I recently installed a series of drivers for my Vaio VGN-TZ17GN running XP and while all others work fine, the video driver has reset the display resolution from the original 1366x768 to 1024x768 and cannot be changed back via control panel, only to a smaller 800x600 setting. How can I change it back to the original resolution, and will it require a new video driver?
    Problem Solver:
  • 10 Answers
If you're using the newest driver, it should support the physical display's maximum resolution. If your old display driver worked fine, roll back to it. If you can't, then you need to contact Sony to find out where to get the proper driver.
Posted on Mar 27, 2011
After xp installation my sony vaio vgn-sz2xp display did not appearfully.black spaces are appeared on the both side of the screen......... kindly help me its too urjent
I would guess that the video driver has not been installed? If it has, try changing the display resolution to see if it will fill the screen.
You can obtain driver software for this machine at the following URL:
http://support.vaio.sony.eu/computing/vaio/downloads/preinstalled/index.aspx?l=en_GB&m=VGN-SZ2XP_C
Jul 22, 2011 | Sony VAIO® VGN-SZ2XP PC Notebook
I installed windows 7 to my vaio tz17gn, and now the function key and camera dont work.any solution?thanks
Maybe you can go to the Sony support site
http://esupport.sony.com/US/perl/swu-list.pl?mdl=VGNTZ170NN&SelectOS=42
Select your operating system and download files under the CAMERA section. Install the correct driver and give it a try...
May 24, 2011 | Sony VAIO VGN-TZ170N/N Notebook
I have sony viao notebook model vgn tz17gn and installed xp the screen resolution is small and i adjust in display but it is same any help pls
Hi, you simply need to download the drivers for the graphic card, go to control panel and click on system/click on hardware tap/click on device manager, you will have an explorer like tree click on display adapters most likely will be highlighted in yellow in your case make sure you have all the drivers for other things as well it is a time consuming process but essential, you can find the right drivers buy accessing sony's website, if you can not find your model in your own region(sony has a regional website) try searching other regions since many models manage to make their way to other regions. I hope this works for you best of luck
May 24, 2011 | Sony VAIO VGN-NR360E/S Notebook
FN keys don't work on Sony VAIO VGN-SZ18GP
The solution is as follows, which worked for me:
- Install Windows 7
- let it update all the drivers that it needs to
- Install additional Sony drivers that you need (XP drivers work just fine, but make sure to install them in Administrator mode, so, Run as Administrator), such as camera, fingerprint scanner, etc
- Install the Notebook Control Device Driver (without this the other software does nothing)
- Sony Utilities DLL
- Sony Shared Library
* restart computer *
- Sony Video Shared Library
- SUS (Setting Utility Series)
- VES (VAIO Event Service)
After this one the Fn keys will start to work. The S1 and S2 keys don't work due to something to do with UAC (but I don't need them anyway)
- VAIO Control Centre (will allow you to change what the S1 and S2 keys do, even though you can't use them :) )
That's it and it worked for me.
Apr 18, 2009 | Sony Computers & Internet
SATA DRIVER SONY VAIO VGN CS23G_W
Drivers for the VAIO can be found here:
http://esupport.sony.com/US/perl/select-system.pl?DIRECTOR=DRIVER
  1. Under option 2 select Computers - Notebook
  2. Click Continue
  3. Either use Option 1 to auto detect your laptop or use option 3 and select the series (VGN-CS)
  4. For model find the full model number
  5. Click Continue
The next screen will have all the relevant drivers for your laptop.
Mar 13, 2009 | Sony VAIO VGN-CS215J/W Notebook
Xp sound driver for sony vaio vgn-n32oe
Check this out "XP audio/sound driver for sony vaio vgn-n320e"
Uninstall your previous installation and install this audio/sound driver.
http://esupport.sony.com/US/perl/swu-download.pl?mdl=VGNN320E&upd_id=3507&os_id=7
Feb 10, 2009 | Sony VAIO VGN-N320E Notebook
No sound devices on my sony vaio VGN-CR322H laptop
Pl check the whether all driver from OEM have been installed including MB and try to reinstall the driver it should work fine. or reinstall the SP2 for win XP. then install the OEM driver again, this should work, else there might be hardware problem.
Aug 20, 2008 | Sony VAIO PCV-J200 PC Desktop
VAIO laptop VGN-FE865E drivers for XP Windows
Mar 07, 2008 | Acer Aspire 5610-4648 Notebook
Sony vaio motion eye
Windows Vista is not the greatest at working on proprietary machines with drivers intended for XP. Can you get a driver from SONY for the motion eye that supports VISTA? I had Vista on my new machine (Dell) for all of 3 minutes before I uninstalled it and put a brand new copy of XP on. It's stable -- and works. Vista is squirrelly.
Jan 07, 2008 | Sony VAIO VGN-FJ270/B Notebook
Drivers required for ATI mobility radeon X2300 video card
I have Sony Vaio VGN-CR26GN/B Laptop.I have Intel processor and ATI Mobility Radeon X2300 graphic card.I need NEW UPDATED drivers for ATI Mobility Radeon X2300 Graphic card.OLD Drivers are causing performance issues.There are no new drivers for ATI MOBILITY RADEON X2300 graphic card on ATI.com and AMD website and other websites.I have searched the web but the result is nothing.I have also searched Sony website for drivers but they have not updated for a longtime.Please PLEASE Give me the link for NEW Updated drivers for this Graphic card Model:ATI Mobility Radeon X2300 on my email.ThankYou
Jan 03, 2008 | ATI Mobility RADEON Graphic Card
Computers & Internet Logo
46 people viewed this question
Alun Cox
David Payne
David Payne
