You can download the complete instruction manual in PDF format by clicking this link.
You'll require Adobe PDF Reader installed on your computer to view the manual. If it is not already installed on your computer, download it free from: http://get.adobe.com/reader/
Hope this solves your problem. Thanks for using FixYa.
Question edited for clarity. Please include model number.
Question moved from Food Processors category.
Use a thin pointed object, such as a wooden skewer or thin screwdriver, to push in the RESET button. 3. Check the assembly: Ensure that the heating element assembly is correctly assembled on the base of the fryer. Make sure it is properly installed and locked into place.
Normally the neutral lead of the lamp is a different color. If you have a ohm meter you can use it to look for a short between two terminals, this is the switch. The lamp is likely a neon lamp that you can not read with a meter, neon must have over 60V to light.
either there is grease- built up oil in the timer or the timer unit has failed, parts for these fryers are expensive so my best offer on an option is to replace your fryer.
You can find replacement cords for many counter top appliances at most appliance and building supply stores. Try Ace, Home Depot, Lowes. Take the cooker with you to make sure you are getting the correct cord.
