Question about Frigidaire FEQ1442ES Electric Dryer
My heating element went out. First where is it and how do I replace it.
  • Frigidaire Master
  • 528 Answers
It is behind the drum
you need to open the top cover
take the control panel out
open the front cover (with the door)
take the drum out (disconnect the belt from the motor pully . on the bottom)
you can see the heat element but check the fuses first on the heat element they might go bad and not the heat element wiche is :Number:131553900 on sears parts
Posted on Mar 27, 2011
  • weible420 Mar 27, 2011
    And where's the fuses.
  • 911 SERVICE TODAY
    911 SERVICE TODAY Mar 27, 2011
    :) thouse are the fuses they are silver color with 2 wires in and out http://www.searspartsdirect.com/partsdir...
    part # 33 and 36 are the one that burn
Replace Zanussi ZWD12270W faulty dryer heating element
Just for the record, the heating element went on mine too and I'd only used it less than half a dozen times. The engineer said that it went because it hadn't been used enough (it gets moisture inside somewhere). He said if I didn't use it I would have the same problem after it had been replaced. So make sure you dry something every couple of weeks (he said at least once a month).
Nov 30, 2013 | Zanussi ZWD12270 Front Load Washer / Dryer
I have an Electrolux Frigidaire Self Clearning Convection Oven. I was cooking yesterday when it went off and I cannot get any heat now. The oven still lights up when I turn it on. The fan still wor
Hello - Sounds like the element or the control board to the element is not communicating correctly. I would have a professional diagnose the element first. You may only need to replace it. Otherwise it could be the control board not allowing the element to heat up properly, a faulty mechanical thermostat or an oven sensor.
Oct 19, 2012 | Frigidaire GLEB27S7A Electric Single Oven
Dishes come out all wet. Maybe the heating element but would there be any other potential?
You are right -almost-. When the heating element is not working properly and dishes doesn't dry, I don't think the heating element went bad. It's more likely that other part is causing the problem. Perhaps the timer went bad.
When the timer is broken, the heating element doesn't get power to dry the dishes. By the way, the timer are also called electronic controls or control panel. I believe it needs to be replaced.
Aug 29, 2009 | KitchenAid 24 in. KUDI01FLSS Stainless...
Replaced high temp sensor on whirlpool front loader
The high limit thermostat should have been replaced also.
If there are no obstructions that will fix your problem.
Mar 13, 2009 | Whirlpool GEW9250 Electric Dryer
Heating element in GE Range Oven
get the model number and order the exact repacement bake element
Mar 10, 2008 | Kenmore 40494 / 40495 / 40499 Electric...
Heating element - amana le8107w2
the heating element is located at the back. you can remove the back cover and access it from there.
Feb 22, 2008 | Kenmore 63942 Dryer
Frigidaire FEQ1442ES Electric Dryer Logo
77 people viewed this question
Top Frigidaire Dryers Experts
Tim Whalen
Marvin
Marvin
Sal De
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
