I have an AWA dvd player and a centrex tv...the centrex tv doesn't have the red socket to connect one of the sound cords into...how do i get the sound to work from the dvd player onto the tv??
  • 3 Answers
Its just a mono tele not stereo it should still get sound or u could go str8 from ur dvd to stereo or amplifietr
Posted on Mar 27, 2011
Im trying to connect my coby dvd player to my samsui tv
Hi Maria,
You can hear the sound means your TV and the DVD player are working well. May be the video connecting cord ( yellow connector) between the TV and DVD player has gone bad. Please try replacing it. For testing, you can interchange it with any of the two sound connecting cords which have white and red connectors. I hope it helps.
Jan 23, 2016 | Sansui 19 in. LCD TV
Why does my emerson 32In TV not find a channel for the DVD player that is running?
Check all the input connections once again. Check input cords. Change the cord and check. Sounds you have connected it to receive signals as AV. Select the input at TV to AV. If colors of the wire connected doesn't match the colors of the sockets at both TV and DVD end; this type of fault can occur. Anyway, check the connections and the colors of socket & wire do match, once again.
If all are found ok; and still you do not get signals, the main board to your TV should be troubleshooted. Contact any service technician.
Electro help
Feb 07, 2015 | Emerson Televison & Video
Trying to hook up a dvd and wii with direct tv and can"t get sound out of wii! HELP Can you show me where to plug cords in?
Your TV has two sets of AV inputs. One on the side and one at the back. The Wii has a 3RCA cable ( Yellow / Red & White ) . Connect these jacks to the corresponding color sockets on the side input of your TV. Select that input on the TV and your Wii sound and picture should come on.
For the DVD player you have to get a 5 RCA component cable. This cable will have 5 colored jacks, connect the White & Red to the Audio in of the TV and then connect the Red/Blue/Green jacks to the component video input of the TV.Do the same at the DVD's end also. Setect that source on the TV and you should hear the DVD sound and picture.bobhifi_31.jpg
Apr 03, 2011 | RCA L32HD41 LCD TV
I'm trying to connect my dvd player to an AWA 47'' LCD tv but it doesnt have any sound although I can see the movie. I have a thick white lead coming from the rear of the dvd player but can't find where to...
On the back of your TV, you should have jacks with colors RED, YELLOW & WHITE. Yellow is Video IN. The other two are Left & Right audio IN. Usually they wire up color to color.
Jan 30, 2010 | Televison & Video
Need to connect dvd player have yellow, red and white connectors
Red is right channel, White is Left Channel, and Yellow is video.  If you just got the TV and DVD player its a pretty simple setup.  Just look on the back of the DVD player and hook the yellow cord to video and hook the other end to video on your TV.  Now just plug in the red and white cords to the audio on the back of the DVD player and connect the other ends to audio on the back of the TV.  You can bypass these connections and just get a HDMI cable which has video and sound all in one convenient cord, but they cost more.  You just connect the cord on the back of the DVD player where it says HDMI and then plug the other end to the TV where it says HDMI.
Nov 05, 2009 | Televison & Video
My tv only has a cable hook up how do i hook a dvd player with red white and yellow cords
put the tv on av
#yellow cord in yellow socket
#red cord in red socket
#white cord in withe socket
now power the dvd
#Yellow cord in yellow socket
there will be 2 places for the red and white cords
#the red and white cords must be inserted in the audio,
# you will see them next 2 each other
insert them you it will work.
For More Info Email To ruanelectronics@gmail.com
May 11, 2009 | GE 32GT740 32" TV
How do you connect AWA plasma TV to AWA surround sound
Hi Map33_bm
It appears that your TV set is 2 channel stereo, so as there is no surround signal coded into the TV audio channels, thesurround sound does not process it.
I've posted a PDF in 'manuals' which you can check out.
Did this info help at all?
Regards, Clive.
Oct 28, 2017 | Televison & Video
I am trying to connect an akai dvd player to directv, please help
ruettab,
good day. to connect your any DVD player to any TV screen always remember this color code
from DVD back part:
yellow = video out
red/blue/green( in a row) = component video out ( this can only be used for screen with component video inputs)
Black = digital audio ( rarely use unless)
Red and white (in a row) = Audio output (left and right audio)
where to connect from TV screen.
Locate where A/V INPUTS (audio/video socket) from your TV screen, you can see it either at the BACK/SIDE or somtimes in FRONT of TV screen , having marked as "AV1"AV2"AV3' .
Once you found TV input, you must first have RCA cable (color code cable to connect player to screen) then connect the RCA cable at the back of your DVD player, simply follow color code
RCA yellow marked cable = DVD yellow socket
RCA RED and WHITE marked cable = DVD RED and white socket (second row for your player)
then connect the other end of the RCA cable to TV screen, first select which input where you gonna place the DVD player ( either AV1, Av2 or Av3 if do have multiple inputs)
once decided which INPUT to connect the player.
ex. if you select AV1 as input there would be 3socket on its row (yellow/red/white)
now connect the other end of RCA cable to the screen by following the same color code:
RCA yellow cable = TV screen A/V1 input yellow socket
RCA RED and White = TV screen A/V1 input red and white socket.
cheers,
mark
Jan 31, 2009 | Akai DVD-3850S DVD Player
No sound
tcolson,
good day, make sure your RCA red and white marked cable connected to TV screen audio input where you also connect your yellow cable which is the video.
note: always remember color code of RCA cable
yellow = video
red and white = audio (left and right)
connection would always be:
video device yellow RCA socket = TV yellow "INPUT" socket
white and red RCA = TV white and red "INPUT "socket
make sure that all this 3 cable are connected together in a specific "A/V input"
cheers ,
mark
Jan 30, 2009 | Sansui VRDVD4001 DVD Player/VCR
Connecting durabrand SA51AR
COnnect to the CD/MP3 audio pair.
Dec 28, 2007 | Durabrand STS92 System
Televison & Video Logo
51 people viewed this question
Top Televison & Video Experts
