Question about Craftsman 21 Hp 42" Deck, Ys 4500 Lawn Tractor
WHAT WEIGHT OF OIL IS NEEDED FOR A YS4500 W/ A 21 HP BRIGGS AND STRATTON MOTOR
    Problem Solver:
  • 17 Answers
I have used 30 WT oil in all my 4 cycle engines. You could google Briggs & stratton to get some info. Sears will sell you an operators manual. Try googling Sears, you might get lucky & get the manual for free..
Louie Almond
Posted on Mar 27, 2011
What oil does a polan 38inch deck take
Check with Briggs and Stratton to confirm but, for summer use 10W30 or a straight 30 weight automotive grade oil will work.
Jun 01, 2014 | Poulan 38-Inch Steel Deck 15.5 HP Briggs &...
Briggs & Stratton 18 hp motor oil white
White oil in any motor indicates the oil has mixed with water . Drain the oil change the filter and find out how the water got in.
Oct 01, 2012 | Briggs & Stratton Briggs Stratton Intek V...
Need to know the weight of the motor oil
sae 30 in winter sae 40 in summer i preffer rotela
Aug 20, 2012 | Briggs & Stratton Briggs Stratton Intek V...
21 HP briggs & stratton engine burns 6oz of oil & the spark plug is black with oil & carbon there is no smoke from the exhaust
Check in your user manual and see what weight of oil you should use in your engine. If the weight of oil is too low it will let it burn pass the rings and the valves. I use Briggs & Stratton 30 SAE oil in all my engines. If the engine is old you may have to do a valve job or clean the valves and head which do carbon up and need to be cleaned from time to time.
Aug 22, 2011 | Garden
What kind/type engine oil for the 17.5 H.P. Troy-Built Pony garden tractor?
sae 30 weight is used for most garden tractor engines. This is straight 30 weight oil not a multigrade. Most big box stores that carry this kind of gear have it.
Feb 16, 2011 | Briggs & Stratton Briggs Stratton Intek V...
WhaT TYPE OF OIL DOES THE 16.5 HP B&S engine take
Your 16.5 hp Briggs engine takes SAE HD30 weight motor oil. I recommend to use a name brand high quality oil. It should take 48 ounces from a complete drain. If you run this engine when it is cold outside (below freezing) then you can change to a 10W30 oil.
Good luck
Sep 16, 2010 | Poulan 38-Inch Steel Deck 15.5 HP Briggs &...
Changing oil in Biggs and Stratton engine
Use 10W30 weight oil. The capacity is 1.5 Quarts (48 ounces) with filter change. I highly recommend you use 100% synthetic oil in an air cooled engine. Change the oil and filter every 50 hours of use.
Apr 23, 2010 | Briggs & Stratton Briggs Stratton Intek V...
What type of oil is used in an Intek 6.5 engine? Powers a log splitter, cold weather application.
30 weight, should hold about 2 qts. Use a synthetic oil, will flow a little better when cold than conventional.
Jan 12, 2010 | Briggs & Stratton Briggs Stratton Intek V...
I have a 1977 model 137-495/ 8 hp electric start MTD riding mower with a 38'' cut, my problem is I want to change my oil and I have no idea how much oil I need with the filter.
I take it that the motor is a briggs and stratton?
Briggs makes their own sae 30 weight oil which you can pick up at lowes for 5 bucks or so and it is packaged in a 48oz. container
this is what you need for an oil change and filter,
being this old and 8 horsepower have you located a oil filter?
anyway start with 48oz do you have a screw in dip stick to check your oil or a cap you take off near the base of the motor? if you have a cap you take off then you add oil here until it covers the top of the threads and your done.
if you have a dip stick add 1qt 32oz..then check the level with the dipsticks safe range and adj as needed.
if you cannot find briggs oil then use a reputable brand sae 30 weight
hope this helps you some
Jun 07, 2009 | Mtd Garden
Craftsman 21 Hp 42" Deck, Ys 4500 Lawn Tractor Logo
598 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
