My picture are not the right color. they need to be restored. nothing on the computer is the right color.
  • 981 Answers
What color is missing; is there any theme to the deviation in color; and might the problem be your monitor? Check that out and reply under a more specific problem description than Generic PC Desktops. Learn to adjust your monitor in case it merely drifted, too.
Posted on Aug 04, 2008
SOURCE:
My dell optiplex 755 amber color on power botton. monitor display nothing
The hard drive, motherboard, or some other critical component may be failing, or just the OS or hard drive corrupted. If you have files that you do not want to lose, you could try this... Pull the hard drive out, and use a "USB Hard Drive Adapter" (available fairly cheap online) to connect the hard drive to a friend's computer, and save all the personal files (documents, pictures, etc.) you can to a folder on the friend's computer or an external hard drive. That way, at least you may not lose your files.
Then, you could try to do a Factory Restore or Reload on the computer, and if that works, copy your personal files back to your newly restored computer. Good luck.
Jun 17, 2014 | Computers & Internet
The colors of my laptop's sreen are inverted. I've tried everything I could think of (display settings, system restore,....), how do I fix this?
Click start control panel administration tools computer management device manager scroll to display adapters + to expand you might see a yellow question mark ? or exclamation mark ! or a red x right click select reinstall drivers You might need to upgrade your graphics card drivers. You might have to remove your graphics card to make sure the socket is clean restart your computer the reinstall it this should activate found new hardware wizard if your computer came with a mother board disk the drivers could be on it Click start control panel display desktop you can select a different desktop from the drop down list or a browse button where you can select different pictures this may vary depending on your operating system also you can change the settings for more or less pixels or from the drop down list pick the appropriate level of color range or troubleshoot also select advanced then general dpi normal , larger or custom settings
Always click APPLY after making any changes windows 7 Open Personalization by clicking the Start button, clicking Control Panel, clicking Appearance and Personalization, and then clicking Personalization. Click Window Color and Appearance. Under Window Color and Appearance, click the color you want, and then click OK. Note If you see the Appearance Settings dialog box instead of the Window Color and Appearance window, the theme might not be set to Windows Vista, the color scheme might not be set to Windows Aero, or the computer might not meet the minimum hardware requirements for running Windows Aero. For more information, see Troubleshoot problems with Windows Aero.
Feb 28, 2013 | Dell Latitude D820 Notebook
This happens when I start the computer. It seems like that I attach a disk, but I do nothing!
Have you recovered your computer recently? Because the PQService partition is a partition that allows you to restore your drive to factory defaults.
You might be able to right-click on "Computer," select "Manage," go to "Disk Management" and right-click on the drive ( should be labeled J: ) and select "Change Drive Letter and Paths" and click the "Remove" button.
I'm not sure what any of these commands are in German, but this picture should explain it.
Hopefully that will work.
Feb 07, 2013 | Computers & Internet
Display problem on my vaio VGC-LT23E desktop. Horrible resolusion. I tried to restore it to an earlier day but still same problem. Now it is not connecting to the internet either. Please help...
Both issues are from the restore most likely. I would say both are driver related issues. Max color when no driver is present is 16 colors and low res.
Go into the device manager.
  • Right Click Computer and select Properties
  • Click on Device Manager
Any yellow ! or ? indicates a driver issue. You will need to go to sony's support page on another computer and download the drivers
http://esupport.sony.com/
Comment back if you need further help.
Sep 18, 2011 | Computers & Internet
I am trying to change color laserjet 2600n back to English and need some assistance. can you help?
Restoring the factory-set defaults
Restoring the factory-set defaults returns all of the settings to the factory defaults.
To restore the factory-set defaults
1 (LEFT ARROW) or the (RIGHT ARROW) button to select Service, and then press
Use the
(SELECT).
2 (LEFT ARROW) or the (RIGHT ARROW) button to select Restore defaults, and then
Use the
press (SELECT).
The device automatically restarts.
Then you need to change the default settings back to what they were.
Oct 19, 2010 | HP Color LaserJet 2600n Printer
Slight yellow tint to the color.
replace the coolant in the picture tubes that will restore the color and the clarity. Heres a link to the kit which has the coolant and step by step instructions.
http://servicemanuals.vstore.ca/product_info.php/pName/phillips-crt-coolant-replacement-kit/cName/repair-kits
Apr 24, 2009 | Philips 51PP9303H Rear Projection...
Lexmark X1100 printer will not print black
I came up with a work around for printing black.
I changed the black cartridge with the color cartridge.
Then when I have a letter to print, I change change (or write) the letter text to yellow, red or blue.
Then I can print out a letter.
By printing the text as yellow, red or blue the cartridge will try to print with only 1 color, but will print out black.
If you do not use one of these primary printing colors the out put will be unusable.
I can not of course print out pictures.
Oct 04, 2008 | Office Equipment & Supplies
Picture dark - colors not true
What kind of computer are you using and what are the connections to the projector.
Apr 30, 2008 | Dell 3300MP Multimedia Projector
New Acer computer
Hey i guess the Video card drivers are uninstalled. My suggestion if you have not made any major changes post this accident do a system restore, alternativly you can allways uninstall video card and install it back.
heres how you do system restore.
Through the All Programs menu:
1.
Click Start.
2.
Point to All Programs.
3.
Point to Accessories.
4.
Point to System Tools.
5.
Click System Restore.
6.
Follow the instructions on the wizard.
For device manager
http://www.microsoft.com/windowsxp/using/setup/learnmore/devicemgr.mspx
let me know if this dosent work.
Dec 20, 2007 | Computers & Internet
Computers & Internet Logo
Ekse
Alun Cox
