Question about Garmin nuvi 750 GPS Receiver
My Garmin nuvi 750 wont talk,Why is this? - Garmin nuvi 750 GPS Receiver
    Top Expert:
  • Garmin Master
  • 75,471 Answers
Hello
Just reset the GPS and check whether it helps you or not. To reset do the following.
Slide the power key to the left and hold it there for a minimum of 10 seconds. The nuvi should operate normally.
If this does not help update the software. Goto www.gramin.com/products/webupdater
Posted on Mar 27, 2011
4 Suggested Answers
SOURCE: trouble with Garmin 750
Even stand alone FM transmitters are tempermental and their performance can depend on the arrangement of your car's antenna system.
I have found that my radio will 'lock and hold' the Garmin's signal if I can boost it for a few seconds by creating a stronger signal by placing an 'antenna' (generally anything metal) near back case of the Garmin at the middle or right side (looking from the front).
You can also try just taping a piece of metal to case back at that position. I just used pair of sissors but I'm sure some tin foil or a peice of wire will do the trick.
Posted on Jul 01, 2008
sharcnet
  • 2130 Answers
SOURCE: Garmin Nuvi 750 will not turn on. Any ideas on
Hi Jessica,
Move the on/off power switch to the left and hold it there for at least 30 seconds and see if it comes back on. I know there was a bug in a firmware version that makes the unit "bricked" after a certain date. The only way to fix it if the reset didn't fix it is to disconnect the battery inside, reboot the unit and install the firmware fix.
- Jim
www.sharcnet-usa.com
Posted on Aug 20, 2009
sharcnet
  • 2130 Answers
SOURCE: Garmin Nuvi Doesn't turn on
Try resetting the unit. The procedure can be found here:
http://www.sharc.net/discus/messages/6/313.html?1268661443
- Jim
Posted on Mar 19, 2010
Garmin Nuvi won't talk. No sound when programming
If the mute is not checked, try plugging in a set of headphones. if you now hear sound, your internal speaker is blown. Please see this link:
http://www.sharc.net/gps_audio_repair.htm
- Jim
Apr 27, 2010 | Garmin nuvi 750 GPS Receiver
Need manual for nuvi 750
you can download a copy of your manual for your Nuvi 750 HERE
bill
Nov 20, 2009 | Garmin nuvi 750 GPS Receiver
My garmin will only turn on while it's plugged into the car charger. I have had it plugged into my computer for some time and it won't power on while connected to the computer or while unplugged- I...
Time for a new battery. If you talk to garmin they will want to replace the entire unit. You can buy a battery for about $23 and do it yourself.
Here is on place that sells them but I would also search for others to compare prices and specs.
http://batteries.batterymart.com/garmin-nuvi-750-replacement--list
Oct 24, 2009 | Garmin nuvi 750 GPS Receiver
I cracked the screen on my Garmin Nuvi 750. Can it
Maybe this can help.
http://www.sharc.net/gps_repair.htm
Jul 15, 2009 | Garmin (010-00583-00) for nuvi 750/760/770
My Garmin nuvi 750 is no longer talking to me. There is no voice. When I go to the language settings, the Voice shows none found. It was working 2 weeks ago, I haven't used it since. Our Garmin had a...
There is a software bug Garmin has been working on for a while. The voice file changes to none. To fix go to tools, settings voice and change to desired language. Sometimes the language files get messed uo and need reloaded from webudater, this can be obtained from www.garmin.com. The latest Garmin Software version is 4.80
May 06, 2009 | Garmin nuvi 750 GPS Receiver
Garmin 750 stop saying street names
If you go to your languages, in the menu
Check Languages are
(( noted with a person's name ))
these are TTS text to speach voices,
Check they are set correct,
you should be good.
Hope this helps
Regards
Richard.
Apr 11, 2009 | Garmin (010-00583-00) for nuvi 750/760/770
Manually Turn off Garmin Nuvi 750
Slide the switch to the right and it should shut off
Apr 05, 2009 | Garmin nuvi 750 GPS Receiver
No voice prompts on my new nuvi 750- volume level not muted.
Got this from a another guy who said he had the same problem
Update your gps on garmin website, download latest firware version. Worked for me
Feb 07, 2009 | Garmin nuvi 750 GPS Receiver
I want to listen to the radio while using Garmin nuvi 750
Hi, go to Tools, Volume, then select FM Trans and switch it on. Tune your car radio to a wavelength which has no signal, just background static noise, note the wavelength and adjust the Nuvi screen to the same wavelength.
Dec 30, 2008 | Garmin Nuvi 760 Handheld GPS Receiver
Can't register my Garmin 750 online
Go to this url and I hope this helps. It worked for my Garmin 750.
http://www.garmin.com/garmin/cms/site/us/support/searchsupport?search_key=nuvi%20750
Aug 01, 2008 | Garmin nuvi 750 GPS Receiver
Garmin nuvi 750 GPS Receiver Logo
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
Steve
Are you a Garmin GPS Expert? Answer questions, earn points and help others
