Question about Teac AD-500 CD Player
Cd tray won't stay shut and play. It keeps on opening.
JVC xl-fz258 won't open to eject cd, won't play
The basic problem is that the drive mechanism has failed. The problem with CD ejection can be caused by binding in the tray or a weakened ejection motor
Dec 02, 2012 | JVC XL-FZ258
Magnavox ZC320MW8 door stays open
f the tray won't open or close properly, check the belt for dirt or wear. Then check the tray for misalignment. If needed, remove, clean, lubricate, and reinstall the tray following the instructions in the owner's manual.
God bless you
Sep 27, 2012 | Magnavox ZC320MW8 DVD Recorder Refurbished
Cd draw opens on power up and won't play a cd keeps opening after closing
This unit needs replaced it has seen better days sorry. The only thing you can try is shut off all power to the PC then unplug the PC and that cd drive from the rear of it. let the PC boot all the way up so you see your desk top. Shut it all the way down un plug PC hook back up the wires on the back of the CD player let it boot back up see if this stops it.Remember to rate my solution this is how i earn my achievements also testimonial Thanks much in advance.
Apr 22, 2012 | Dell Dimension 3000® Pentium® 4...
My door will not stay shut to play a game what is wrong.my ps2 door was not opening so we thought we fixed it but now it wont stay shut . all lights are on just wont stay shut to even read/play any games...
the tray doesnt stay in. does your ps2 sit on its side where the tray is sideways, or is it straight up? i think you should try rotating it to a point where it should stay shut.
Feb 11, 2010 | Sony PlayStation 2 (PS2) Console
Cd tray is stuck in open position on my HP computer
In Some Cases The Button May Be Stuck In Causeing It To Keep Pushing It Open In Other Cases The Arm May Just Be Stuck To Extending The Tray Out. I Recommend Seeking A Computer Technician If You Do Not Know Anything About Computer Componants
May 12, 2009 | HP Computers & Internet
THE DVD TRAY KEEPS OPENING
check if the power hubs on the back of the back of the drive are hooked up right if they are un hook and hook back up while your pc is off
Mar 13, 2009 | LG GSA-H55N DVD-RAM Burner
Cd tray not staying closed
gently push the cd door back in while pushing the door closed button , untill it closes if it still comes out then the cd laser mechanism is not lifting or something else has happened , then it will need to be tested to determine the exact cause
Oct 16, 2008 | Memorex MKS5001 Shelf System
Cd/dvd drive won't stay shut
I have the dv9000z. If I do NOT push the DVD drive tray all the way in until it CLICKS shut, then it OPENS again after 1-2 seconds. This is normal. I have found that most times when I close the DVD tray drive, I am not pushing it in far enough, because the top of the DVD tray is rubbing against the laptop's case. If I just press down VERY SLIGHTLY and push the DVD tray in, the tray will fully close and CLICK shut. This works for me. Good luck.
Jun 30, 2008 | HP Pavilion dv9000z Notebook
Cd tray on my 360 wont stay shut
either you will need it repaired or u can do it the cheap way and after the disc tray is shut put some tape over it and see if it will read it still. If not it will need to be repaired. It will only cost about $35 or free if you are still under warranty.
Feb 14, 2008 | Microsoft Xbox 360 Console
Teac AD-500 CD Player Logo
37 people viewed this question
Top Teac Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Teac Audio Player and Recorder Expert? Answer questions, earn points and help others
