Question about Pioneer VSX520 Receiver
Have got sound through all devices plugged in however no picture. Using video cable (Yellow) and red/ white audio. Have got yellow plugged in monitor out....
    Guru:
  • 276 Answers
Your video source (cable box or Blu-ray or satellite box) has to be plugged into a proper video (yellow) input on the Pioneer A/V receiver and you must select on the TV, the video input where the yellow video cable is plugged in from the Pioneer A/V receiver (use TV remote). Also select on the Pioneer which source component you want like the cable box or whatever. Check cables for quality. Swap RCA video cables to see if cable is bad. Try new video cables. May need to adjust a user setting on the Pioneer A/V receiver. Make sure cable box or whatever is plugged into the yellow video input for that component you are selecting on the Pioneer.
Posted on Mar 27, 2011
I have the 3 RCA red, yellow, white cables on back of dvd and to tv. Video only plays when I select video 1 under the input. When when I select video 3 only sound and no video. What else can I try?
Sounds like from the symptoms that you have plugged the white and red cables into AV3 input on the back of the Teleivsion and plugged the yellow cable into AV1 on the back of the Television.
Check the cables are all plugged into AV1 input ports on the back of the Television. Red and White go into the Audio inputs and Yellow goes in the video input. Also make sure you have not plugged cables into component inputs on television look for AV1 in on back of Television .
Mar 08, 2015 | RCA Televison & Video
Plugging red to red, white to white, and yellow to SPDIF (black) and got no picture with sound. Plugging red to red, white to white, and yellow to green and got black and white picture with sound. How...
First you need a component cable to solve your problem.Since you have not mentioned what device you are connecting to your TV, I''ll assume its a DVD player or a settop box.There is a Red and White audio sockets + Red / Green / Blue component video socket. Just make sure you connect the corresponding two sets of jacks at both end of your TV & DVD player and everything will work. bobhifi_21.jpg
Mar 27, 2011 | Philips Televison & Video
When ever i plug in my video and audio cable the red white and yellow ones, into the back of my Toshiba 26CV100U TV i don't get the picture i only get the sound what should i do ?
The Red, White and Yellow (AV) cable is for composite video and stereo audio. The yellow cable is the video part of this, the red and white are the audio --
3 possible solutions for you:
1. Make sure you match up the color of the plugs with the sockets on your tv.
2. Make sure you're not using the Red, Green, Blue (RGB) input on your tv which uses similar plugs, but has a different color coding.
3. Make sure your tv input is set to the AV input. This is often controlled by the "TV/Video" button on your remote, and the AV input is often called "Video 2" or "3" depending on the model.
Feb 28, 2011 | Toshiba Televison & Video
Trying to connect ps2 to samsung syncmaster have connected the red and whie cables but all i get is a fuzzy black and white picture - do i need a different cable??
Is the cable you are using a set of Yellow, Red & White cables? If so do you have them plugged into the ports on the "side" of the Monitor? or are you trying to use the ports on the back?
It should be hooked up to the ports on the side.
Jan 05, 2011 | Samsung SyncMaster 940MG 19" LCD Monitor
Problem with eyeclops video projector...after
unplug all rca cables from your eyeclops, then try all three colors one at a time, into the yellow colored hole on the side of your eyeclops, until you get a picture, and you have to have the dvd player on and playing a dvd, otherwise the light won't come on your projector, then plug in the audio sources, the yellow and white. When I got my eyeclops mini projector, it wouldn't work at all when I plugged the yellow rca cable in the yellow hole on the side of the eyeclops, the red into the red, and the white into white. Only when I placed the red rca cable into the yellow hole on the eyeclops, the yellow into the red hole, and the white rca cable into the white hole did it finally work. That was for my dvd player. With the video game function, I plugged each color Rca cable into their same colored holes on the eyeclops and it worked fine, but again, you have to have your device, whether it be a dvd player or game system on and running before your eyeclops led lights will turn on. Not sure I had to switch colors when I played my dvd player, but that's how it works on my mini projector, anyways.
Jan 17, 2010 | JAKKS Pacific Eyeclops Bionic Eye Tv...
Splicing a monitor output wire from my laptop to
This cant be done.. You need a video card that has the yellow jack [video out]
the red and white jacks are your sound,
get a headphones to RCA adapter for the sound card[computer] going to projector or radio...[just need the RCA adapter to get sound]
But to get the video[yellow jack] to work you NEED a video card with a yellow jack inslled in your computer...or a video card that has a adapter for RCA video
I have a
Sep 30, 2009 | Toshiba Satellite A135-S4527 Notebook
How do i hook up a nintendo to my tv which cords go where and can someone walk me through it
Round peg into the round hole. Red peg on the red slot. etc. If the wire from the nintendo doesn't fit the slot on the tv then you're in the wrong slot. if the wire from the nintendo fits the slot on the tv (and is the same color if you are using red/white/yellow rca cables) then you're good. here's a hint on connection types (you will not mix): 1. RCA (red/white/yellow round connectors) Red=right audio sound White=left audio sound Yellow=video connect to the slots that look like they want some. 2. Coaxial (stiff cable with a pinner poking out of the end -- same cable that connects you to cable tv) just hook it up by itself; it carries audio and video. 3. Component (red/green/blue)(red/white) two 'bundles' red=red component of video green=green component of video blue=blue component of video red=right audio white=left audio 4. VGA + (red/white) VGA=video (computer monitor cable) red=right audio white=left audio 5. HDMI (flat hdmi cable. you spent $30 on this 3 foot ****) HDMI=audio and video 6. hugs and kisses hugs=video kisses=audio (both sides)
Jul 15, 2009 | Video Game Consoles & Games
Super nintendo set up-its configuration.
You should have two cables. One is going to be the power supply. The other is going to be a gray or black audio video cable. You will have three connectors on the cable, a yellow, a red, and a white. The yellow is your video signal and will plug into a yellow input on your TV, DVD, VCR, or whatever device your trying to plug it into. The red and white are your audio cables and they again will plug into whatever device your using for audio such as the TV or a surround sound system.
Mar 14, 2009 | Nintendo Video Game Consoles & Games
No sound
tcolson,
good day, make sure your RCA red and white marked cable connected to TV screen audio input where you also connect your yellow cable which is the video.
note: always remember color code of RCA cable
yellow = video
red and white = audio (left and right)
connection would always be:
video device yellow RCA socket = TV yellow "INPUT" socket
white and red RCA = TV white and red "INPUT "socket
make sure that all this 3 cable are connected together in a specific "A/V input"
cheers ,
mark
Jan 30, 2009 | Sansui VRDVD4001 DVD Player/VCR
Picture is fine, but the sound won't work
Are the yellow, red & white cables RCA phono plugs?
Yellow = Video
Red = Right Audio
White = Left Audio (mono)
The red, blue & green cables are for picture only and don't include sound. Have you tried using the red, blue & green for the picture and using the other cable, red & white for just the sound? Don't use the yellow.
- Jim
Feb 10, 2008 | Sanyo HT32744 32" TV
Pioneer VSX520 Receiver Logo
132 people viewed this question
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
Ian Summerfield
Ian Summerfield
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
