Question about GE Ovens
I have a GE built-in oven, quite old, model JKP07 0J3WH. It's not heating per temps shown. Only to maybe 100degree, regardless whether I set it higher. The elements are warm but not hot (like 500 degree hot). The Broil setting doesn't even make make the element red. The temp light is not coming on anymore. We changed the lower element last year, but that was cold to the touch. We looked at the fuse panel, everything ok. It's something in the oven (circuitry, temp sensor - i dunno, Im not a specialist). thanks
  • 1462 Answers
SOURCE: NEFF Oven Model B1430NOGB/02 Oven Temp not heating above @50 degrees
probably the element. to save wasting money, check continuity with a multimeter
Posted on Jun 25, 2008
mastatech
  • 478 Answers
SOURCE: GE JKP26GOP1BG Electric Oven won't maintain temperature
You will need to replace the temp probe Call704-891-6557 we'll tell you how to do it safely.
Posted on Mar 14, 2009
SolutionGuy
  • 331 Answers
SOURCE: GE JKP26G Electric Oven Doesn't Maintain Temperature
Diagnosis= failed thermister (temp probe inside the oven cavity) The part number is WB23X5340 and it lists for ~$72.00 at your local appliance parts place.
Bad news is that you have to pull the oven out of the wall to do this repair.
Good news is that it's not difficult to do.
TURN THE POWER OFF AT THE BREAKER BEFORE YOU PROCEED! Otherwise you'd look like this...
Ready? OK!
All you need is;
1.) Phillips screwdriver
2.) 1/4" socket/nutdriver
3.) Ratchet if you don't have a nut driver
4.) 36 quart Igloo ice cooler (like what you'd take to the lake or the beach)
5.) Sturdy wire (smaller than a coat hanger, preferably)
6.) Flashlight
Did I mention TURN THE POWER OFF AT THE BREAKER BOX?
Now we're ready for surgery.
Open the oven door and look where the oven meets the wood. You'll see a couple of screws there... remove them. Now the oven is ready to pull.
Place your Igloo cooler under the oven. Slowly pull the oven from the cavity until you have it out and sitting on the cooler. (don't sweat it... the oven is light. maybe 75 pounds or so.)
Now that you have it out, open the oven door and remove the oven racks. Look inside (may need a flashlight) and locate the temp probe, there are 2 screws holding it in place. Remove those 2 screws and set them inside the oven cavity, you'll need them soon.
Now go to the back of the oven (slide it if necessary) and remove the back panel. (*Here's a tip... some of these GE units? All you have to do is remove one screw to access the temp probe, so look carefully... don't go nuts here. Sometimes the whole panel/panels DON'T have to come off)
You'll see the temp probe wires... they are 2 small white thermally insulated wires coming from the cavity to the wire harness in the back. Disconnect this harness and pull the old probe out from the front of the oven cavity.
OK... now to get the new probe installed... See that plastic thing on the end of the new probe? It's a pain to get through the cavity where you'll be plugging it into. It's best to have help. but it can be done alone (I've never had help, it's just harder)
Take the sturdy wire (from the tools list) and make a small hook at the end of it. Poke it through the hole that the old probe was stuck through. Now hook your new probe into the hook. Now go to the rear of the oven and gently (did I say gently?) pull it through to the back of the oven.
Now that you have it through, connect it to the harness. Now all you have to do is reinstall the rear panel/s and the oven. No biggy. Just take care not to scratch your wood trim... line it up before lifting and installing.
All in all about an hour's worth of work. I know it sounds like alot more but I could have done this in less time than it took me to type it.
Congrat's on your first major oven fix! Let us know how it turned out.
Posted on Mar 17, 2009
  • 3230 Answers
SOURCE: GE JTP 1580W288 Set oven to Bake, switches to broil at bake temp
The F2 Error code means the oven has detected an excess temperature condition. Most often this is due to a bad temperature sensor - the sensor costs about $75 from an online repair site.
How to remove and replace the temperature sensor. In most GE ovens, when you open the door, you'll see the rod-shaped temperature sensor sticking out of the back wall at the upper left. It's about six inches long and a bit more than 1/8" in diameter, held in place with two screws.
Turn off the circuit breaker (built-in ovens) or unplug the range before attempting the replacement.
The replacement sensor will come with instructions, but basically it's a matter of removing the sensor, pulling out the wires to where they are connected and disconnecting them. You may have to snip. The replacement sensor will come with high-temp wire nuts to hold the new connection. Polarity doesn't matter; it's a straight resistance thermocouple. Hook it up, be sure you poke the connections back far enough so that they're on the other side of the thermal insulation and not resting against the back of the oven.
If you continue getting the F2 error after replacing the sensor, then the problem is likely in the control module - this is the circuit board behind the keypad and clock.
You'll need to remove the decorative bezel to get behind the control panel. Remove screws and set off parts in order - it's not complicated. Once the bezel is off there are two more screws that hold the panel in place. Then you can lift the panel up about a half inch and pivot it forward toward you. You'll see a bunch of wires going to a circuit board.
On the panel you will notice some black plastic boxes that say "Potter & Brumfield" on them. These are relays. Check the relays - slide the black plastic cover straight up to expose the coil and the contacts. The coil, when energized, closes the contacts - look at all the relays. You can manually close the contacts with your finger (be gentle). If the contacts of one of them are stuck, they might be welded together. You can fix the problem by prying apart the welded contacts gently with a knife blade. Take some time to gently polish the relay contacts with a folded bit of fine grain sandpaper - this will get some more life out of them. Be gentle and careful - the relays aren't complicated but if you bend the contact or rip it out, you'll have to replace the controller, which will set you back a couple hundred dollars. If you unstick and burnish the relays, they will probably eventually weld together again as the rough spot will spark, but when you burnish them with sandpaper they should be good for some more life before they need to be replaced.
If the problem isn't the temp sensor or welded relay contacts then the problem is obviously somewhere else, but temp sensor and relay contacts will account for the lion's share of F2 errors.
Once again, be safe, be careful, be gentle. Ovens are not very complicated and they're tough, but always exercise care. Always disconnect electricity before messing with them.
good luck,
Posted on Jun 28, 2009
SOURCE: GE JTP56 double oven controls OK top OK bottom no heat
have you inserted the business card as described in the solutions?
I have a GE Profile JT965 built-in wall oven with microwave. The microwave just quit heating. Last night it worked and today it does not. The turntable turns and the light comes on but no heat. The...
Twelve years is an appliance eternity. There may be an open internal fuse, a defective door interlock, magnetron failure, and/or control board failure.
Dec 20, 2017 | GE Profile JT965 Electric Double Oven
My Mother has a GE oven which is not working properly. The problem: the oven is turned on to bake,it heats up to the desired temp, works for awhile and then the oven just turns itself off and there is an...
If your electric2_bing.gif oven is not heating then you probably have a bad heating element in your oven. This is not that hard to fix yourself...
Check out this tip that I wrote about the Oven not heating problem..
Oven Problems Electric2_bing.gif Oven is Heating Slowly or Poorly
http://www.fixya.com/support/r4511800-oven_problems_electric_oven_heating
heatman101
Asker's Testimonial " thanks i will have my husband look into that. " - 2gunsally
Oct 27, 2009 | GE 30" Built-In Single Electric Wall Oven...
Jun 26, 2009 | GE Profile JTP56 Electric Double Oven
Electric oven not heating to temp
the oven temp. sensor is bad here is the part #WB21X5301 this should take care of your problem
Jan 21, 2009 | GE Ovens
GE Profile -Installed wall oven - won't heat
brand new??? under a year old??? if so you have a warr call for service, but it sounds like an ignitor isssue, brand new , perhapsgot damaged in shipping 1-800-ge-cares
Mar 29, 2008 | GE Profile JTP56 Electric Double Oven
Ovens Logo
186 people viewed this question
Top GE Ovens Experts
William Miller
William Miller
Oloyede Monsuru
Are you a GE Oven Expert? Answer questions, earn points and help others
