Question about Canon ImageRUNNER 3570 Copier/Printer
I have a canon IR3570 and Im trying to set up the scan feature to scan directly to a pc in a pdf form. everytime I try it, it gives me an error and I never receive the scanned doc.
SOURCE: canon pixma mp830 will not scan
I am experiencing the same problem, from the equipment id does not scan
Posted on Jun 09, 2008
Fixe_You
  • 1800 Answers
SOURCE: I CAN'T SCAN ANY DOCUMENTS WITH MY HP J6480
hi
try this official link i think that will really help u out
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00710491&lc=en&cc=es&dlc=es&product=421990&rule=39296
plz do rate this post
Posted on Dec 12, 2008
  • 168 Answers
SOURCE: Canon ImageRunner Scan feature won't connect to network
its waiting for the command from the computer. in order to use scan you have to down load the canon scan tool from imagerunner.com / support/ downloads/ office products/ then canon network utilities. look for network scan gear tool ... down load save open run setup then open the program and you can either let it search for a scanner or you can put in the IP adress for the copier. then under your scanning software ( ADOBE PRO) eg. you selesct the scan gear tool as the scanner. to scan a doc you put paper in feeder select scan online then from your computer tell your software to scan good luck
Posted on Jan 03, 2009
SOURCE: Canon MP500 keeps cropping scanned docs
i was having the exact same problem -- very annoying! just go to the following link and follow the instructions. VERY quick and easy!!!..... http://support-au.canon.com.au/contents/AU/EN/8000507501.html
Posted on Feb 10, 2009
SOURCE: Can't save my scans in pdf form
This can possibly solve your problem:
0. you should have the CD that came along with the printer. the solution that is listed below is working for windows xp operating system.
1. Browse the CD -> Go to the Setup folder. -> Go to the DocProc folder. -> Double-click Docproc.msi to install. you will not see any progress etc.,
2. Browse the CD -> Go to the Setup folder. -> Go to Qfolder . -> Double-click Qfolder.msi to install. same as above.
3. Go back to your HP solution centre and under scan settings option you shhould get to see the PDF options (and a few others as well).
cheers
Posted on Aug 11, 2009
How can I install "scan" option in display of Canon irc3170 printer?
http://www.usa.canon.com/cpr/pdf/Brochures/copier_c3170_spec_sheet_rev.pdf
Canon Contact Us
According to the Cannon web site, the 3170 series printers do have the scan feature. I suggest you contact Cannon directly for information about the scan feature.
May 01, 2014 | Canon imageRUNNER C3170U Color Copier
Canon copier ir3570 error code E000733-001
Reconnect DC controller and power supply,check connection with the printe
Dec 22, 2012 | Canon Office Equipment & Supplies
I have ir4570 error code e00007
It is my pleasure to guide you.
Your Canon iR 4570 All in One Printer Manual iR4570
User's Guide can be downloaded at http://download.canon.it/manuali_operatore/files/iR4570_USR_ENG.pdf
Look at Chapter 3 Troubleshooting
List of Error Messages ..3-6
List of Error Codes without Messages. . 3-6
You will find the list of error codes.
Also, http://servisfc.blogspot.com/2010/12/detecting-error-e007-for.html
gives the following;
QUOTE
Detecting Error E007 at canon copier iR2270, iR2870, iR3570, iR4570, iR3530.
As part of its protective mechanism, the machine checks for the following error conditions.
Error Code: E007
Detail: 0000
Sympton: The fixing film rotates in an abnormal way.
Description: The reading of the main thermistor is in excess of 100 deg C with the fixing motor in a locked state and in addition, the machine fails to detect the marker signal for 6 second.
UNQUOTE
Good luck and please post back that you are successful, giving thumbs up, or that I can be more helpful.
Jun 09, 2011 | Office Equipment & Supplies
Ir3570 Takes Half Hour to start printing 3 pages - help!!!
Sounds like you have the wrong driver installed, go to canon website and download a new driver for the machine
Jul 06, 2010 | Canon ImageRUNNER 3570 Copier/Printer
Auto detection can not be set as default
A 'Driver' is only the software portion to connect two hardwares. You need to install a printer driver for Printer, or a DVD driver for a DVD drive. Similarly, the scanner driver just connects the scanner to the computer.
You need to use a Scanning software to use the scanner. Canon offers CapturePerfect 3, using which you scan documents, do rotation, convert to PDF etc. CP3 has option to detect the page size. CP2 is available free of cost from Canon sites. CP3 comes with the scanner.
S. Mohan, Chennai, India
Apr 01, 2010 | Canon DR-5010C Scanner
How to find the IP Address canon IR3570
you should be able to go through the print menu on the printer and look for something that says information or configuration and look for network settings and print this page.
ADDITIONAL FUNCTIONS>SYSTEM SETTINGS>NETWORK SETTINGS>TCP/IP SETTINGS
Nov 25, 2009 | Canon ImageRUNNER 3570 Copier/Printer
Acrobat and Canon DR-9080C not working
You are right, it is driver related issue. Acobat 9 has more features that may not be compatible with the existing driver. may be you can use CapturePerfect and directly create PDF and then use the Optimising features of Acrobat 9. Ofcourse you have to do it twice, but you can use the 'batch' process and do it automatically.
S. Mohan
Jul 09, 2009 | Canon DR-9080C Path-Through Scanner
An error message when i try to scan
On the CanoScan Toolbox program bar, select settings. Then hit the Browse button next to "Select Folder where Temporary Files are Saved" and go up one level to Canon from TB50. Then hit OK. This fixed the problem for me after Microsoft Updateinstalled updated Canon drivers. It looks like the geniuses at Canon are either having you write to a write-protect folder or one that only has system permissions and then giving you a disk-full error.
Mar 25, 2009 | Canon CanoScan LiDE 70 Flatbed Scanner
Canon ir 3570
Can anyone pls let me know the procedure to scan a document using Canon IR3570?
Mar 28, 2008 | Canon ImageRUNNER 3570 Copier/Printer
1,232 people viewed this question
old marine
old marine
