Question about Sony (crx300e) CD-RW/DVD-ROM (Combo) Burner
Hi , my cd rw crx300e does not respond to discs at all.i may have deleated components, all drivers are up to date,can i check this ?
  • Sony Master
  • 27,725 Answers
Make sure that the cdrw dvd rom is getting enough consistent power test all leads that are attached to the cd rom including electical extensions and make sure they have a secure connection or just replace them there might be bad/faulty or
your drivers may have been corrupted or you might have a virus run your antivrus program
you might have to physically unplug the leads for this cdrw dvd rom then plug them back in this will activate found new hardware wizard
hope this helps or
you might have to uninstall then restart your computer then reinstall your cd rom or uninstall the driver then reinstall for this device
also
click start control panel administrive tools computer management device manager scroll down cd dvd rom drives right click you can you will have options to update driver roll back driver select properties general troubleshoot select driver click to reinstall drivers click update driver uninstall then reinstall
you need only do the registry check if you cant see the drive/s in windows explorer/my computer
it might be a registry problem
Close all open programs
Click on Start, Run, and type regedit and press Enter
Click on the plus signs (+) next to the following folders
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
{4D36E965-E325-11CE-BFC1-08002BE10318}
This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
After deleting the keys, close the registry editor
Reboot your computer
Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone.
hope this helps
Posted on Mar 27, 2011
The problem with nero to burn the copy cd/dvd
try this one try to copy everything you want to burn through cd/dvd intothe computer then you can now burn it....
plz like if this is helpfull.....ty
May 17, 2011 | Sony (crx300e) CD-RW/DVD-ROM (Combo)...
I have a 3 dongle hardware is zte i have windows vista and everytime i put the mobile dongle in it says e:\ win32 not a valid application help!!!! please
Hi leigh_Hall86,
It seems that you're running a 32 bit version of the software on a 64 bit operating system. Or the driver is not longer supported by modern Operating systems. To fix this issue try finding and installing the right driver.
Hope this helped
-Luchen
Mar 10, 2011 | Sony (crx300e) CD-RW/DVD-ROM (Combo)...
SONY CDRWDVD CRX310Sreads CDs but not DVD.
hi
becoz you have a CD writer not a dvdRW it will burn only CD's not DVD's
both lence are diffrent
May 21, 2010 | Sony (crx300e) CD-RW/DVD-ROM (Combo)...
Driver cannot read blank disc
I recently installed a dvd writer for my neighbor. they used a top brand dvd-r / rw and never had any problem. but after the new install they had the same problem . after visiting the manufacturer's website we found that that certain brand of dvd were recommended. check the manufacturers site for dvd recommendations.
Sep 11, 2009 | Acer (4432A-002) CD-RW Burner
I have cobo drive, drive can read and write DVD's but not CD's
Hi there. You may need to re-install your drives.
Open Device Manager, click the + sign next to DVD/CD-ROM drives. Right-click on the drive and choose Uninstall Driver. Shut down your system, and restart. When Windows starts it will detect the new hardware and install the software for it.
Also, try uninstalling your burning software, restart, and re-install. It may be that the software has got corrupt.
Hope they work, and let me know if they do or don't.
Thank you
Tim
Dec 08, 2008 | Sony (crx300e) CD-RW/DVD-ROM (Combo)...
BIOS and Sony CD-RW CRX300E
Your Sony CD-RW is an ATAPI CD-ROM for the purpose of your BIOS. Without you specifying the motherboard brand and model, it is hard to tell you what your issue could be.
Nearly all PC motherboards made after 1995 will allow you to boot from the CD. Enter the BIOS setup screen by pressing, during POST, <DEL> or <CTR>-S (Gateway), <F1> or <F2> and look for boot sequence. Some MB's have a boot sequence key you can press to select the boot device for that boot instance only.
If you are trying to say that you have an ATAPI CD-ROM and the Sony CD-RW, then check your master/slave/cable select jumper settings on the device. Each IDE channel can have at most one master and one slave.
Jul 13, 2008 | ASUS Computers & Internet
CRX300E Combo
http://www.youtube.com/watch?v=-Xr71sWVacI
May 01, 2008 | Sony (crx300e) CD-RW/DVD-ROM (Combo)...
Samsung TS-H492 CD-RW Combo
are you using a single IDE cable with your H/Disk? if yes! check, the jumper connections of your CD-ROM,maybe the are both in the master position ,change the jumper of your CD_ROM to slave position.or use another cable for your CD-ROM.if doe'snt work go to BIOS SETUP,set the settings to default SETUP.then restart your PC.
Mar 10, 2008 | Samsung TS-H492 (TSH492AWRBH)...
Sony CRX300E CD-RW/DVD-ROM Combo - DVD doesn't read
do you have software/program that supports DVD.
Try a different DVD/Movie/Disk or alternative.
Also install a program, such as Nero which will give you physical characteristics of the drive.
Finally go to device manager, and remove or uninstall the device, reboot the computer and setup again. This can sometimes remedy the problem.
ensure that the drive is set as Master/Slave. if on the same Bus/IDE channel as a hard-drive. set as master/slave opposite to what the hard-drive is setup as.
Hope this helps.
Mike @ Compurepair.
Feb 24, 2008 | Sony (crx300e) CD-RW/DVD-ROM (Combo)...
Sony (crx300e) CD-RW/DVD-ROM (Combo) Burner Logo
Top Sony Computers & Internet Experts
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
