Question about Kenmore 51562 / 51564 / 51569
Our Kenmore 51562101 Refrigerator's freezer stopped working almost overnight? Everything has thawed. Help!
VANMAN69
  • 23 Answers
SOURCE: freezer works ok.refrigerator temp varies from 39 deg.to 60 deg.
check to see if there is frost in the back of the freezer if so you have a defrost prob..
Posted on Jun 29, 2007
  • 2336 Answers
SOURCE: kenmore elite refrigerator
If this appliance is new, I would suggest to contact the vendor or manufacturer and ask them for in home service.
It could be the thermostat that might be not working properly or not set properly.
Check the user manual for more info on the thermostat settings.
Posted on Jul 08, 2008
capsman
  • 111 Answers
SOURCE: freezer works but frig is not cooling
I don't know this particular frig, but evidently the defroster doesn't work. Frost buildup has blocked the flow of cold air.
There is a defrost timer, under the frig, accessible from the front. You can turn it with a screw driver. Turn it till you hear a click. If the timer hasn't been turning, that should turn on the defroster, a heating element nested among the freezer coils. Wait half an hour and if it is defrosting, water should be dripping into the drip pan underneath the frig. If so, then replace the defrost timer and you're good to go.
If that doesn't make it defrost, then the problem is probably the defrost thermostat, in with the freezer coils. When the frig defrosts, the defrost heater stays on until the defrost thermostat gets warm. It should be open circuit while warm. But if it is open circuit while cold, it is bad and is the cause of your defrost problem.
If you open up the freezer coils, use a hair dryer to defrost. That is safer than hot water.
Hope you can fix it.
Posted on Aug 01, 2008
buddymcl777
  • 67 Answers
SOURCE: Frig and freezer not cooling. Everything is thawing
1/ refrigerant leak or
2/ Defective thermostat / sensor or
3/ Burnt out compressor
Posted on May 01, 2009
  • 1218 Answers
SOURCE: i have kenmore refridge model # 106. 51512100
Sounds like the compressor quit running, or the refrigeration system restricted and is allowing no refrigerant from circulating.
Remove the back cover and see if you can hear the compressor running. If not, there are three or two starting components mounted on the side of the compressor. With the unit unplugged remove them. There are1, the relay, 2, (thestart/run capacitor, some models only), and 3, the overload. They can be pulled off and taken to an appliance parts house which usually are happy to test for you. To check the compressor itself, you will need a working knowledge of electrical and knowledge in the use of a VOM meter. Three terminals stick out of the compressor. The VOM meter should read between no less than 2 and no more than 18 ohms between any two terminals.
If you can hear and feel the compressor running, you have a serious problem. Either all the refrigerant has leaked out, or the system is totally restricted. A for professionals problem only, and very pricey.
However, if the machine is under 5 years old, it is under warranty for this last problem.
If you correct the problem, DO NOT leave the back cover off. It ducts air to the condenser, and must be in place.
Posted on Oct 31, 2009
I have a Kenmore side by side fridge Model 51562101. We just noticed a burning type of smell coming from under the freezer side. My wire thinks the smell is more like a chemical smell. The fridge is...
Your compressor just went bad...
Many times a freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong.
If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator
Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Feb 15, 2011 | Kenmore 62832 / 62834 / 62839 Bottom...
The freezer is fine but the lower fridge is at 58 f
There is ice build up blocking air flow to the refridgerator compartment. Put everything in a cooler, turn fridgfe off, thaw OVERNIGHT with BOTH DOORS PROPED OPEN and then rinse freezer with a liter(big slam) of water. Let sit 5 minutes and pull bottom drain pan . Empty it. IF YOU RUSH THIS THEN The internal ventalation will still be blocked. 12 hour thaw minimum even with doors open.
Jan 27, 2011 | Kenmore 63712 Top Freezer Refrigerator
Hi I have a Sears, Kenmore refrigerator model #106.53382. The freezer has stopped freezing. Everything is defrosted. The lights all work, I hear sound. What could it be?
This is your defrost system that has gone out on this model. When this system goes out, everything thaws out because the defrost system has failed.
This is an easy repair if you want to attempt it yourself and you can save a lot of $$$$ by doing it on your own.
Just contact us at:
http://www.fixya.com/repair/d499389-accurate_appliance_repair_service from 7 AM until 9 PM CST and we will provide part removal/installation instructions for you when you get your parts through us.
We want to get you cooling and freezing again soon and we ship overnight for our customers.
Thanks, Ella
Nov 17, 2009 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
My side by side kenmore refrigerator, freezer isnt freezing
the fan in the freezer is not working to blow the cold air in the freezer you need a new fan you need a repair man it will cost you $300 good luck i have the same problem don't buy samsung they are useless that why home depot don't sale samsung
Nov 12, 2009 | Samsung RS265LABP Side by Side...
Refrigerator stops cooling
Your defrost system is bad. When the unit freezes up, the air flow shuts down and you don't cool. When you turm it off, it thaws out and starts to work again. We have parts so give us a call if you like. Hope this helps! Ella
Aug 18, 2009 | Kenmore 63222 / 63224 Bottom Freezer...
Refrigerator not cooling and freezer not freezing
The compressor start relay or start capacitor is defective and I will need to go through this in a step by step process until we locate the problem For now unplug the refrigerator to prevent compressor damage until we locate the problem. Let me know when you are ready. Sea Breeze
Jun 24, 2009 | Frigidaire FRT17G4B Top Freezer...
Internal water dispenser stopped working
I lowered the temp on the freezer to 4 overnight, by morning water dispenser is working fine. I think that when we changed the temp to 7 (in order to make more ice ) it froze the water pipe going to the dispenser. I am going to keep both fridge and freezer at 5 ,and hope this will not happen again.
Dec 31, 2008 | Amana AFD2535FES Stainless Steel Bottom...
Everything works but no water
Try turning down the freezer a little.
You can 'thaw' the water line in the door by hanging some towels in the freezer with the door open. Should thaw in a couple hours. At least this way you don't need to empty the freezer.
Dec 08, 2008 | Hotpoint HSS25GFP Side by Side...
Kenmore 51562 / 51564 / 51569 Logo
77 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
oldblindman
Level 1 Expert
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
