Question about Samsung Televison & Video
I have the Samsung LED DLP Model number HLT6187SAX/XAA, Version RE01, Awhile ago while i was watching a movie the tv went black with just the audio still working. I turned off the tv than turned it back on, it came back on but with a blue green tint, it kept flashing blue. I took it apart and cleaned the heat sinks on the LED's as they were very dusty. Now it works fine but with out any red colors. I believe the red LED burnt out. Is there only one light engine for all the LED's or does each LED have it's own light engine? Also what is the proper voltage to the LED as I dont want to spend $130 only to have the new LED burn out right away.
  • Sid Schmidt Apr 10, 2011
    solved problem myself installed new red led.
  • 218 Answers
SOURCE: I have a HDTV DLP TV HLT6187SAX/XAA I have problem
He is talking about the HLT6187SAX/XAA which is an LED model not the HL-T6187S model which has a lamp unless he gave the wrong model number in the original post.
Posted on Apr 06, 2011
  • 147 Answers
SOURCE: TV won't stay on. Green & Red light timer-lamp (Green) stand by/temp (red) flash.
Most likely needs a new lamp. Easily done yourself.
Posted on Apr 15, 2009
ladywinn
  • 5138 Answers
SOURCE: No picture
Replace Lamp
Posted on Dec 12, 2009
  • 150 Answers
SOURCE: Samsung HLP5063WX/XAA 50" DLP
Here is a site for ColorWheel replacement, which is what you need to do if you hear that screeching or fan running noise coming from your TV. Sometimes the wheel just explodes which gives you no picture.
http://www.jangro.com/electronics/samsung-dlp-replace-color-wheel/
Posted on Jul 13, 2010
SOURCE: We replaced the lamp on our Samsung 50
    1. Ensure that the TV is off. It may be advisable to unplug the TV as well.
    2. 2 Using a Phillips screwdriver, remove the single screw affixing the lamp cover (the small, grill panel on the back of the set) to the chasis. There is also a grill that is held in place by tension. Just "pinch" the thumb clamp on the bottom of the grill and slide it out. This is the same procedure you would perform to change the lamp, except in this case you will not need to remove the lamp itself.
    3. 3 Inspect the spring-loaded blue safety switch to ensure it is making good contact when the panel is secured. The switch should deflect downward when the panel is replaced. If the contact with the panel is suspect, very gently bend the metal bracket on which the switch is mounted.
    4. 4 Replace the grill cover and the lamp door, and continue to enjoy your TV.
    jQuery('.article ol .image').each(function(i,e){ var $this = jQuery(this); $this.find('img').error(function(){ jQuery(this).remove(); $this.remove(); }); });
  • 5.Check some basics first. Make sure the sleep timer on your TV hasn't been turned on, telling your set to turn off at a certain time. If your DLP TV is acting erratically, Samsung recommends turning the set off and unplugging it for 30 minutes. After 30 minutes plug it back in and turn it back on. Unplugging the set resets it, and that may fix the problem.
  • 6 Check your power supply. Make sure your Samsung DLP is securely plugged into a working outlet. Plug the TV into a different outlet to see if the problem still exists. Make sure that a fuse hasn't blown in your house or a circuit breaker hasn't flipped.
  • 7 Replace the lamp. If your Samsung DLP is shutting off or won't turn on, a bad lamp is the most likely cause. To replace the lamp, remove the lamp cover from the back of the TV by removing the screws with a Phillips screwdriver and slide it out and away from the TV. Remove the screws on the lamp assembly and slide it out of the TV. Disconnect the old lamp and insert a new lamp into the assembly. Slide the assembly back into place and replace the screws. Do the same for the lamp cover.
  • 8 Check for signs of overheating. Samsung DLP TVs generate a sizable amount of heat. If the components inside the TV get to hot, the TV will shut itself off as a protective measure. Make sure your DLP is out 12 inches or so from the wall. Make sure that all of the vents on the set are clear of any obstructions. Allow the TV to cool down for 30 minutes before turning it back on.
  • 9 Contact Samsung. If none of the above tips help, it's time to contact Samsung, as the problem is likely something that should only be fixed by a qualified service technician. More serious problems may include a bad power supply or a bad ballast. Attempting to repair those yourself will void your warranty and may cause more serious damage to your set.
  • The safety switch exists so the user does not accidentally remove the lamp door while the TV is on. Doing so could, theoretically, result in burn or electrocution. This spring loaded switch causes the TV to shut down when the door is opened.
  • Since the TV's chasis is plastic, expansion and contraction can cause the switch to lose firm contact with the lamp door. The TV's behavior could then be such that after being on for a while (getting warm) the plastic expands and the switch loses enough contact to cause the TV to shut down. The frequency with which this phenomenon occurs is not only dependent on the internal temperature of the TV, but also the ambient temperature of the room as well as the relative tension on the switch itself. The user's perception is that the TV starts up fine, but then "randomly" turns itself off after being on for a while.
  • If you have recently moved your TV, it is very common for random shut-downs to occur. This is because the move has shifted the flimsy plastic chasis of the TV, thereby loosening the contact between the lamp door and the switch.
  • Make sure your TV is off and cool when performing this procedure.
  • Posted on Aug 31, 2010
    I have a 50" Samsung tv. The tv turns on and the screen comes on, then within 1 minute the screen goes black. I can still hear sound.
    Samsung HL-R5087W TV screen goes blank -tv/sound on - Forums ...
    www.cnet.com > Forums > Samsung
    CNETJun 11, 2015 - About a month ago, the at various times the tv screen would go blankeven though the tv ... Try turning off the cable/sat box when the happens. ... In reply to: Samsung SP50L7HX DLP TV linked to Sky HD box - same problem .... on it comesback to normal. however, once it went off again (Black Screen) after only 2-3 minutes. ln-t4069f picture problem lcd warmup - Forums - CNET
    Jun 11, 2015
    Samsung LCD TV LN-T5265F Black Screen Diagnosis Help ...
    Jun 11, 2015
    More results from www.cnet.com
    TV with Black Blank Screen Repair How to Troubleshoot ...
    ? 3:16
    https://www.youtube.com/watch?v=kFdVi2ejfzA
    May 8, 2014 - Uploaded by ShopJimmy.com
    TV Repair Help for a TV With a Black No Image on the Screen ...Sign in to add this video to a playlist. ... LCD & LED TV Repair - No Image & Blank Black Screen Flashlight ... Easiest TV repair - How to Fix Power [TV turns off, freezes, or won't ... 1:26.Samsung LED TV Blank Screen & No Backlights Basic ...
    Samsung TV screen goes black w/ audio still playing ...
    ? 1:49
    https://www.youtube.com/watch?v=L9cjcsysdW4
    Sep 11, 2012 - Uploaded by Roberto Ramos
    TV screen begins to flicker then screen turns black while the audio continues to heard. I'm unable to see the TV Menu options when screen turns off. ... After turning the TV OFF then back ON again, the screen will flicker and then ... 1:26. Samsung LEDTV Repair - T-Con Board Replacement - No Picture on ...
    Jan 28, 2016 | Samsung Televison & Video
    TV lamp has been replaced, still won't come on, no picture. When turned on, I can see a blue, kind of sparking light and noise starts and does this about three times. TV powers down and does this again....
    Samsung DLP TV Repair - No Picture - Replacing ...
    ? 2:41
    https://www.youtube.com/watch?v=pBTgk_C5FVU
    Jun 11, 2012 - Uploaded by ShopJimmy.com
    DLP TV Repair No Picture Bad Lamp Bad Bulb TV Won't Turn On DIY Samsung DLP TV Repair How to replace Faulty LampTutorial Click Here to ... Rating is available when the video has been rented. ... is a replacement for the following DLP Rear Projection TV models: ... SAMSUNG HLR6167WX/XAA
    Samsung DLP problems - Help! - ecoustics.com
    www.ecoustics.com > ... > Home Video Forum > Projection TV Forum
    Oct 26, 2009 - I have attached a picture of to show where the "Light Tunnel" is located. Upload ... So now I have a Samsung HLN5065W/XAA that I am willing to part out or sell as is. ... I replaced the ballast but the TV still won't turn on. .... The lamp has been sitting on a shelf until two weeks ago, when the TV went dark. Samsung DLP Light Ballast
    Apr 10, 2009
    Archive through October 26, 2009 - Samsung DLP problems ...
    Apr 8, 2009
    Samsung DLP Flashing Standby light
    Jul 1, 2006
    More results from www.ecoustics.com
    Jan 19, 2016 | Samsung SELECT HLR6167WX/XAA Rear...
    Is TI chip covered on samsung dlp model HLT6187SAX/XAA?
    I don't believe the manufacturer is covering this any longer, but you can try calling Samsung support at 1-800-726-7864 Call 1-888-899-7609
    Mon. - Sun. 9am - Midnight (EST) Hearing-Impaired (TTY) 1-888-899-7608
    Mon - Sun : 9am - 6pm (EST) Home Appliances Hours of Operations Mon - Fri : 8am - Midnight
    Sat : 9am - 5pm
    Sun : Closed Laptop, Printer, Galaxy Tabs (WiFi only) 1-800-SAMSUNG (1-800-726-7864)
    Mon - Sun : 24hrs
    the part# for your DLP chip is : 4719-001985
    see the following web site: http://www.samsung.com/us/support/contact
    the
    Jul 06, 2014 | Samsung DLP HL-P4663W 46" Rear Projection...
    I have a Samsung HLT6187SAX/XAA making a loud air noise, picture is good but making noise
    This noise may be coming from a Fan that's about to give up.
    www.aaatvservice.com
    May 24, 2012 | Samsung HLT6187SAX 61" DLP HDTV
    I have a HDTV DLP TV HLT6187SAX/XAA I have problem with the color, now all in green, red and yellow. the blue was gone. I want to know is that the problem from the lamp or the bulb?
    Jan 18, 2011 | Samsung HLT6187SAX 61" DLP HDTV
    Model Number HLT5676SX/XAA 56" Samsung
    your question does not help us or you as we do not know your problem .
    Jun 09, 2017 | Samsung DLP HL-P5663W 56" TV
    The tv went black no sound or picture. We
    U have a solid green light from the LED power light indicator right?U have this DLP tv for awhile like two or three years,and use it alots right?Never change the lamp and the ballast right?Change the lamp and the ballast should solved ur problems.
    Apr 01, 2010 | Samsung HLR5067WX 50" Rear Projection HDTV
    White dots on screen of 50 Samsung DLP
    Random dots or pixels failing on a DLP TV will be a bad DMD chip. This is a technician replace item only. The chip runs around 160 dollars list price. The part number will depend on which version the set uses and will be determined by the technician.
    Jul 23, 2009 | Samsung HLN567W 56" Rear Projection HDTV
    Connect laptop to TVs
    you have to set your laptop to send a signal to the television. there is a function option there that you need to press on the keyboard depending on what laptop model you have. for others its fn+f8. you just have to set your tv to pc and set your pc to send the signal.
    May 25, 2009 | Samsung HLT6187SAX 61" DLP HDTV
    Televison & Video Logo
    302 people viewed this question
    Jerry Greenberg
    Jerry Greenberg
