Question about HP Photosmart C6180 All-In-One InkJet Printer
Leaking Black Colour
I Have D6168 I dont know from the last night it started leaking from printer, black colour, before that it was not pulling the black colour suddenly the black colour started leaking i doubt wether the inside piple line is damaged or pluged out of my cartridge nozzel where can i find the service manual
    Guru:
  • 1,049 Answers
REPLACE THE PRINTER AND SAVE YOURSELF A HUGE MESS
Understand when I suggest replacing the printer, it isn't that you can't fix it or that I'm not answering your question. But to do so will require cleaning every inch of the internal components. The ink will stain everything it touches and you'll need a smock, a work area, and probably gloves.
See what happens is that where the print head parks there is an ink absorber and below it is an ink well. The ink absorber is a sponge like arm that cleans off the cartridge and the well catches the loose ink. Inkjet printers are for the most part not designed to last past a few years, so few printers have a method for emptying these. When they become full the printer will start leaking ink in torrents but will continue to function normally for quite a while until it fills every nook and cranny of the printer. While all you notice is a sightly higher consumption of ink.
By the time you start visibly seeing the ink come out of the printer, the inside is a huge mess, and when I say huge I mean without cursing, words just can't express how nasty and ink smeared it is.
Posted on Aug 06, 2008
My cyan colour is finished, i have to print a black colour documents, printer is not allowing to print, please help
switch to black and white on the printer settings.make sure ignore colour warnings are turned off
if that doesnt work youll need to replace the cyan,get it refilled for less or order online to reduce cost
Mar 07, 2011 | Epson Office Equipment & Supplies
Alignment problem. just refilled black ink cartridge..seeing message that printer is not aligned and remove tape from cartridge, but i see no tape
1) remove the cartridge and check it is not leaking. If it is, the printhead area on cart will be flooded with ink. Removing couple of ml from cart will stop it leaking.
2) If the cart looks clean (not leaking), stamp the printhead on some folded tissue paper or paper towell. It should leave a solid black stripe about 10mm long on the tissue. If it doesn't, your refill ink hasn't quite reached the printhead. You can blow little air into the breather hole (on top) to prime the printhead. Stop blowing when ink starts leaking at the printhead.
Clean the cartridge up before installing it.
3) If all above is ok and it still doesn't align properly, repeat above steps with the colour cartridge. The printer needs all colours working to perform the alignment process.
good luck with it
LC1000
www.inkbank.com.au
Dec 10, 2010 | Lexmark X7350 All-In-One Printer
Hardly print in colour but run out of colour ink really quickly.
Really if you know you don't print in colour you can just decide to remove the colour ink from the printer and observe to know if it empties after a while which might mean that it was getting dried up somehow.
Do get back to me over this after you might have tried it out.
Good luck and thanks for using Fixya.
Apr 16, 2010 | Canon PIXMA MP160 All-In-One InkJet...
Lines in photo
Hi
This could be either a leak from colour cartridge or could be because there is still some blue ink in the printer from the last colour item printed?
Apr 10, 2010 | HP PhotoSmart C4280 Laser Printer
How do you change the ink from black to color i dont wont it to print black but i dont know how to change it
first go start menu,then click settings click printer and faxes.
second go to you default printer right click printer preferences.then go to
find out ink colour or black you will see on have a sample small image inside when you choice print out with colour or black their image will automatic change for you.
try this because i no sure with brand and model printer you have....
Aug 15, 2009 | Lexmark C533DN InkJet Printer
Can ip1300 print with just black ink cartridge?
AS far as I know you cannot put a black cartridge in the place of a colour cartridge it has to be a colour one. Check your printer properties to see if you can set your printer to work in black only, if you can then set it to black but leave the empty colour cartridge in place. This works for my 1800. Give it a try.
Aug 05, 2009 | Canon PIXMA iP1300 Printer
Black and white only
Well - it's fixed - but no thanks to anything I did.  It's just all of a sudden working fine again.  I tried three different dvd's the other night, and all were black and white.  But last night the same dvd's were back to colour.  Who knows?
But thanks for asking.
Dec 27, 2008 | Sony SLV-D300P DVD Player/VCR
Canon Printer Picms MP450 Error 6500
They don't like re used cartridges.
I would purchase a new printer as they are not economic to repair.
Feb 27, 2017 | Canon Pixma MP450 All-In-One InkJet...
I cannot print but i have only the black cartridge but i dont have the yellow cyan ang midget
Most modern printers use some colour when printing Black and therefore will not print if ANY ink cartridge is showing as empty.
Unless your printer has a setting for using Black ink only (this is not the same as printing a black and white document), then you will need to purchase and install the colour cartridges before printing can take place. The good thing about this is that very little colour ink is used when printing black and white documents - so they should last a long time.
Good luck.
May 09, 2008 | Brother Multi-Function Center MFC-240C...
Colour problems
the same for me with black ink .....
Thanks
Phil
Dec 18, 2007 | HP Photosmart 2610 All-In-One InkJet...
HP Photosmart C6180 All-In-One InkJet Printer Logo
481 people viewed this question
Ben Johnson
