Question about Canon PowerShot A720 IS Digital Camera
I changed the batteries in my Power Shot A720 IS recently when the low battery warning flashed, and had taken only two photos when the warning flashed again. I moved the mode switch to playback and the screen went dark "Change batteries now" appeared. I turned off the camera, set the mode switch to shooting, turned the camera back on and was able to take two more photos before the low battery warning returned and prevented any more picture taking. I purchased and installed new batteries and faced the same problems
  • flybroom
    flybroom Jan 16, 2012
    This worked for me:http://www.epinions.com/review/Canon_Pow... I used some foil and folded it to a tight little package and stuffed it underneath the battery connections.
  • 67 Answers
Hi, 1st you must use alkline bat or minimum 800 mhp bat....
and if problem is not solved then cheak the bat cap and connection clean with aomthing,,,,
If any thing else contact me
Khatricamera@gmail.com
Posted on Mar 27, 2011
  • C Dunn Nov 12, 2013
    Same problem. Camera wont power up long enough to open lens. Cleaned, have fresh batteries.
My A720 is takes blurry photo only around edges
1st
Is there any dirt on the lens? make sure it is clean. if this is not the issue you will need to open the camera and make sure it is clean on the inside as well (I DO NOT reccomend to do this alone)
2nd
make sure to use rechargeable batteries ONLY
I reccomend using ENELOOP (by sanyo) or FUJITSU
make sure the batteries are made in Japan!!
Oct 01, 2014 | Canon PowerShot A720 IS Digital Camera
I have a Canon Power Shot A720. Outdoor photos are beautiful. Indoor photos are always grainy/blurry...a lot of noise. I have tried the ISP feature but there are only two choices... 1. Auto or 2....
Hi Usually outdoor picture are good within small compact camera. They designed like that. But now your unit just have flash pcb defective. When flash function work, your picture will be good indoor. Regarding your flash unit would be brown fuse or replacement of flash unit. It is 50 and 50 chance. Your local repair shop would charge around $35 to 95 depend on what they really want to charge. Thanks and best regard!
May 24, 2011 | Canon PowerShot A720 IS Digital Camera
I have a canon power shot A495 digital camera. problem with camera is new or fully charged batteries discharges after taking 4 to 5 photos when taken with flash
all the canon cameras batteries do not last more than 2 years.
the best would be to purchase a new battery which you can find at any Target, OfficeMax of a sort department stores.
Oct 11, 2010 | Canon PowerShot A495 Digital Camera
Wont take pictures with flash
The problem is in the battery holder of the CR1220 battery.
-Take out the CR1220 battery (the little round one).
-When you replace it, put a bit of aluminum foil against the back, between the battery and the plastic holder, to make it a nice tight fit. One layer won't do it, but don't put in half the roll.
-Put it back in. Done
Using a fresh battery & clean it all with alcohol = good idea as well. Worked for me.
Wich
Apr 24, 2009 | Canon PowerShot A720 IS Digital Camera
I get a warning which says *Battery Exhausted*. I've replaced them but still get the warning.. Any idea whats wrong?
earlier i posted solution in similary problem. maybe help you this.
solution is good batteries, Ni-Mh or Lithium, rechargeable only not alkaline. but...problem is how long you watch pictures on lcd display or how much is flash in use. if always by shooting pics used flash that means that you can with best batteries 30, 20 or less pics shooted. and of course, if you connect camera with pc, how long is cam on? just transfer pics on pc and turn the camera off. the best solution is use the card reader for pics transfering.
if is flash off, it's possible to shot 120-150 pics with Ni-Mh. with lithium i don't know, maybe 500 pics. don't use camera lcd for analysing pics it's just there for short preview.
with alkaline batt., very low quality, i shot 30 pics without flash.
i shot also very good pics at night without flash. nikon coolpix L15 can do that but you must have more praxis. alkaline batteries shooting!
after 3 pictures on display is message: warning! the battery is exhausted. what you can do? turn the camera off. wait about 10 minutes. turn the camera on, you can shot 3 or 5 pictures and than turn your camera off again.
you can repeat this few times and you be lucky if you 30 pics captured:)
REMEMBER: all this goes without camera flash!!!
flash and every zooming use more battery power! and that was all magic:).
Mar 22, 2009 | Nikon Coolpix L15 Digital Camera
Canon A720IS flash problem/low battery indicator
cudgegong said in another forum:
To resolve the annoying "change the batteries" problem. Goto menu, choose yellow menu, select
file No. reset to ON. Turn camera off and back on.
Voila fixed.
Mar 13, 2009 | Canon PowerShot A720 IS Digital Camera
Power key doesn´t work
There must be a problem with your batteries. If you have recently charged your batteries and it happens again, you should try a new set of rechargeable batteries.
You can try conserving charging power usage on camera by turning the flash off so that it doesn't precharge for the next shot.
Jun 04, 2008 | Samsung Digimax i6 PMP Digital Camera
Menu and display buttons do not function
One quick question. Is the camera taking photos?? when you try to transfer the photos to computer , are the photos fine or there are some Black photos??
Regard's
Manoj Goyal, INDIA
+91-9214988557
Dec 03, 2007 | Sony Cyber-shot DSC-N1 Digital Camera
Battery life
Are you keeping the large LCD screen on all the time? If so, that will dramatically reduce battery life. Same goes for flash use (although for 8 shots shouldn't be a factor) and constant stabilization. Also, by low battery do you mean that the camera is turning itself off and can't be turned back on? If just the icon is showing low battery life, it could be that the sensor wrong. I have an MP3 player that will say it has zero battery power, but will really play for another two hours. You should be able to take many more than 8 shots with one battery. I've taken 500 photos over a period of nine days on one battery with my FZ10. Viewfinder only, stabilization only when shooting, no flash use.
Sep 06, 2005 | Panasonic Lumix DMC-FZ15 Digital Camera
Canon PowerShot A720 IS Digital Camera Logo
956 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
