Question about Samsung HP-S5053 Television
Samsung s5053, will not turn on. clicking noise inside, screen comes on and goes off. No picture. checked voltage on pin 10 get 5 volts connector cn804-1. research on internet seems to point at main power board, but some think its standby power board. I was going to replace the PSPF501A01A board. But don't want to spend $100.00 on wrong board. Any advice will be helpful. Thank-You Ken
  • 5 Answers
Ken, did you ever find out what was wrong with your set and have it repaired?
I have the same "clicking" problem when first turn on the TV. First, it took about 30 secs clicking (came from the relay) then came on ok. The wait time gradually increased up to a few minutes before it comes on. Then, the power button was flashing blue light when the TV is off, but then came on ok after 3 - 5 minutes. Now it finally has no power at all.
I checked the stand by voltage at pin 10 of the CN804-1 connector and get nothing but a going spike voltage up and down on the multimeter. I noticed that one blue ceramic disc capacitor (the disc type, not the can type) was cracked and some black burned spots around it. May be it is the problem?
Posted on May 06, 2011
Samsung Smart TV UN465300FXZA picture goes very dim after a a couple minutes of being turned on
the back light is the problem if one goes off the rest will not work unless you replace it you need expect to do it
Mar 29, 2018 | Samsung Televison & Video
Hello, I have a Samsung LN52B630 TV that quit working...noticeably after a confirmed lightning strike nearby.
Screen coming on when the main plug is removed is normal, that happens on most TV's...Are the spots that have no volts supposed to have voltage? there is a legend on the board to tell what voltages belong no what pin, check that
Oct 28, 2017 | Samsung Televison & Video
My 2006 harley 883 has a new... stator, regulator, and battery. charges perfect and turns over just fine. after 10 - 20 seconds i shut her off hook her up to a battery tester and she goes from
Hi, Casey in order to check out any main electrical system, you have to start with a fully charged battery 12.5 volts or better, and be able to pass a load test if necessary. "WARNING" never plug or unplug any electrical connector with the engine running !!!
1. Check battery terminals for damage or corrosion, check battery cables at "BOTH" ends for loose, corroded, or broken connectors, "INSIDE" and outside the cable harness, perform connector wiggle test and check cables with an ohmmeter if necessary.
2. Check the voltage drop at the battery when you hit the starter button, anything below 9 volts you might have a faulty battery.
3. Check voltage at the battery with the bike running at 3,600 RPM should be 14.3 to 14.7 volts. If you are not getting these numbers, you might have a faulty voltage regulator.
4. Make sure voltage regulator is "GROUNDED" and functioning properly, watch the video below on how to test a voltage regulator.
5. Unplug the connector to the alternator and hook your multimeter leads to the alternator (pin/socket selection does not matter) set the multimeter to AC volts, at an idle the multimeter should read 16 to 20 volts AC. at 2,000 RPM 32 to 40 AC volts, 3,000 RPM 48 to 60 AC volts. If you are not getting these numbers, you may have a faulty rotor, follow step 6
6. Set the multimeter to OHM'S, connect one lead to the alternator (any pin/socket) and the other to a ground, the multimeter should read infinity. Connect both leads to the alternator multimeter should read 0.1 to 0.2 OHM'S. If you are not getting these numbers, you have a bad stator.
7. Check all wiring in the charging circuit for worn or chaffed spots and all wiring connectors in the circuit for corroded, broken, or loose pins/sockets, which is the # 1 offender.
For more information about your issue and valuable "FREE" downloads that you will need please click on the links below and for more specific information or questions at no charge please feel free to contact me at xlch@mail.com. Good luck and have a nice day.
Instant Tech Relief A must have !!! Absolutely Totally "FREE"
https://serviceinfo.harley-davidson.com/sip/vehicle/lookupForm
http://partsfinder.onlinemicrofiche.com/stcharlesharleydavidson/showmodel.asp?make=hdmc
Harley Davidson Manuals Mark Workshop
Oct 22, 2016 | 2006 Harley Davidson XL 883 Sportster
Head lights (no tail lights) come on when ignition is turned on, they go off when engine is started (head light switch is off).
Hi, Nudge in order to check out any main electrical system, you have to start with a fully charged battery 12.5 volts or better, and be able to pass a load test if necessary.
For more information about your issue and valuable "FREE" downloads that you will need please click on the links below. Good luck and have a nice day.
http://racetechelectric.com/files/pdf/rte_troubleshooting_flow_chart.pdf
How to diagnose and repair motorcycle charging problems
May 23, 2016 | Motorcycles
Samsung Plasma won't power on
this is not a capacitor problem. set is only 18 months old - has something to do with x y sustain boards not allowing smps to power on the high voltages.
May 27, 2013 | Samsung Televison & Video
PICTURE GOES OUT SOUND STILL WORKS TURN OFF AND WAIT AWILE TURN BACK ON WORKS FOR AWILE IS THE REPAIR EXPENSIVE CAN I DO IT MYSELF
hi
electric shock
take car
there is somewhere in your TV main board, one of IC's or transistor's pin is Disjunct
Jun 02, 2010 | Samsung HP-S5053 Television
Blank Screen but sound works on samsung HPS-S5053
Testing by FixYa Staff
Please do not rate this post!
We apologize for any inconvenience.
Jul 14, 2009 | Samsung HP-S5053 Television
Sony cdx m800 no display
I think you are going to need the service manual to properly troubleshoot this. You can try to follow these instructions without one, but having one makes it so much easier. You will need to have the radio on a work bench with the CD mech out and the harness out of the car as well so you can turn on the radio and check some voltages. Since you are an electronics engineer, I should not need to point out any safety precautions, after all, I am just a technician.
For starters, check the voltages at pins 7,8,15,16,17 on connector CNP909 the 24 pin connector for the display on the main board. Pin 1 should be the one closest to the corner of the board that connector is near. Pins 7 and 8 should have 10 volts each, pin 15 should have 5 volts and 16 and 17 should both have a much higher voltage. I suspect you may be missing the 10 volts from pins 7 and 8. If so, check the voltage at the emitter of Q914 on the main board. It is a digital transistor (surface mounted) and when the power is on it should have 10 volts there and 10 volts on the collector and zero volts on the base. If any of those voltages are not there, check Q915. It should have 10 volts on the collector, 5 volts on the emitter and 5.6 volts on the base. It is not a digital transistor but is surface mounted and much bigger than Q914. If you are missing the 5.6 volts on the base, check the zener diode D905. It should have 5.6 volts on the cathode and ground on the anode. The cathode goes directly to the base of Q915. Use your multimeter on the diode check mode and see if it looks normal. Could be that zener diode is shorted. There is also 2 capacitors in parallel with that zener, C928 and C930, check those as well. If one of them shorts out it will look like the zener is shorted.
You can also check CNP805 for the 10 volts, it is supposed to be there as well. I don't know what pin number but I think that connector is on the top of the board. The 10 volts should be either pin 5 or pin 7, depending on which side you start at. CNP805 is the connector for the sub-board with the reset switch on it. After you know what these voltages are on CNP909 we should be able to narrow down the problem.
I hope this helps, I really do not have a lot of time right now. I have a power supply to fix and a big stack of car amplifiers to repair. Let me know if you need more help, I just may not be able to answer as quick as you may like, but I will answer when I have time.
Dave
Jan 27, 2009 | Sony CDX-M800 CD Player
VERY DARK COLORS ON THE SCREEN..
check power section the brightness control transistor could be open.The voltages are ok on rgb.check heater voltage
Hope this be of initial help/idea. Pls post back as requested, how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FIXYA.
Mar 07, 2008 | Samsung 793S 17" CRT Monitor
Televison & Video Logo
437 people viewed this question
Jerry Greenberg
Jerry Greenberg
