Question about Sharp Heating & Cooling
I moved my air conditioning unit and water poured out of it. is that normal? and how long /should I wait before plugging it up again
  • 576 Answers
This is fairly normal. What happened is that the unit was not in the window correctly and/or the drain hole(s) is(are) blocked. When the unit is installed, it should be tilted slightly away from the house. If it isn't shim it so it is. also, there should be holes on the bottom of it for the water to drain out. make sure they are not blocked. You do not have to wait to plug it in unless you had it turned in a direction other than right side up for a period of time.
Posted on Mar 27, 2011
We've had a Cuisinart DCC-2000 coffee maker for less than a year: 1) it stops brewing about halfway through the brewing cycle (with plenty of water still in the reservoir, and 2) the "Clean" light
This problem is caused by a clogged water filter in the unit.
Unplug the coffee maker.
Open the top panel where you normally pour in the water and set the coffee filter.
Gently pull up on the tap that sticks up in the back left corner of the open top. This will free a long plastic part that has a compartment at the bottom that contains a filter filled with charcoal.
Unsnap the small compartment that holds the filter and clean it gently under running water with light brushing.
If there is a lot of coffee build-up, the water chamber where you normally pour in fresh water needs to be cleaned out. Pour in a cup of water and invert the unit over a large sink pouring out the water through the opening you normally use to fill the unit.
Repeat this until you remove the coffee grounds.
Let the unit dry fully before plugging in to run again.
Sep 30, 2012 | Cuisinart DCC-1200 Coffee Maker
NanoMax Portable Air Conditioner does not drain and unit's red light continues to come on with unit cutting off in a matter of minutes. Unit is less than 3 years old. Purchased from HSN or QVC, which...
There is a drain plug for the water on the rear lower back of your unit. You have to pull that plug out and it should drain the water out. The water is from condensation of the air you are conditioning. Probrably in the lower middle portion. Unscrew the cap and pull on the black plug. If it is plugged you need to take a small hanger and gingerly move it back and forth in the drain opening until the accumulated water drains.
Aug 02, 2011 | Amcor Heating & Cooling
If a washer not used for a few years would that cause any problems
Hi and welcome to FixYa, I am Kelly
The seals do have a tendancy to harden / dry out or... corrosion prevents the unloader bypass valve from moving / operating properly. I recommend you put a little oil (2 oz maybe...) through the unit on purpose via the inlet water connection. Then connect your water hose and force the oil though the unit with the air in the water supply hose while it purges. DO NOT turn the unit on until your sure the water supply hose has purged out all air. Then turn on the unit making sure that you cycle the wand trigger rapidly for a few minutes by cycling the trigger until the high pressure hose is not so rigid then let the high presure hose charge fully again. Cycle trigger wait, cycle trigger wait. 1 second bursts until you get full pressure. Then use normally. This usually wakes up pressure washers that have been resting :)
Thanks for choosing FixYa,
Kelly
Apr 18, 2011 | Karcher Garden
SANYO SPLIT TYPE AIR CONDITIONER LEAKING
The leakage is probably from condensation and there should be some sort of drain for it. You should check to see if it is clogged or partially clogged. Also since you say it does it when it hasn't operated for a while you may want to check out where the lines pass through the wall and make sure that it is sealed up there so you don't get leakage from out side.
May 04, 2010 | Sanyo Split System Air Conditioner
Freezer drain is plugged. How do I unplug it?
shut off unit. find drain hole. pour HOT(boiling hot) water about a cup. wait so it will melt the ice. now either use a air from air compressor, or a portable steamer to run air thru the hole, also can use a long flex bar(like cloths hanger) or a flex pvc hose.
U also have to make sure your condensor coil is clean. dust at bottom of the fridge usuallu cloggs the drain as it normally drains to the boottom tray located beneath the fridge.
Oct 31, 2009 | Refrigerators
Keeps tripping circuit breakers bunn NHb
Hello
Coffee makers have a heating unit in them which draw a lot of current. If it is on the same circuit as refrigerator, toaster and other it will trip the breaker. Also, some breakers are more sensitive than others. Have an electrician run a separate circuit for the coffee maker outlet. Try running it in the dining room outlet, which I hope is separate from the kitchen outlets. Is the house old? Older homes have a lot of mixed up wiring.
John
Aug 09, 2009 | Bunn NHB Coffee Maker
No manual with Bunn NHBX coffee maker.
before plugging in place your empty filter basket in the coffee maker and place a pot under it. Slowly pour in two pots of water using the pour pitcher. Now you can plug it in. it'll take 15 min to heat up first time . when you brew your first pot leave your water level a little short,because the water will expand (only the first time)
May 06, 2009 | Bunn NHBX-B Contemporary 10-Cup Home...
How does it work?
Most units of this type make steam by heating water that is placed in a canister. Other than the place you attach the "hose", there should be only one other place on the body of the unit that opens up... that's most probably where the water goes in. Put water into a measuring cup, graduated cylinder, filling to known point. Then pour water into unit until 1/2" below fill hole. Note on measuring cup how much you used. This is the unit's capacity. Put "lid" or "cap" back on, plug unit into wall and wait a little while. Voila! Steam.
Mar 23, 2009 | Tristar SB Steam Buggy Vacuum
Leaking water under frig and ice-maker is not hooked up?
The problem you are experiencing is normally a blocked evaporator drain line. Whether you have a side by side model or a top mount freezer the solution is relatively the same. Most top mount freezer models have a rear evaporator panel covering the aluminum evaporator coils. There are some instances where the evaporator coils are on the floor. These instructions are for top mount freezers where the rear freezer panel covers the evaporator coils. First of all, if there is an ice maker in your unit, this will have to be removed. Normally there are two screws which can be loosened and the body of the ice maker can be lifted off the screws leaving only a plug in harness to disconnect. Remove the harness either from the plug at the left wall or rear of the freezer and set it to the side. Next, remove all the screws securing the rear panel. Remove the rear panel exposing the aluminum evaporator coils. Be careful not to damage these coils as they contain the freon that cools your refrigerator. If you look closely underneath these coils, there will be ice from frozen defrosted water. Using a hair dryer and not a heat gun, melt all the ice and sop up the water with a towel. Now you will see a drain hole which is normally still blocked with ice. Pour hot water in this hole and sop it up. Keep doing this until you pour water down the hole and it drains into the evaporator drain pan either under or behind your refrigerator. Once you have unblocked this drain line, reassemble and plug the refrigerator back in. Set all controls to the middle settings and within 24 hours, your unit will be functioning correctly once again. If you need further assistance, we are here. Eric Campion
Feb 20, 2009 | Jenn-Air JFC2089H Bottom Freezer French...
Heating & Cooling Logo
89 people viewed this question
Top Sharp Heating & Cooling Experts
Oloyede Monsuru
AJMAL KHAN
Tim Whalen
Are you a Sharp Heating and Cooling Expert? Answer questions, earn points and help others
