Question about Kenmore Sewing Machines
Will not go into reverse - Kenmore Sewing Machines
  • 3,230 Answers
Well when you push on the reverse button you should feel some resistance from the internal mechanism? If not, then the lever on inside is either broken or stuck. If you want to look at some of the reverse mechanism you may remove the bottom covers both for the base and the free area and locate the link lever that works the reverse. Then remove the top cover for more light so you can see better. Post comments for further help or information.....
Good Luck!!
Thanks for using FixYa!!
Posted on Mar 27, 2011
Will not sew in reverse when reverse button pushed
my kenmore 385.17526 will not go in reverse when I push ...
www.shopyourway.com > Manage My Life > Questions
my kenmore 385.17526 will not go in reverse when I push the button ... Having asewing machine that doesn't reverse can be a bit disappointing, especially ...
Sewing Machine Repair ' ThriftyFun
www.thriftyfun.com/tf/Home_and_Garden/.../Sewing.../index.html
Sewing Machine Won't Sew in Reverse. My Elna 3007 became temperamental atsewing in reverse some years ago. On occasion, I will need to push the button ...
Bernina 1230 Reverse Button Fix ' Temecula Valley Sewing ...
https://tv-sewingcenter.com/bernina/bernina-1230-reverse-button-fix
Aug 30, 2010 - The reverse button of the 1230 had been pulled or popped out of ... All I had to do to fix the button was to hold the button in, and then push the cap forward. ... My 1120 Bernina reverse button will not work and the person who ...
Dec 28, 2015 | Sewing Machines
I just replaced the motor on this machine and when started it only sews in reverse. To get it to sew forward, I have to push reverse lever down.
The motor may have to be reversed. The reverse action of a sewing machine is the feed below the needle is reversed not the machine.
Dec 07, 2015 | Sewing Machines
Where is reverse button
Depends on the make & model of your machine. Would be best to consult the owner's manual. Mechanical and computerized machines also vary. Mechanical machines usually have a stitch length lever that, when pushed all the way up, will reverse stitch, or there is a button usually marked with an R or an arrow. Computerized machines usually have a button marked by a U-shaped arrow.
Of course, if you have a vintage sewing machine, it may not even have a reverse stitch. Instead, to sew in reverse, one would have to sink the needle into the fabric, raise the presser foot and swivel the fabric 180 degrees, drop the presser foot and stitch.
To find a copy of the owner's manual, search the internet for:
Manufacturer + Model + the word "Manual"
sewing machine reverse Google Search
Dec 04, 2015 | Sewing Machines
Brother AE2500 reverse sewing lever is too stiff to move , how does this work please, bacause in the CD provided with this sewing machine , this lever (plastic) for doing reverse is being moved down t
Try turning the flywheel and operate the reverse lever at the same time. Some machines need to be at a certain point in the stitch cycle for the reverse lever to be used.
Dec 26, 2014 | Brother Sewing Machines
Bobbin bunching in reverse, I have adjusted all tensions and ONLY in the reverse I get a "rats nest" under my fleece fabric. Stitches beautifully but once you ask for a reverse, it is a mess
For all machines that I have experience the reverse button or control is only use to lock the finishing end of your sewing & if reverse all the way would not work right.
Oct 28, 2013 | Sewing Machines
I have a husgvarna Designer1and the reverse botton is not lighting up and is not going in reverse
The reverse button doesn't light up until the feed dogs reverse their rotation (feed rearward). The problem probably relates to the drive thats shifts the linkage to reverse the feed dogs (although it could be the linkage itself is out of wack). In any case, I doubt that you are doing anything wrong or that this is something you can fix yourself.
Jan 27, 2013 | Husqvarna Viking 1
Sews backwards..when I press the reverse button it sews forwards
Sounds like you have the timing precisely reversed. Time to try again.
Sep 10, 2012 | Singer CE-100 Futura Computerized Sewing...
Husqvarna Classic 100 sew machine , pressed reverse button, now it sew reverse only!!! Please help! i pressed, i hold, turned off and on, nothing....... any ideas?
There is a permanent reverse position on the dial button behind the reverse where the stitch length is located. Check to see if you have positioned the knob to permanent reverse. The setting looks like a "U" turn arrow.
Feb 18, 2011 | Husqvarna Scandinavia 100 Sewing Machine
Machine won't go into reverse
What model machine are we talking about here? If it is a Designer 1, Reverse doesn't show up on the screen. You need to hit the Reverse button twice in succession, the button stays lit up, and the machine should sew in reverse until you hit Reverse again or change stitch.
When a reverse arrow shows on the screen, it is usually when a programmable stitch is selected and you need to hit Reverse to complete the programmed task.
Get back with more detail on your machine and the problem, and maybe I can offer some more specific help.
Pamsquilt
Oct 17, 2008 | Husqvarna Viking 1
Machine sews only in reverse
Be sure you are in the correct stitch pattern...if you are on a buttonhole stitch or a stretch stitch it normal for the machine to sew backwards. Be sure your length is to the right of 0 and not in a strtch stitch model or buttonhole mode.
Bonnie
Jul 28, 2008 | Kenmore 15218 Mechanical Sewing Machine
Sewing Machines Logo
204 people viewed this question
Top Kenmore Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Douglas Plant
Douglas Plant
Are you a Kenmore Sewing Machine Expert? Answer questions, earn points and help others
