Question about Mitsubishi WS-65809 65" Rear Projection Television
My Mitsubishi 65809 will not turn on it is getting power my daughter said she thought it turned on for 4 sec
It sounds like there is a fuse blown in side. I had a similar result after I changed out the IC chips, There is a way to get the error code. Unplug the TV then plug it back in. Press and hold "Device" and "Menu" button at the same time. The power button will blink the error code. Mine was a 2 - 2 which meant it had a short. When I researched that it turned out my 5A Pico fuses where blown. I checked them and they where bad. I soldered in 2 new ones and it turned back on. In most cases if you have a 2 - 2 you will also need to replace the IC's. I got mine from http://www.tvrepairkits.com
Posted on Apr 01, 2011
I have a mitsubishi ws-65809. I relpaced the STK392-570 ICs and turned on the tv and it powered on for 2 secs and went off. I ran the test and got a 2 and 2 blink. Then ran test and got a 1 and 2 blin
If you unplugged the set you will get the 1,2 no error found, the 2,2 is short protection, I hope you had that before the chips were replaced, it is one or both of the pico fuses bad that protect those chips.
see photo of board, locations are 9FAo4 and o5 on the middle board where the chips are but further back.
12_15_2012_1_52_39_pm.jpg they are both five amp pico fuses.
Dec 15, 2012 | Mitsubishi WS-65809 65" Rear Projection...
Tv truns on then turns off
if model indicated do the self check it has:
On front of set when green light for power goes out press and hold both the menu and input (source) buttons at the same time for at least 5 seconds and release both buttons.
Power light will then blink a two digit error code like 2 blinks, 2 blinks a pause and repeat it for a total of 5 times.
If set has been unplugged you must plug it back and try to get set to turn on--unplugging clears the errors.
Let me know what error you find and I will tell you what it means.
Apr 28, 2012 | Mitsubishi WS-65809 65" Rear Projection...
Tv shuts self off after 30 sec
It says it is a Mitsubishi WS-65809--can you confirm that?
Mar 28, 2012 | Mitsubishi WS-65809 65" Rear Projection...
Mitsubishi WS 65809 65" Rear Projection TV. Turns
Hello There, Its seems that the circuit board has problems. You'll have to get it replaced ASAP before the board is ruined completely.
The same thing also happened to me 2-3 weeks ago. the techs came in and had to replace the board since 1 circuit was damaged.
It will cost around $100
p.p1 {margin: 0.0px 0.0px 0.0px 0.0px; font: 13.0px Arial}
Thank you for using FixYa!
I hope that I helped you & that this post is helpful to you at most!
Don't forget to rate! :)
Jan 16, 2011 | Mitsubishi WS-65809 65" Rear Projection...
Tv wont turn on its a mitsubishi wide screen model number WS-65809. also forgot password for parental locks so when it is on cant watch anything but Disney, and Nickalodian!!!
I can help you unlock your Mitsubishi HDTV V-Chip at least, for when you get it back on.
Please follow these steps to bypass the vchip or reset the V Chip password.
I hope that helps.
_______________________________________________
Reset Mitsubishi HDTV VChip Password
Bypass Mitsubishi HDTV Front Panel Lock
Mar 13, 2010 | Mitsubishi WS-65809 65" Rear Projection...
Ws65909 powers off about 3 sec after power on
a code will always read 12-normal if you just plugged the tv in. it has to try to turn on then shut itself down to log a code. Or shutdown is caused by something the tv cannot detect . Or a front panel button has failed- does the green light turn on for a second when you hit the power button on the remote? if not try unplugging the front keypad behind the speaker cover.
Oct 06, 2009 | Mitsubishi WS-65809 65" Rear Projection...
Tv will not turn on manually or with remote
you need to get the stk chips replaced. i had it done with mine, it cost me 411 dollars for a tech to come do it. it worked fine for about 4 months now, and my red color is gone. mitsubishi sucks, sorry : (
Sep 25, 2008 | Mitsubishi WS-65809 65" Rear Projection...
Mitsubishi WS-65809 65" Rear Projection Television Logo
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
