My father died 11 years ago and he bought a Glo-Warm Vented heater for propane gas only. It has never been used as we found it still in its box in an old attack. Can I use this to our natural gas system? Can I get a propane to natural gas converter for this model?
  • Heating & Co... Master
  • 3,328 Answers
Check on line google make modle serial number btus etc and ask for nat gas converstion kit , age could be the problem here ,or try national energy they are on line or google the makes and ask them direct
Posted on Mar 27, 2011
I have a dyna glo RMC 40 NGT vent less wall heater that I would like to convert to propane, I need to know which conversion kit to buy, and where. Thank you.
dyna glo natural gas heater Questions & Answers - Fixya
www.fixya.com > Forum > Tags
dyna glo ventless rmc50 ngt can this heater be changed from natural gas to propaneuse, ... Dyna Glo Natural Gas conversion to LP Gas I have a Dyna-Glo natural gas space ... Question about D-E36 Infra-Red Wall Mounted Panel Heater ... dyna glo heater model #RMC-40GT I believe on your particular model , that you ...
Parts for Dyna Glo, Thermoheat and Dyna Glo Pro Heaters
spaceheaterparts.com/category.sc?categoryId=13
Shop Dyna Glo, Thermoheat, Dura Heat, Workhorse LP and oil fired htrs ... Circuit Board 2201181 Dyna Glo & Thermoheat 150k Nat Gas Htr RMC-FA150NGDGD ... This spark plug (ignitor) is used on Dyna Glo and Thermoheat 40K btu LP.
Propane Wall Heaters - Walmart.com
www.walmart.com > ... > Heaters
WalmartDyna-Glo IR18NMDG-1 18,000 BTU Natural Gas - Infrared Vent Free Wall Heater. $170. ... Dyna-Glo 40K Liquid Propane 360-Degree Tank Top Heater. $88.00 ... Dyna-Glo Deluxe RMC-FA125DGD Portable Gas Powered Forced Air Heater.
1352062 Dyna Glo Natural Gas conversion to LP Gas
162.220.53.34/F/.../t1352062-dyna_glo_natural_gas_conversion_lp_gas
Jan 12, 2016 | Heating & Cooling
Can I change nature gas jet to propane
If you know what you are doing, yes.
Dec 11, 2014 | Heating & Cooling
Internal 1/2 psi propane regulator is not passing gas thru so that heater wont light. Are there recalls? Where can I buy a replacement part? Heater is 2 years old, never lit.
What's the pressure to the heater? It should be a minimum of 11 to 13 water column inches. Also, make sure that your heater is in fact a propane fueled heater. Don't go by whats on the box it came in. Look at the manufacturer's tag(s) on the heater. It may be a Natural Gas unit instead of Propane unit. I've seen this happen before. In which case it won't work and can not be converted.
Feb 02, 2011 | Dyna-Glo D-E37 Wall Mounted Panel Heater
Ihave a dyno glo heater rmc-lc20ngt nateral gas can it be converted to propane
You didn't specify whether it's a vented or vent-free heater. I suspect it's Vent-free. In which case NO!
Doing so would override any of the safety features that are built-in to shut it down if something goes wrong.
Jan 19, 2011 | Heating & Cooling
I had purchased this unit RMO-80LPT heater several years back, I never installed unitl this week. the sales en at the time told me it was gas/propane. Now seeing the -80LPT on the side is it propane...
The orifices for a propane heater are much smaller so you will not be able to get the natural gas to flow properly with the current orifices.
The both the natural gas and propane valve are 1/2 psi so the valve can be used but the regulator for propane is typically 8-11 inches on the wc table and the natural gas is typically 3 lbs on the wc.
You may be able to drill out the orifices in the burner and in the pilot ods and get the unit to work.
Oct 13, 2010 | Dyna-Glo D-E37 Wall Mounted Panel Heater
Glo Warm Self Venting Heater Model FB3B Emits strong odor
The propane may have a higher sulfur content; however, the odor may go away soon. It is probably caused by the dust and oxidation (micro-rust) that attached itself to every part of the heater while in storage, even though it was "sealed".
Sep 29, 2009 | Dyna-Glo D-E36 Infra-Red Wall Mounted...
Need to convert to LP from Natural Gas
i do not think any propane type heater may be unvented but check with manufactorer
Apr 16, 2009 | Heating & Cooling
Glo Warm propane heater won't light
There is really not a lot to go wrong with the heater itself so my first guess would be that the regulator is bad, not letting the proper amount of gas through. You can check it for leaks with a bottlee of soapy water but even if you don't see a leak there is a rubber gasket inside with a pressure spring that is probably bad.
Feb 04, 2009 | Desa International GWP20T GLOWARM Wall...
My glo-warm propane heater keeps shutting off automatically-pilot and all.
my heater says if the pilot light keeps going off automatically it is a safety function that means it does not have enough fresh air to operate
Nov 03, 2008 | Desa International Blower Glow Warm Wall...
Heating & Cooling Logo
119 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
Marvin
Marvin
