Question about Zodiac Speed Dragon watch #ZO5525 Watch for Women
Watch runs then stops. New battery. Pulling stem and depressing restarts watch. Watch runs slow for the period it does run. Run time usually less than one hour.
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 141 Answers
Tie your watch for some time to provide some heat anothervice you must be check it's lnternal parts........
Posted on Mar 27, 2011
New Gucci watch is not running, will taking off the plastic film with the red strip on the back make a difference.
That decal/sticker is usually only an indicator of a un-worn watch.
The only thing that will turn the battery on is pushing in the STEM.
If it does not run then... your battery SHELF LIFE has been
exceeded... Time to get a new battery
https://www.gucci.com/us/en/st/faq
Gucci offers a repair service for Gucci products purchased from Gucci.com, ... Watch Repairs* East coast: GTS 50 Hartz Way Secaucus, NJ 07094 tel 1.866.692.8244
Gucci Gucci
Dec 14, 2015 | Gucci Watches
I opened the package and dont know how to turn it on!
mcdevito75 Here, It must be a Quartz watch, look for a very small piece of plastic just under the stem, remove that piece of plastic, push the stem down and your watch should start. OR!! look on the back cover of your watch, carefully, if you see a plastic tab comming out of the back cover, remove by pulling carefully on that plastic tab, this plastic tab is keeping the battery from grounding, thus saveing battery power but also not letting your watch run. Simply reove this tab by carefully pulling on it.
Jun 17, 2011 | Watches
I haven't worn my fossil watch (FS 4337 model) for some time & decide to wear it & shook it, adjust it, & it dosn't work. Usually when I don't wear it for about 2 weeks, I shake it...
If you have a Fossil FS4337 Chronograph, shaking the watch shouldn't be doing anything other than exercising your muscles; the movement is a battery-driven quartz movement whose movement is controlled only by whether the stem has been pulled out (stopping the movement and saving power) or whether the battery still has enough power to activate the stepping motors that move the watch hands. Based on the symptoms that you've described, I would suggest that it's probably time to change your watch battery.
Often, when a watch battery is running low but isn't completely dead, pulling the stem into time-setting mode will stop the movement and permit the battery to "rest," giving it (briefly) a bit more reserve amperage to put out when you push the stem back in. That's how you can sometimes get a quartz watch to run for a few minutes after the battery appears to be dead. That may also be why your watch has started running again after you've set the time and date.
Fossil analog quartz watches tend to use silver oxide (usually #377 or #379) batteries instead of longer-lasting lithium batteries. In ordinary use, I would expect a silver oxide battery to provide between 1 and 2 years of service before it needs to be replaced. I can't remember if Fossil chronographs (which also use quartz movements) use a silver oxide or lithium battery. Lithium batteries often provide an additional year or two of service in analog watches, compared to silver oxide cells; digital watches using them supposedly may last as long as 10 years with a lithium battery, assuming you don't use the backlight or audible alarm functions. Note, however, that these batteries are different sizes and different voltages, so you can't substitute one for the other.
Finally, none of this advice applies if you have a Fossil watch with a true mechanical movement in it. In that case, gently shaking the watch may spin the winding rotor enough to start the watch back up again. However, an even faster way of winding those watches is to use the winding / time set crown to wind the mainspring directly instead of relying on the geared-down action of the winding rotor. Automatic watches can bind up if they are not used for a period of time; the lubricating oil used in some of the pivots can harden--or at least provide enough resistance that the movement may require more initial force to start running than to continue running. That behavior usually indicates that it's time to have the mechanical movement cleaned and re-lubricated.
May 31, 2011 | Fossil Brushed Brown Dial Chronograph...
Eco-drive watch stop working, after it was in jewelry box for over a year.
First, be sure that the stem is fully pressed in. Pulling out the stem to set the watch stops the action.
The Eco-Drive is still a battery watch. It just has a solar/light powered recharge system built in. The battery will run down after a year of no light. Place the Eco-Drive in bright sunlight for a couple of days in order to recharge the built-in battery. You may recharge the watch in fluorescent light as well, it just takes longer.
Dec 05, 2010 | Citizen Eco-Drive BL006056H Wrist Watch
Hi, I am a seiko 8f33 perpetual calendar watch. I just got it back from Seiko...had the battery changed and new band. the problem is that I tried to set the date and the watch stopped working. Does...
If your watch stopped working while changing the time it can be for a couple of reason . One is i never set the watch between the hours of 11 pm and 4 am or else your movement can be damaged. The main reason is usually that the watch crown was not pushed all the way in to the first set . If the watch crown and stem is pulled out and not in the start position the watch will not run. Also after setting time you might need to reengage the watch by pressing on the jumper buttons on the top side of the crown they look like push buttons.
Oct 17, 2010 | Seiko SKA192 Wrist Watch
Tag Heuer Tiger Wood Golf WAE1111.FT6004 Watch stops when not worn. Is there a problem
An automatic watch needs to be worn, wound daily or placed on a watch winder to keep it going. It is not like a quartz watch that has a battery and can keep going when not worn. A modern automatic watch will run for about 36 - 48 hours on a full wind.
A quartz watch that stops like you describe is in need of a cleaning by a professional watchmaker. When this stopping occurs it is an indication the oils have dried out and the warmth from your body heats them so they are semi liquid again and the watch runs. but when the watch cools again the oils harden and the watch stops.
Hope this helps,
Ken
Yellowstone Watch, Inc.
www.yellowstonewatch.com
May 21, 2010 | Tag Heuer Tiger Wood Golf WAE1111 Watch
Cannot shut it off permanently
Turns out (IN OUR OPINION)
That letting the watch run is far better than turning it off.
Due to battery draining over time, and Just fact that if its not running for an extended amount of time it may not restart.
If planing to leave it inactive for extended time have the battery removed if not just let it run.
Hope this tip helps.
Have had numerous customers come in and have battery changed in a watch that was working fine. stopped the watch and the watch would not restart. (Just our humble observation).....
R/
David
Feb 18, 2010 | Avalon Ezc Voice Series Low Vision Talking...
I have 4 seiko watches that no longer work. Most unreliable watch
mcdevito75 here, hello Diane, I'm afraid your jeweler is correct, and so are you. It is adviseable to pull the stem out to save the battery BUT, only if your not going to wear your watch for a long time, not just over night, here"s the problem!! the quartz mechanism and most of the works are plastic, and plastic while fairly flexable when new, gets hard over time, your pulling the stem to stop the watch everyday or even once a week most likely broke the switch in the mechanism that starts the watch, if so your only option is to replace the movement if you can get one. Pull the stem to stop your watch only if your not going to wear your watch for say 2 weeks toa month.
Feb 06, 2010 | Seiko Ladies Two Tone SUJ614 Wrist Watch
New watch not working
I would go and get the battery replaced. Watches will run off the battery even when sitting on the shelf in the stores. Replacement are usually less than $10 at the mall or check a jewelry store.
Jan 21, 2010 | Kenneth Cole KC1232 Wrist Watch
Luminox 3001 watch not keeping time
Because of the way they work, it's quite hard for quartz movements to run consistently slow - so if you find one getting behind, it's usually a sign that it's stopping intermittently. It would do no harm to check that the crown is properly pushed in after you've reset it, but my guess is that the watch will benefit from a new battery. A.
Apr 08, 2007 | Luminox Navy Seal Dive 3001 Wrist Watch
Zodiac Speed Dragon watch #ZO5525 Watch for Women Logo
109 people viewed this question
Top Zodiac Watches Experts
Ankit Chandel
Ankit Chandel
Ansel Alberto
Ansel Alberto
Are you a Zodiac Watch Expert? Answer questions, earn points and help others
