Question about Compaq Computers & Internet
The problems is can't detected to the you tube or video
  • 33 Answers
I will need more detailed info as to what your referring too.
Posted on Mar 27, 2011
What would make the oil in my 95 chevy truck smell like gas
The fuel pressure regulator & spyder assy under
the intake is leaking fuel
Google GM Spyder Problems
Go to You Tube Video & watch Wayne at
Real Fixes Real Fast show you the problem
Mar 12, 2013 | Cars & Trucks
Code p0455
PO 455 --Evap System Leak Detected (Gross Leak)
Have it scanned & smoke tested to find leak
You can Google any OBD2 Code & read up
on problems ,solution, anything auto related,
as well as on You Tube Video
Mar 07, 2013 | Chrysler Town & Country Cars & Trucks
Screen went green on sony tv
Check the video output section circuit for any loose soldering or component failure. Check the voltage at the green cathode of the picture tube. Can be measured by using a multimeter. At present, this voltage will be lower than other tow cathode voltages. In most cases, the cause for this fault is found to be with loose solder terminals itself.
Check all the solder terminals at the video output stage printed circuit board. You can locate this board at the picture tube base itself. Will be plugged to the back of the picture tube neck. A rectangular board. Normally, it will be very difficult to detect loose solder points, as they might be microscopically small to detect by ***** eye. So it is recommended to re solder all the suspected solder terminals there, by applying little more fresh solder, without making any solder bridge short in between adjacent solder terminals. This must solve the problem you faces with your TV
Jul 23, 2012 | Sony FD Trinitron WEGA KV-34HS510 34" TV
I have done all that you saud to do. Now the problem I have is the computer will not turn on at all. It's like the power has been turned off from inside the operating progam. I have windows 7, is this...
Phase 1
After power button pressed, computer will detect 5 components :
1. Power supply - OK (enough power)
2. Main-board - OK
3. Processor - OK
4. Memory - OK
5. Video Card / VGA - OK
== beep sound .. (1 time) or on the monitor, display appears BIOS ==
The characteristics of damage to power supply
1. Power supply fan does not spin
Video power supply fan not spinning
If the power supply fan is not spinning, the possible cause of damage to power supply. Solution, replace the power supply.
How to check the damage to power supply
2. Power supply is weak (resulting voltage power supply can not turn on the computer or the voltage is less)
The characteristics of damage to the processor
Normal fan without processor
Normal fan with processor
Based on experience, the possibility of damage processors is very small. To check for damage to the processor, install the processor to another computer (for comparison).
The characteristics of main-board damage
Because the new main-board, so the possibility of the main-board damage, very small. The characteristics of damage to the main-board, when the power button is pressed
1. Power supply fan not spinning
2. Processor fan is not spinning
3. Casing lamp is not lit
4. Main-board lamp does not light
The characteristics of the memory damage or dirty memory
1. The characteristics of normal memory, but installation is not correct or dirty
When the computer is turned on, the sound
Solution
Picture a
Release Memory
Picture b
Clean the memory slots with a brush
Picture c
Clean the gold layer memory with a pencil eraser
Picture d
Reinstall the memory correctly
The characteristics of damage to video cards
Solution, remove the video card, clean the gold layer with a pencil eraser.
I hope this information helps.
Oct 23, 2011 | Computers & Internet
Sony trintron Tv KV-HA21P50, its alot of green color, whats is the problem.
Hello
Loose soder points in the video output board of your Sony Trinitoron is the problem. Solder loose on the green output transistor will show this kind of fault with this type of CRT based sets. Just open your TV, and locate the video output board. It can be located at the picture tube base itsef. This board is pluged diretly to the back of the picture tube. Just pull it out straight backward, without making any sideways shake. You may have ot apply some backward pressure to detach it out. Just look for any loose solderings at the solder terminal of this board.
It is very difficult to detect the loose soldering by ***** eye, as it will be microscopic in nature. It is a best practice, to resolder most of the solder terminals of that board, by app;ying a little more solder, whout making any solder bridge in between adjecent solder terminals. This will solve the colour problem to your TV.
I've attached a picture of a tV with back opened. You can see the Video Output Board pluged on to the back of the picture tube. Just resolder all the picture tube base socket terminals solderings also. OK
gopakumarg43_35.jpgHere the main board has been pulled out and placed vertifally at service position. The CRT board [video output board] can be located as you open the TV.
Aug 30, 2011 | Sony FD Trinitron WEGA KV-32FS120 32" TV
My youtube video is not opening. In my PC every other program and website is alright other video is opening but not only you tube video will u tell me whats the problem
HERE'S THE ANSWER TO YOUR PROBLEM:
Try to change the proxy settings:
1. Open IE
2. Go to tools >internet options >connections select the automatic detect settings.
3. Apply then OK.
If your using firefox:
1. go to tools> options > advance > network tab.
2. then click settings
3. select the automatic detect settings
4. then apply and ok.
Your problem is solved! Thanks!
Jul 04, 2011 | YouTube Videos
When i turn on my tv it has a blue tint then about a minute after its on it swithces to a red tint with red lines .... what does this mean and how can i fix it?
Hello
There are two possibilities for this fault. The first one is solder loose contact in the video output board. Video output board is pluged diretly to the picture tube base. it can be pulled out from it. Be careful not to shake sideways when you pull it out from the picture tube, as it may damage its pins. Normally loose solderigs are very difficult to detect as they will be not visible with naked eye. Keep special attention to the solder terminals of high watt resistors fitted in it. They will heat up during sorking, and repeated heating and cooling make its solder terminals to be get loose contacted. Just resolder all the suspected solder contacts by applying a little more solder, without making any solder bridge short in between adjecent solder terminals. Resolder all the picture tube socket solder terminals also.
Till the problem perists, its video processor IC [Chroma IC] is faulty, and should be replaced with same type and number. OK.
Jun 28, 2011 | Symphonic ST420FF 20" TV
Both diswashing drawer are running with F1 flashing
We found that the unit was floofing because a thin, white plastic tube behind the drawer had broken. I learned that the plastic tube is to preven the electric cables from kinking when the drawer moves in and out. The broken tube was preventing the seal from working properly and water was getting past it to the bottom of the unit where a water sensor detected it, shut the washer down, and displayed an F1 fault. The simple solution was just to snip the tube off so that it could not reach the lip of the drawer and intefere with the seal.
Jan 13, 2011 | Fisher and Paykel 23 in. DD-603SS Built-in...
How to connect vista laptop to tube tv
If your laptop has a s-video output you can get a s-video cable that goes from your laptop to your tv's AV input.
You then just have to activate the alternative display on your laptop to make it work if it doesn't detect it automatically. Hope this helps.
Cheers
Sep 30, 2009 | Televison & Video
Computers & Internet Logo
12 people viewed this question
Top Compaq Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
