will accept. If its accepted, the bluetooth headset will start working!
Thanks, ask me if u gt any doubts.
Oct 06, 2010 | Cell Phones
How to connect to a phone
You need a active blue-tooth connection for the connection.
Turn on your blue-tooth of the mobile and search for the devices. it will show you the list of devices you can connect to. Select the one you need.
Thanks
Aug 12, 2009 | Jabra BT130 Wireless Headset
I try to connect my HTC M200 bluethooth headset with my Samsung S-M5230 mobile. The mobile can not find the headset. I tried it with another bluethoot, and it worked. The headset also use to be working...
is this the first time that you're going to pair the phone and the headset? try to turn off both devices, turn on the blue tooth headset, try to press and hold the power button for 5 seconds until you see a solid led light on the headset, try to open the phone, open the phone's blue tooth then search the headset. If the phone is asking you to enter a code try to enter 0000.
Jul 06, 2009 | Samsung Cell Phones
Blue tooth is not pairing
have u tried activating your bluetooth on your mobile and press and hold the button on your headset until the light comes on it should then recognise iit
May 26, 2008 | Motorola Mobility HS801 Consumer Headset
Blue tooth hs 801
hi, first press call and volume key simultaneously for 4 sec, then it will turn on. then make search on your mobile for bluetooth device and connect with it. then it will ask for passcode, type any number... while mobile is connecting continue pressing its volume key until it connects... and then here u r connected with ur headset...
May 24, 2008 | Motorola Mobility HS801 Consumer Headset
Not working with Samsung U600
YOu will have to put the headset in pairing mode by keeping the power button pressed till the light becomes solid blue instead of blinking. Now switch on the blue tooth of your mobile and try pairing,. it should work. passcode will be 0000
Jan 29, 2008 | Samsung WEP200 Headset
Samsung WEP650 Bluetooth Headset Logo
Top Samsung Radio Communications Experts
JP Services
JP Services
Jerry Greenberg
Jerry Greenberg
Are you a Samsung Radio Communication Expert? Answer questions, earn points and help others
