Centrex Washing Machine CTW60518; Where to obtain parts.. required is a new black (concertina) hose, approx 190mm, connects tub outlet to inpeller housing(outlet hose. Thanks ALbert
3 Suggested Answers
  • 69 Answers
SOURCE: i have a centrex ctw60518 6kg and i need to
Sorry, but as far as I know, there are no parts available for Centrex appliances. Centrex are cheap Target brand machines, and if they fail under warranty, they replace the machine. Out of warranty, you're out of luck. I'm a tech in NSW, and have not been able to source any parts here at all. One thing you could consider is calling the Fair Trading Office, as it is reasonable to assume you will be able to get parts for a washing machine less than 10 years old- they may be able to advise you further. Also, try going to the retailer you purchased machine from, and ask if they have a supplier of spare parts. Good luck!! PS. you could also try taking hose into your local appliance repair shop, and see if they have a hose off something else that might fit- a lot of hoses are similar.
Posted on Mar 17, 2010
Testimonial: "Thanks for your advise i'll look in to it as soon as i can demps57"
SOURCE: looking for a lid for a centrex washing machine
We have a Centrex Washing Machine, Model No. CTW 60518 Top Loader, which has recently broken-down. It leaks and not emptying completely on the spin cycle. We are unable to have repaired due to parts unavailable. If anyone would like this machine for parts kindly phone (07) 4936 4185 (Queensland -The machine has not been flood affected).
Vicki
Posted on Jan 17, 2011
Ned a new drainage hosed for a centrex twin tub washing machine. Any help?
yes go to the manufactures website and request the spares department for the part from them eric
Jan 01, 2018 | Washing Machines
Leak in front
see this steps and fix it. God bless you
Drain Pump
If the washer is leaking water the drain pump might have a hole or crack. Or, the bearings might be worn out. Replace the drain pump if it is leaking water, they're not repairable.
Enter your model number to see parts for your washing machine.
Help me find my model number
Tub Seal and Bearing Kit
If the washer is leaking water the tub seal and bearing might have a tear or rip and is letting water leak past. The tub seal and bearing can be replaced. This is common and relatively easy to replace.
Tub Seal Kit
If the washer is leaking water the tub seal might have a tear or rip and is letting water leak past. The tub seal can be replaced. The tub bearing often gets damaged when the seal leaks. consider replacing the tub bearing along with the tub seal.
Tub Spin Seal
If the washer is leaking water the tub spin seal might have a tear or rip and is letting water leak past. The tub spin seal can be replaced. This is common and relatively easy to replace.
Tub Seal
If the washer is leaking water the tub seal might have a tear or rip and is letting water leak past. The tub seal can be replaced. When the tub seal fails water gets into the tub bearings and usually causes the bearings to go bad also. It is a good idea to replace the tub bearings with the new tub seal.
Door Boot Seal
If the washer is leaking water the front door boot seal might have a tear or rip and is letting water leak past. The boot seal can be replaced. This part can tear when the washer is overloaded. This is common repair.
Tub to Pump Hose
If the washer is leaking water the hose from the tub to the pump might be split or torn. Don't try to cut off the bad piece of hose and stretch it to fit the pump, this will put strain on the remainder of the hose and may cause a sudden and complete failure of the hose which will dump potentially hundreds or thousands of gallons of water onto the floor because the next time the washer tries to fill all of the water will end up on the floor and so the washer will never shut off the valve. Any time there is a damaged hose, replace it completely with the OEM part.
Washing Machine Fill Hose
If the washer is leaking water, check the fill hoses on the back of the washer, this is the most common place for water to leak. If the washer still has the original black rubber fill hoses replace them with stainless steel or some other, more durable hose.
Drain Hose
If the washer is leaking water check the drain hose. The most common places for the hose to spring a leak is from the connection to the pump out to the back of the washer. Another common occurrence is when the washer gets pushed too far back against the wall.
Jul 09, 2013 | Bosch Nexxt Platinum WFMC640SUC
Leaks water in the front of the machine while washing. It is a whirlpool heavy duty super capasity plus. It is about 17 years old
1 Inspect externally visible components - Somewhere adjacent to your machine will be two faucets, one for cold and one for hot water. Flexible hoses with standard garden hose type fittings on each end connect these faucets to the water inlet valves for your machine. Check to see if either the hot or the cold water hose is leaking either along its length or where it attaches to the faucet or to the water inlet valve. In the simplest case, you may simply need to tighten the hose slightly at one end or the other. A pair of pliers can be used to tighten the hose fitting, but be very careful not to over tighten at the water inlet valve end because here the hoses screw onto plastic or nylon threads that can be stripped by over tightening. The hose fittings contain rubber washers or washer filter screen combinations that can be replaced if they have deteriorated. These can be obtained from local home improvement stores or appliance parts suppliers. If the hose itself is leaking then buy replacements for both the hot and cold water hose since they have probably experienced similar deterioration. Another possible source of water on the floor is an overflowing drainpipe. The drain hose from the washer normally has a curved end that hangs loosely on a vertical drainpipe (sometimes on a laundry sink) that connects into your sewer system. If the drainpipe or its connection to the sewer system is partially stopped up you will get an overflow when the washer empties. On a front loading-machine check for leakage around the door or any obvious deterioration in the gasket material. Get a helper and use a heavy piece of cardboard or masonite to protect finished floors if you have to slide the machine out for access. If the leak is not external you will have to look inside the machine. 2 Common washing machine components/operation - Understanding what you are looking at inside the machine requires some background about how washing machines operate. The washing machine has a water inlet valve assembly to turn on and off the hot and cold water that must flow into the machine. There are also flexible hoses to connect to your homes hot and cold water supply plus a rubber drain hose for emptying water from the machine. The machine has a tub for holding the water during washing and rinsing and the tub contains a "basket" (the part with holes in it that you see on looking into the machine) for holding the clothes. It has an agitator to accomplish the washing operation. It has a pump to move water from the tub to the drain and some kind of spin mechanism to remove additional water from the clothes after the tub is emptied. There is also an electric motor to power the agitator, the spin mechanism, and the pump as well as a transmission to couple the motor to the agitator and spin mechanisms. There may be a filter to remove lint during the wash cycle. Finally there is a control panel to select specific cycles, temperatures, agitation speed, amount of water in tub (load size), washing time etc. Inside the machine there are also hoses to connect the water inlet to the tub, to connect tub to pump to drain hose, and to interconnect the tub and pump and filter (if present), etc. The most likely points of water leakage are the internal and external hoses and their attachment points, the water input valve assembly, the pump, and the water filter. A less likely leak would be from the tub itself rusting out on an old machine or from some kind of mechanical failure or chronic imbalance that caused the basket to rub the tub during spin. The link "Online Appliance Repair Manuals" under resources below provides more detail, diagrams, and description for some specific brands as well as good general information. If you have not worked on washing machines before, it would be very helpful to read the first two short chapters in this reference or to read some equivalent tutorial material covering basic repair techniques and principles of operation and containing lots of explanatory figures. 3 Looking inside the machine - Here you will probably need a manual or at least the online resource cited just to get access to the inside. The assembly/attachment techniques are not always obvious just looking at the outside of the machine. Older machines sometimes had access panels on the back that provided a place to look in, but newer machines may require removing the cabinet and this is much easier if you know the recommended approach. Be very conscious of safety while working inside the cabinet. There are electrical shock hazards from exposed connections and mechanical hazards from moving parts plus possible wet wiring from water leaks. Keep machine unplugged and water turned off except as needed for tests. Also turn off water while moving machine for access and have a bucket to put the drain hose in. Inspect the inlet control valve and the tube connecting the valve to the washing machine tub. Check all internal hoses and their connections for leaks. Inspect bottom and sides of tub for any problems. Inspect the body of the water inlet valve assembly, the pump and the filter for signs of leaking through cracks or bad gaskets. Check all of the areas for wetness or signs of mineral deposits where leaking has been occurring. Remove failed parts referring to manuals or online sources as needed. Most hose clamps can be removed with ordinary slip jaw pliers. Some hose clamps may be of the screw type. If a hose is stuck and difficult to get off after the clamp is moved back out of the way, grasp the area where the hose overlaps the pipe with channel lock pliers and try to rotate it slightly back and forth to break the bond. Some sheet metal or machine screws may need to be removed to dismount parts. 4 Obtain new parts - You will need to know the make, model and serial number for your machine. If you have an owner's ,manual it will tell you where to find the "nameplate" which has this information. Lacking a manual try looking on the back of the machine or possibly just inside the door or sometimes down by the base. If you have an owner's manual it may also have a parts diagram and parts numbers. Your options for obtaining parts include getting from your dealer (e.g., Sears parts), finding a local appliance parts supplier (check your yellow pages and call first about availability), or ordering from an online appliance parts supplier. Ordering online is probably the cheapest, but if you are inexperienced it is nice to walk up to a counter with the old part in hand (along with your machine information) and get personal assistance in obtaining the right replacement. 5 Install parts - After installation check carefully to be sure the leak is repaired. Reassemble the machine.
Feb 15, 2011 | Washing Machines
My machine is leaking out of the bottom?
  • Inspect externally visible components - Somewhere adjacent to your machine will be two faucets, one for cold and one for hot water. Flexible hoses with standard garden hose type fittings on each end connect these faucets to the water inlet valves for your machine. Check to see if either the hot or the cold water hose is leaking either along its length or where it attaches to the faucet or to the water inlet valve. In the simplest case, you may simply need to tighten the hose slightly at one end or the other. A pair of pliers can be used to tighten the hose fitting, but be very careful not to over tighten at the water inlet valve end because here the hoses screw onto plastic or nylon threads that can be stripped by over tightening. The hose fittings contain rubber washers or washer filter screen combinations that can be replaced if they have deteriorated. These can be obtained from local home improvement stores or appliance parts suppliers. If the hose itself is leaking then buy replacements for both the hot and cold water hose since they have probably experienced similar deterioration. Another possible source of water on the floor is an overflowing drainpipe. The drain hose from the washer normally has a curved end that hangs loosely on a vertical drainpipe (sometimes on a laundry sink) that connects into your sewer system. If the drainpipe or its connection to the sewer system is partially stopped up you will get an overflow when the washer empties. On a front loading-machine check for leakage around the door or any obvious deterioration in the gasket material. Get a helper and use a heavy piece of cardboard or masonite to protect finished floors if you have to slide the machine out for access. If the leak is not external you will have to look inside the machine.
  • 2 Common washing machine components/operation - Understanding what you are looking at inside the machine requires some background about how washing machines operate. The washing machine has a water inlet valve assembly to turn on and off the hot and cold water that must flow into the machine. There are also flexible hoses to connect to your homes hot and cold water supply plus a rubber drain hose for emptying water from the machine. The machine has a tub for holding the water during washing and rinsing and the tub contains a "basket" (the part with holes in it that you see on looking into the machine) for holding the clothes. It has an agitator to accomplish the washing operation. It has a pump to move water from the tub to the drain and some kind of spin mechanism to remove additional water from the clothes after the tub is emptied. There is also an electric motor to power the agitator, the spin mechanism, and the pump as well as a transmission to couple the motor to the agitator and spin mechanisms. There may be a filter to remove lint during the wash cycle. Finally there is a control panel to select specific cycles, temperatures, agitation speed, amount of water in tub (load size), washing time etc. Inside the machine there are also hoses to connect the water inlet to the tub, to connect tub to pump to drain hose, and to interconnect the tub and pump and filter (if present), etc. The most likely points of water leakage are the internal and external hoses and their attachment points, the water input valve assembly, the pump, and the water filter. A less likely leak would be from the tub itself rusting out on an old machine or from some kind of mechanical failure or chronic imbalance that caused the basket to rub the tub during spin. The link "Online Appliance Repair Manuals" under resources below provides more detail, diagrams, and description for some specific brands as well as good general information. If you have not worked on washing machines before, it would be very helpful to read the first two short chapters in this reference or to read some equivalent tutorial material covering basic repair techniques and principles of operation and containing lots of explanatory figures.
  • 3 Looking inside the machine - Here you will probably need a manual or at least the online resource cited just to get access to the inside. The assembly/attachment techniques are not always obvious just looking at the outside of the machine. Older machines sometimes had access panels on the back that provided a place to look in, but newer machines may require removing the cabinet and this is much easier if you know the recommended approach. Be very conscious of safety while working inside the cabinet. There are electrical shock hazards from exposed connections and mechanical hazards from moving parts plus possible wet wiring from water leaks. Keep machine unplugged and water turned off except as needed for tests. Also turn off water while moving machine for access and have a bucket to put the drain hose in. Inspect the inlet control valve and the tube connecting the valve to the washing machine tub. Check all internal hoses and their connections for leaks. Inspect bottom and sides of tub for any problems. Inspect the body of the water inlet valve assembly, the pump and the filter for signs of leaking through cracks or bad gaskets. Check all of the areas for wetness or signs of mineral deposits where leaking has been occurring. Remove failed parts referring to manuals or online sources as needed. Most hose clamps can be removed with ordinary slip jaw pliers. Some hose clamps may be of the screw type. If a hose is stuck and difficult to get off after the clamp is moved back out of the way, grasp the area where the hose overlaps the pipe with channel lock pliers and try to rotate it slightly back and forth to break the bond. Some sheet metal or machine screws may need to be removed to dismount parts.
  • 4 Obtain new parts - You will need to know the make, model and serial number for your machine. If you have an owner's ,manual it will tell you where to find the "nameplate" which has this information. Lacking a manual try looking on the back of the machine or possibly just inside the door or sometimes down by the base. If you have an owner's manual it may also have a parts diagram and parts numbers. Your options for obtaining parts include getting from your dealer (e.g., Sears parts), finding a local appliance parts supplier (check your yellow pages and call first about availability), or ordering from an online appliance parts supplier. Ordering online is probably the cheapest, but if you are inexperienced it is nice to walk up to a counter with the old part in hand (along with your machine information) and get personal assistance in obtaining the right replacement.
  • 5 Install parts - After installation check carefully to be sure the leak is repaired. Reassemble the machine.
  • Read more: How to Find a Leak in a Washing Machine ' eHow.com http://www.ehow.com/how_2285965_leak-washing-machine.html#ixzz1D5Uk4sk2
    Feb 05, 2011 | Frigidaire FTF2140E 3.5 Cu. Ft. Front...
    I have a centrex ctw60518 6kg and i need to replace the tub to pump hose but can not find one anywhere i hope someone can help, i live in qld .
    Mar 17, 2010 | Washing Machines
    I have problem with my washer. When I fill in water while clothes in washer and notice bottom water flow. I believe that there are leaking in somewhere. Can u help me to look through. Thanks
    have problem with your washer leaking This video will show you how to find that leak on any front loading washing machine
    Please remember to subscribe to our YouTube channel for all appliance tutorials
    a 4 THUMBS rating is appreciated for answering your FREE question.
    And don't forget to like us on facebook
    Oct 24, 2009 | Washing Machines
    Looking for a lid for a centrex washing machine model ctw60518
    Vicki
    Jul 07, 2009 | Washing Machines
    HOOVER 500MB WASHING MACHINE
    the pump hose has to be above tub level or the water will run out
    the dial control unit is faulty and if the parts are are available will cost up to $150.00 aud approx to buy
    the leak under the machine could be from a tub to pump hose or water level hose up to sensor
    how new is almost new as it seems you have inherited a lemon and not a working machine
    Jul 17, 2017 | Washing Machines
    Washing Machines Logo
    Top Washing Machines Experts
