Question about Lanzar (MAXP154D) 15'' 2000 Watt Dual Voice Coil Subwoofer Driver for Small Enclosures Car Speaker
My friend has a lanzar max pro 15 (only one) he has it in a 4 cubic feet box and is not happy with the sound. Now i say make the box smaller about 2.5 but someone else says build the box even bigger. Who is right?
4 Suggested Answers
SOURCE: Subwoofer Box for four lanzar 15"
Any kind of enclosure that will hold four 15 lanzar in the back of my 1999 GMC S15 SUV.I would like to have the big tom drops for SPL.Also i will be playing some music form time to time and still i need the big (BOOM) for the SPL.I have one amp going to my sub just for my subwoofer it's a 3000 crunch mono amp.Lanzar say there woofer works bets with ports in the box. I just trying to fine out what is the best way to go for the big boom.
Thank You,
Wayne
Posted on Jan 28, 2008
  • 37 Answers
SOURCE: want to find out the best type of enclosure for 2
you best type of enclosure will be a sealed enclosure or you can build it with a partition in the middle seperating the 2 subs and port each side.
heres a link that will give you the specs for your sub
http://www.lanzar.com/manuals/MAXP104D-124D-154D.pdf
Posted on Sep 21, 2009
  • 24 Answers
SOURCE: what is the rms wattage on a lanzar max pro 15"
1000watts RMS and 2000 peak
Posted on May 31, 2011
15x14x9=how many cubic feet?
Square feet is calculated L x W so 10x10 would be 100 sq. feet, Cubic feet is calculated by L x W x H so 15 x 14 x 9 = 1890 cubic feet
Feb 22, 2015 | Microwave Ovens
What is the cubic feet needed to build box for audioban 12
You can use this speaker in either a ported or sealed box. A sealed box would be smaller, (sealed box volume: 0.5 to 1.25 cubic feet) the larger the box the more base you will get. With a sealed box your amp has to work double hard as it would in a ported box ( 1.3 to 3.2 cubic feet) You will get close to double the volume in a ported box. Tuning a ported box with the size and length of the port will determine the hertz the speaker will play at.
Sep 15, 2014 | AudioBahn AW1206T Car Subwoofer
Air space need sealed subs
Min volume .66 Cubic feet, Max 1.25 cubic for for the 10" sub,
Min volume .88 Cubic feet, Max 2 cubic for for the 12" sub
Nov 21, 2013 | Kicker Solo-Baric L5 Car Subwoofer
What air space for a sealed box should i use for my lanzar max10d subwoofers
a sealed box is designed to handle more power with a smaller box. to get max efficiancy or spl bass it is recommended to go with a ported or vented box but your speaker can't handle as much sometimes 200-300 watts less but bigger bass. so, sealed box is 0.85cu.ft-1.25cu.ft and vented or ported is 1.25cu.ft-1.75cu.ft.
Feb 01, 2011 | Lanzar MAX10D Car Subwoofer
Could me and friend install a lanzar max 15" sub into a 2004 honda accord??
Technically speaking, you can install whatever you want into anything you want to install it into. I recommed you doing your research first, because a good amp and sub install job is more than just plugging stuff up. And if your not upgrading to an aftermarker HU, fuggedaboutit!
Feb 22, 2010 | Lanzar (Pair) MAXP104D Max Pro Series...
I have a fifteen inch lanzar max pro p145d and want to put it in an 06 mustang. need to know how much air space i need to make it rumble right
I would go with a sealed because ur trunk is small and sealed would be the smaller box. I recommend 2.0-2.75 cubic ft sealed. for vented would be 3.25-3.50 after woofer displacement. Also I would recommend a reverse wedge meaning the woofer would go on the back side of the box not the angel side because u can slide the box in further saving u a little more room. I'm doing that same box now for the same sub but in a Nissan 2001 sentra. My box when done will be 2.78 cu.ft. After displacement. Sealed. 720 watt rms power acoustick 2ohm stable mono block to get longer life out of my sub.
Dec 18, 2009 | Lanzar OPTI1222D Car Subwoofer
2 15" and a 10" sub
10" subs need 1 cubic feet. 15" subs need 2.5 cubic feet. install them on its own volume of the box...
Jul 17, 2009 | Cerwin Vega IT-15.0 Car Subwoofer
Box recomendations
It depends on the size of the subs- 8z 10z 12z 15z? whether or not you port the box is up to you- a ported box is generally louder than a sealed box -as you are coupling and tuning the sound from the rear of the driver with the sound generated from the front of the sub- but the box is also generally larger as well.Then aside from your preference of ported/sealed you have to account for the recommendations of the manufacturer as to whether the sub/speakers are meant to be placed in a ported or sealed enclosure. Most 10 inch subs do well in a box that yields .75 cubic feet to1.0 cubic feet.most 12z do well in 1.0 cu feet to 1.5 subic feet and 15z do well in 1.5 to 2.5 cubic feet. I have a set of 15z that require 4.25 cubic feet per sub-so its important to look into the manufacturers recommendations. The easiest box to make would be a sealed enclosure-and the sound quality generally yields a tighter more accurate bass sound along with increased power handling capability- try going to rockford fosgate .com and look into the woofer box wizard its a program that calculates air space for whatever size box you have room for-hope that helps you-good luck
May 11, 2009 | Car Audio & Video
what r u trying to do ?shake the car apart?Only kidding that a good questin 4 15: woofers in 1 enclosure>?what kind of enclosure ?how much space r we working with ? i use to be a installer , i also built costume boxes.I need to knoew how much space u have is it a car van,pick-up?I think an iso baric enclosure woukld be your best bet, it would take up the laest space. What frequency are you going to be runnig to your subs? what do you want? punchy bass,over the big tom drops?
what amp r you running or should i say amps?
you'll get the highest spl in a sealed enclosure,but i dont think thats what your looking for.you want heavy vibrating soud,am i correct? a band pass box will give that to you in a close space.bass sounds better and louder the further away you get../.give me more info then ill give you a layout.but 4 now this might help or solve your problem
http://www.rockfordfosgate.com/rftech/woofer_wizard.asp
they have all the wiring and p[hyschics and designs of boxes. rating please.
Jan 25, 2008 | Lanzar OPTI1222D Car Subwoofer
Lanzar (MAXP154D) 15'' 2000 Watt Dual Voice Coil Subwoofer Driver for Small Enclosures Car Speaker Logo
69 people viewed this question
Top Lanzar Car Audio & Video Experts
Radames Pagan
Radames Pagan
Joe Alexander
Joe Alexander
Jose Velazquez
Jose Velazquez
Are you a Lanzar Car Audio and Video Expert? Answer questions, earn points and help others
