Question about Ovens
Install a baroness integra wall oven
How to install a chef baroness integra wall oven
  • l16164 Aug 04, 2008
    instructions on installing a chef baroness integra wall oven
I have just brought a house and the oven is a baroness integra gas fan oven - i get the thing ignited as can see the flames but when i gently release the nosel the flames go and there is no heat. it is a little warm but i think that's just from the lamp. Any help would be great - i miss baking!:-(
Posted on May 04, 2010
My Chef Classic Wall mounted fan forced oven stopped working. Its grill section working. Fan and the light in the oven working well. Bot oven doesnot heat up. Please give a tip what is probably wrong?
The bake element has gone bad. They can visually look fine but still be bad. To check and replace that element you will unfortunately need to kill the power and remove it from the wall. Remove the back cover. Check for a low resistance (around 16 ohms) across the bake element. If the resistance is high the element is bad. Google the make and model for a replacement element.
Dec 26, 2014 | Magic Chef Ovens
I have a magic chef electric wall oven and it flashes an error code of F3 when I try to bake something. How do I fix it and what does it mean?
The F3 code means that the temperature sensor in the oven is not giving the signal to the oven control. This could be the result of a problem with the wiring or the wire harness between the control board and the sensor or indicate that the sensor itself has failed.
To identify the correct parts, you need to provide your oven model number. Try here: http://www.partselect.com/Magic-Chef-Parts.htm . There are other sources for parts.
I hope this helps. If you add a comment with the model number, I'll be glad to give you more specific information for your wall oven.
Sep 25, 2011 | Magic Chef Ovens
I need a user manual for a chef coronet integra gas oven.
If unsuccessful searching the web for PDF files for your appliance, then contact the manufacturers . There will be contact details on the web for that company, they will usually send you the manual free of charge.
Jul 11, 2011 | Ovens
Baroness integra plus wall oven oven not heating when fan on
a lot of ovens have 3 elements in them...one up top, one under the base and one in the fan compartment...i would say your element has burnt out in the fan comp.
Jul 24, 2010 | Ovens
Need serial number for my electric coronet integra wall oven
ther should be 4 screws holding the wall oven in you need to take them out and puul the oven out just alittle and look on the sides,be carefull not to far out
Sep 01, 2009 | Ovens
No power to the oven
i have same problem, please help!
Aug 26, 2009 | Maytag CWE4800A Electric Single Oven
Chef classic wall oven with digital clock change time?
Press the TIMER button (the leftmost one with a little bell icon) and the "cooking" button (the one next to it with a "hot saucepan" icon) briefly at the same time. Within four seconds start changing the time with the + or - buttons. When you have the correct time just leave it and it will leave time setting mode four seconds after the last button press.
Apr 12, 2009 | Ovens
Chef Coronet Integra oven - no manual
Problem not solved, so I will just have to bumble on! Cannot afford the premium plan, but thanks - I have you on my list should something else happen! Thanks Gabrielle.
Mar 20, 2009 | Ovens
Ovens Logo
2,093 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
