Question about Tascam Audio Players & Recorders
What is the ohm value of the input volume controls on this amp?
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
    Scholar:
  • 63 Answers
For the Tascam DP-01 Digital 8-Track Portastudio, here are some of the specs:
  • Analog specifications
  • Inputs (A And B) 1/4" Phone (Unbalanced)
  • Input Impedance: > 10k Ohms (Max), Or 1 M Ohms (A Only) With Switch In
  • Guitar Position: 2.4 K Ohms
  • Nominal Input Level: -10 Dbv -
  • Maximum Input Level: +6 Dbv
    Effect Return 2 X 1/4" Phone (Unbalanced)
  • Input Impedance: 10 K Ohms
    Stereo Mix 2 X 1/4" Phone (Unbalanced)
Courtesy of Musicians Friend
Posted on Mar 27, 2011
Volume control not working
Left and right wires are like the ends of a carbon resistor.
The centre connection is the slider that slides along the carbon resistance.
Spray inside the device,
The centre sliders often loose connection from overuse.
Carefully take apart and clean & put slight tension back on centre slider.
Look to see if carbon track is worn out?
Take the centre wire off the Pot and try it on either end.
One will be full volume the other will be lowest volume.
Read the Ohms value of the Pot (stamped on)
or use a cheap Ohm section of MultiMeter
Note the size of threaded area
Get similar to take it's place
1M 24mm Potentiometer Linear Single Gang Potentiometers Resistors Passive...
Potentiometer Wikipedia the free encyclopedia
Sep 19, 2015 | Audio Players & Recorders
Volume control is too loud at minimum settings.
Just check thislink out..
Click here
Goodluck,
Please don't forget to rate me as fixya..
Feb 07, 2008 | Audio Players & Recorders
How can I connect a Realstic STA-960 reciever to my Fisher CA-276 amplifier
You can link them using Tape Rec Out on one amp and connecting it to one of the Line Inputs on the other. This will allow the same signal to be played out from both amps. Each amp will power its own speakers. The volume controls will need to be operated on each amp, IOW, they aren't linked.
If your idea was to link the amps to somehow boost the power then you're out of luck. You can't multiply power up in that way. Connecting the speaker outputs of one amp to the line inputs of another will just blow the input circuits.
Speaker output is anything up to 30 Volts and could be anything up to 8 amps when the speaker impedance curve dips to its lower ranges. Fortunately the input impedance of a Line In is generally very high; 10,000+ Ohm. So the input circuit won't draw that much current. The problem is voltage.
Line inputs will accept something in the region of 1~2 Volts from a source signal. That's equivalent to roughly 1/3rd of a Watt @ 1V. The volume control wouldn't be much higher than its lowest setting. As soon as you crank up the volume even a little higher, you'd overdrive the Line Input stage on the receiving amp. That would result in.... first.... massive distortion which would cause the speaker voice coils to overheat and short (High distortion = Dead speakers = Not good). Then the input circuits would fry and kill the receiving amp.
So, all in all, a very bad idea.
Sep 01, 2014 | Audio Players & Recorders
Telefunken TLC037fhda no sound picture good
take a look at the speaker,use a multimeter see if the speaker have the rated resistance.( eg .8 ohms) if speaker bad replace if.if speaker good. see if your audio amp is getting power (multimeter needed) set to d.c volts.have voltage then look for the input pin that brings audio into the amp,use a 16 -32 ohms speaker across gnd pin and input pin(bring volume up hi on tv) if audio replace audio amp.
(also look for cold solder) on p.c board before replacing amp.
May 23, 2014 | Televison & Video
What should my setting be on car stereo...Keeps shutting off subs at half available volume.
If your amp is shutting off when you turn up the volume it means that it's clipping. This is very bad for both your subs and amp. The reason this happens is because your amp doesn't supply enough wattage for your subs and the capacitors are being drained of power causing your subs to cut out. As far as ohms this is not a setting. It is resistance and is very very important to have your ohm load correct or it can cause damage to your amp n subs. For a better understanding of ohm loads visit http://www.the12volt.com/caraudio/woofer_configurations.asp and put the number of subs and the ohm value and it will give you the wiring diagrams for the different ohm loads. then u need to look at your amp manual to see what ohm loads it is stable at.
May 14, 2014 | Virtual Reality VR3 Car Amp
I hav a Silvertone sslb11 bass that needs a new volume pot and don't know wich one to buy. I don't see any part numbers or values printed on the pot. Does anyone know part numbers, brand, or...
I recommend checking music stores in your area for that, it doesn't have to be any specific rating of impedence. Depending on brand, I see guitars with anything from 50 ohms to 250 ohms. This only allows a faster cutoff on volume than others. The most critical action is to have a smooth taper, meaning a straight volume rise or decline versus one that goes down slowly or quickly and suddenly cuts off. Most any guitar volume control from a music store will work just fine. In case I confused you, ohms is the rating of the control, the taper or smoothness is classed as A, B, or C. A is normally for volume controls and B is used mostly for tone controls. Knowing that should give you insight insight to the difference of the controls.
Mar 31, 2013 | Music
Buttkicker Gamer 2 Amplifier won't turn on, light stays orange when it should be green. used to be a struggle sometimes to get it to turn green by using the remote, now it just stays orange all the...
Your Gamer 2 Amp turns on whenever an audio signal is present on the input. The amp can have trouble tuning on if the output of the source (computer sound card, etc.) has been turned down. This can happen easily if you use amplified speakers - if you turn the sound card's volume control down - and then increase the volume at the amplified speaker - the resulting sound is the same; even though the signal has been lowered. The problem is that the output from the sound card isn't sufficient to turn on the Gamer 2 Amp.
Try turning down the external speaker volume, then bump up the sound card volume. You'll probably need to adjust the other inputs individually (Wave, Mic, CD, etc) so that none is too loud or soft. Once the input values have been set, gradually increase the output of the sound card in the control panel application etc. while decreasing the volume on the amplified speaker to maintain a comfortable level. Eventually, you'll find the correct volume level on the sound card output that will wake up the Gamer 2 Amp.
If you're still having trouble, review the manual, here. I hope this helps & good luck!
Sep 20, 2011 | ButtKicker BKA1000-4A Amplifier
What is the ohm and taper value of the input pot on the Tascam PA-150 Dual Power Amp?
Hi doc2714,
The Ohm and Taper Value is " 4 ohms or 115W per channel at 8 ohms "
for more details here is a link providing you with full specifications to your Amp.
http://www.broadcaststore.com/pdf/model/19184/tascam_pa-150.pdf
I hope this helps.
Mar 27, 2011 | Tascam Audio Players & Recorders
When i turn the volume up my jl 1000/1 amp turns off then turns back on when the volume is low what can i do to fix this?
2 things, either your pushing too much power into the imputs (if using high inputs) and clipping the signal, or your running the ohms too low (lower then the amp can handle safely) by running multiple speakers of too low an ohm each. For example if your amp is 4 ohm stable and your running 2 4 ohm speakers in parallel that makes 2ohms and the amp can't handle a load that low. You can consult your manual and it will give you illistrations of wiring and ohm loads
Oct 26, 2009 | Jl Audio 1000/1 Car Audio Amplifier
How to adjust the controls and gain on my kenwood 9104d 1800w amp
Hook the speakers in series to decrease your chances of blowing the amp and/or speakers themselves. And at high volumes make sure that the bass control is set for flat response.
Jun 25, 2017 | Car Audio & Video
245 people viewed this question
Top Tascam Audio Players & Recorders Experts
Sam Palermo
Sam Palermo
John
John
Michial Gueffroy
Are you a Tascam Audio Player and Recorder Expert? Answer questions, earn points and help others
