Question about RCA RS2620 Single Cassette Deck
Hey i recently read your solution to my RCA problem you said to unplug it for 24 hours so it can reset i don't think its gonna work..ahhahaa..i've left it unplugged for months now ahhahaha.and still nothing happened..do you think theres a way i can reset it manually??
    Sergeant:
    Champion:
  • 319 Answers
If the unit still does not work, there are problems that only a qualified technician has to address. Please take in for complete check out and service
Posted on Aug 04, 2008
I`ve a RCA L32wd14 tv everything works fine but
Tries Unplug,replug the tv about an hour,go to the menu sound setting reset it back to factory setting.Should work after this.Not than ur Main Tuner signal board have problem.Must replaced.Tries Shopjimmy.com,Ebay.com to buy a refurbish Main Tuner board for the replacement.
Mar 23, 2010 | RCA L32WD14 32 in. LCD Television
Pulsar (Seiko) Watch Changes Date at different time.
mcdevito75 here, The manufacturer recommends you don"t try to change the date between certain hours as this could hurt the date changeing mechanism inside the watch, I don"t think you did any harm (LUCKY) and the date changeing 45 minutes before mid nite is just about right. BUT! if the date change was aliitle closer to mid nite at 1 time you can try to reset the date, here"s how, your stem should have 2 positions to change the date without haveing to cycle the watch the 24 hours 60 times. Slip a finger nail just under the crown and gently, gently lift the crown to it:s first position, it may take a little practise but you"ll get it, once you do, trun the crown and you should see the DATE change, if so set the DATE to 1 DATE before the DATE you want, now pull the stem out and set the correct gate and time of day. Your watch is now reset and date will change on time, around nid nite.
Jun 10, 2008 | Pulsar Bracelet PXQ502 Wrist Watch
My rca system
Try unplugging unit for 24 hours so that microprocessor can reset. Try again to operate. If still nothing, take in for check and service
Jun 01, 2008 | RCA RS2620 Single Cassette Deck
USB port won't playback
Hey,
I have an RCA LYRA mp3 player and it works fine. I think this system has a very limited amount of mp3 players it will work with.
kruddy
Dec 28, 2007 | RCA RS2664 Shelf System
I have a rca hd52w140
Does the unit show a flashing led on front panel. make any sounds. reset this tv if it works invloves unpluging the set for 30 minites.
Oct 16, 2007 | RCA HD52W140 52" Rear Projection...
"weak signal" on my RCA scenium
Hey! I have the same problem as you. But! this would happen only when I got a power outage. Unplug the TV for a couple of minutesand all was fine. For the last 5 day I have no TV. I have tried everything. All the out on the TV and I still get unusable signal. My rep told me to unplug for 24 Hours. Still didn't work. My menu option work as well and every time I put the TV on, off or if I change the input sound will come on for 2 seconde and stop. If I find the salution I will let you know. Gilles Ottawa
Jan 20, 2007 | RCA Scenium HDLP61W151 61 in. HD-Ready...
P52930bl RCA Projection 52" Remote problem
First thing you want to do with this set would be to unplug it for at least a 24 hour period. if that does not work, the remote sebsor could be defective. if you want to just replace the sensor and not trouble shoot the set, it should be located behind a plasit cover in the front of the set, or located inside the reflection area of the TV set. Differant models are located at differant positions. If you have no electronic experience, play it safe and call in a trained tech to assist you in this repair. Good Luck Please do not forget to rate this thread.
Dec 14, 2006 | RCA P52930BL 52" Rear Projection...
RCA RS2620 Single Cassette Deck Logo
56 people viewed this question
Top RCA Audio Players & Recorders Experts
Gyula Lacz
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
