Question about Canon EOS 40D Digital SLR Camera Digital Camera with 17-85mm IS USM Lens
Got Error 99 on my 40D. Have done all the obvious: remove battery, replace battery, check lenses, SD cards. Have talked with several people who tell me it's "common" with 40D. Any assistance you can give.... I was in the South Atlantic on big cruise when this happened :-(((
  • Canon Master
  • 3,530 Answers
Welcome to Fixya
Err 99 could mean several different things, such as... Memory Card, Lens or Lens contacts....
Here's what you can try:
Remove the memory card an enable "shooting with out memory card" and see if you still get the error. If it works your memory card is bad. Try another lens if you can. Clean the lens contacts with a pencil eraser (be careful not to get eraser dust in the camera body or in the lens). Worst case scenario is, Err 99 could be related to the shutter failing which would mean a trip to Canon.
Thanks!
Posted on Jun 06, 2011
  • marylou858 Jun 11, 2011
    Turns out I had to return it to Canon ... $435 to replace sensor electronics
The lense of my PowerShot A430 is stuck and thereby renders the camera useless. Is there a way to fix this or should I just buy a new one?
Zoom lenses - stuck in its housing or fully extended are caused by factors like - knocks, dead butteries debris or some form of corrosion .
This is a risky method and I would recommend for the last option, if other conventional methods don't work.
Provided your lens has collapsed into its housing - you try a little knock on the camera with your palm while pressing the on/off button. If that does not work, you are on your own - to decide.
Sep 14, 2014 | Canon PowerShot Cameras
My Kyocera Rise has LOTS of problems! The one I want to ask is why do I keep getting a random message saying, "SD card has been unexpectedly removed"?
There are several possible reasons for this. The Kyocera Rise requires an SD card to be unmounted through the memory option in the settings. If you remove the SD without unmounting, you will receive the error message. The Rise also has several software issues that sometimes cause your SD to stop being read, even while still inserted. If you receive this error message without removing your SD card, it is recommended that you take your phone to a company certified Sprint store to have it checked out.
Jul 01, 2013 | Cell Phones
Water in the battery and SD Card
Yes if you dry the SD card off you should still be able to get any data off of it. Do not heat it just use a towel or something.
Mar 04, 2013 | Fuji FinePix XP20 with Mini Tripod, Carry...
My Canon EOS XT continues to show error 99.
Err - 99 is one of the most frustrating messages a photographer can get because it basically means "there's something wrong, I'm not sure what it is, but something is definitely wrong". The error 99 code is a multi use code that Canon uses to alert you that there is a problem without specifics. I've gotten it on both my Canon bodies and each time I'd pull my battery and then replace it after a few moments and the problem resolved, but that is for me. I did notice that when I would get it my battery was usually getting flat. Once I cleaned the battery contacts on both bodies the error has not come back.
Some people have also gotten error 99 with a bad card, with a bad connection to a lens or grip but also to more serious problems, too.Your best bet is to take a pencil eraser and clean all your metal contacts (which you have already done) to see if it aleviates the problem. If you have more than one lens try changing lenses and see if you get it with all your lenses. Keep track of whether you get the error with all lenses or just one as it could be a lens that is causing the problem.
I notice that you removed the batteries. If you would try that again also pulling the card, but leave out for at least 20 minutes. This will give time for the capacitor to discharge all the electricity it's storing so that everything resets. Replace the battery only and test. If resolved then replace the card and test again.
Also clean your card and the slot compartment. You can do the card by wiping with a soft dry cloth and the compartment by using a card slot cleaner
If you are still getting an error it's time to have a repairman examine your camera body for further investigation.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Jul 01, 2011 | Cameras
I have an LG Optimus M. It says the SD card is not installed. I have 2 of them. I reformatted both and it's still saying that. My computer recognizes both SD cards but not my phone.
Hi Everyone,
I had the same problem, and fixed it by very gently bending the Micro SD pins up a little. See the picture below, remove battery first, get a very small screw driver or other implement and one at a time bend each of the 8 pins up slightly, you do not have to bend them much so be very careful. Make sure none of the pins are touching when finished. So the cause of the fault in my LG Optimus GT540 phone was the pins had flattened and were not contacting the contacts on the Micro SD Card well enough. Which is a bit of a design fault really because my original card stopped working because of this and ended up fried. I done the fix above when the new card I bought and checked that it worked on my computer, but when I put it in my phone would come up with the message SD Card removed.
Hope this helps!
Regards,
Peter
May 24, 2011 | LG GT540 Cell Phone
I have 1gb kingston microsd card not opened tell password now.plse tell me master password
I can help. What is not the problem, is the position of the switch entirely. With the SD card Face up and the tiny white plastic switch on the left side, should be slid toward the card edge connector (the shortest side). I know you may have done this and it still doesn't work. Here's why, On the opposite side of the SD card from the switch, there is a tiny "Notch" cut out.
Place a piece of tape, masking, electrical, sometimes transparent will work. Be very precise in placing the tape over the notch, but not over the brass connector on the opposite side. Then place it in your card reader, format it, read and write files to your desire.
This is a little known issue with the design of all SD cards. The notch forces them to work in camera's, MP3 Players, PDA's, etc. that are portable devices, but not in USB card readers or computers with SD reader slots.
The card reader with the SD card has this extra built in feature to protect copyrights (for some reason on blank cards), and makes it useless for custom applications. Once you have "Unprotected" the SD card, installed your files, then remove the tape.
If you get the same error again after applying the tape, add a second layer. Double check that you did not cover the connection edge, and the plastic tab is closet to the side you insert in the device you are using.
Sometimes it takes several tries, but it will work with patience. If you have existing files on the SD card, insert it, right click, select properties. Then remove the "Read Only" check by the box and try to delete or add files then. If it says Disk Write Protected, then check the tape again.
Dec 18, 2010 | Kingston 1GB Secure Digital Memory Card
Lens error, restart camera camera shuts off
Try one of these two fixes, if they dont work for you follow the link below for further troubleshooting.
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: If the camera's batteries ran down completely while the its lens was still open, the camera may show a lens error or not start properly when new batteries are installed. Remove the memory card and keep it removed, then install the new batteries. When you turn the camera on with the card removed it may come back to life, as this triggers a reset in some cameras. Error E30 (for older Canon's) means that you don't have a memory card installed, so turn it off, slip in the SD card and turn it on one last time
Aug 13, 2010 | Canon Cameras
Powers up but locks up on "detectin sd card" screen
A very common problem on the SkyFi3! Press the volume UP and the Power button at the same time and it will finally go off. Go to the Delphi/XM website and upload/download the latest FIRMWARE and upgrade it. Then, call the 800 phone number for Delphi and they will tell you a secret master reset you have to do once or twice, and it will cut down the number of lockups during checking media by quite a bit. Also, do not use a Micro SD card larger than 2MB as well. Good luck, and let me know how it goes for you.
Jul 29, 2010 | Delphi SKYFi3 XM Radio Receiver with Car...
Error message: "Lens error, restart camera" unable to get it to work Have powered on & off several times. Also removed batteries and powered on several times all to no avail.
There are 2 fixes I know for this you can try.
1. Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
2. If the camera's batteries ran down completely while the its lens was still open, the camera may show a lens error or not start properly when new batteries are installed. Remove the memory card and keep it removed, then install the new batteries. When you turn the camera on with the card removed it may come back to life, as this triggers a reset in some cameras. You don't have a memory card installed, so turn it off, slip in the sd card and turn it on one last time.
Jun 01, 2010 | Canon PowerShot A560 Digital Camera
When turing on my Canon SX100IS camera it opens the lense then closes and gives me an E24 error. I am able to replay phones on my SD Card but not take new pictures since the lense retracts
you get this error message E24 because your lens is slightly out of alignment. Cycling the camera on/off several times will serve to help the lens to work it's way back in alignment.
Even though your battery may be fully charged, as a Lithium Ion battery ages, it begins to lose capacity so you don't have enough power to take any still . Try a different battery.
Clean the battery contacts with a pencil eraser. Sometimes, a dirty battery contact can prevent the battery from providing all the current the camera needs.
Hope this helps.
Jan 24, 2010 | Canon PowerShot SX100 IS Digital Camera
Canon EOS 40D Digital SLR Camera Digital Camera with 17-85mm IS USM Lens Logo
135 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
