Question about Refrigerators
I noticed a couple weeks ago the frig side was not cold enough. Milk spoiling but butter not getting soft. Freezer side seemed to be working ok. Now Ice cream in freezer is getting soft.
    Problem Solver:
  • 17 Answers
How old is the fridge? Most units have a system of tubing attached to metal fins, which is located in the back of the unit. This tubing & fins must be kept clean as dust will accumelate & insulate the freon gas from turning into a liquid.. Another problem is when the motor & compressor does NOT get enough air to cool the tubing & fins. This happens when the refrigerator is located in a closet type atmosphere where the unit is too big to get any air to the rear of the unit. NO spacing on the sides or top. ALSO, the compressor might of died. In this case, if the unit is out of warranty and/or over 7-15 years old, buy another, NOT worth the repair. If still under warranty, call vendor/manufacture.
Louie Almond
Posted on Mar 27, 2011
Unit ED5DHEXWQ bought 2 weeks ago Drip pan over flows- water not evaporating quickly. Company tech say I need to modify my frig by placing a heater. 2 The refrig side is not gettinG COLD ENOUGH - MY MILK...
The tech is full of beans. The heat from a normally charged refrigerator is more than enough to evaporate water in drip pan.
The indication of improper charge is that obvious. Fridge warm freezer ok would be a coil blocked with ice, however drip pan overflowing is a charge problem, Ask for a field supervisor.
Dec 24, 2010 | Whirlpool 25.3 Cu. Ft. Side-by-Side...
I have a Jenn-Air side by side frig. The freezer side cools too cold, the frig side not enough. 2 weeks ago I took all the food out of freezer and noticed ice build up on back. I unplugged unit, let it...
If the freezer is staying cold it sounds like a defrost system problem. A bad timer, heater or thermostat can cause frost to build up on the coils and block air flow to the refrig side. Check out ACMEHowTo.com for troubleshooting the defroster problem.
There is a small duct between the freezer and refrigerator side if this is blocked the frig side won't cool.
Jan 09, 2010 | Jenn-Air JCD2389G Side by Side...
Freezer fine refrigerator is not as cold as it should be. dial is set to coldest position. butter is soft and milk is on verge of spoiling
do you notice ice built up on freezer section back wall if so you have a defrost problem if not you have a freon problem also make sure the freezer setting is not on its coldest setting this actually controls the air flow to the fridge section both freezer and fridge need to be set about half way
Jul 12, 2009 | Refrigerators
Sub zero
Is ice on the back cover on the left side? if it is you have a leak in the evaporator... if its under 12 yrs old call an authorized sub zero service it will be covered
Jul 30, 2008 | Sub-Zero 661/F Side by Side Refrigerator
Maytag side by side freezer ice build up
I HAVE A MSD2454GRW, 23.5 CU, MAYTAG AND ICE BUILDS UP ON THE FLOOR OF THE FREEZER TO A POINT WHERE IT RUNS ON THE FLOOR. CAN CLEAN IT OUT AND 12-15 HOURS LATER, ITS BACK.
Jul 20, 2008 | Maytag 25.6 cu. ft. Wide-By-Side...
Amana neither fridge nor freezer getting cold enough
the defrost system has failed. to get it working temporarily, take the back panel off inside the freezer. melt ice off with a hairdryer.
after that, fault can be in several areas - defrost heater, thermal fuse or the main pcb
Jun 30, 2008 | Refrigerators
Side by side Sub Zero not cold enough.
How old is "OLDER" ? If there is no frost buildup on the back wall of the freezer you could have one of two problems. On older units the compressor wears out with years of service and no longer pumps efficiently. Or it could possibly be low on refrigerant charge. ether one of these two problems is a sign that is time to update to new unit.
If you have frost buildup on the back wall of the freezer section you then would have a problem in the defrost circuit attributed to the timer, defrost heaters or defrost thermostat.
Jun 11, 2008 | Refrigerators
Frig not cooling and now freezer is frosting
Val sounds like a defrost problem..go ahead and defrost your freezer again... check your evaporator drain your fan motors let let me know and I can help you Krazytech
Mar 27, 2008 | Maytag MZD2766GES Side by Side...
Refrigerators Logo
129 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Marvin
Marvin
