Question about Duravit 0910100005 Happy D Toilet Cistern - White
Hello I have a 'back to the wall' Duravit cistern and bowl purchased in 2004. The cistern is now leaking into the bowl (at a small rate) and intermittantly tops up. Can anyone suggest a solution
  • lydian Mar 30, 2011
    It sounds fine - I still have to source a washer and then dismantle the cistern to get at the washer
  • 32,281 Answers
The flush mechanism has a large rubber washer over the outlet.
This washer seals the flush outlet and allows the cistern to fill up. If there is a continual water leak into the bowl then this washer is worn and needs to be replaced.
This washer is a flat ring type approx. 50 mm in dia,
Posted on Mar 27, 2011
  • Chris Hingee
    Chris Hingee Mar 27, 2011
    If forgot to mention.
    This washer is located on the bottom of the cistern and is mounted on the flushing mechanism.
  • Chris Hingee
    Chris Hingee Mar 30, 2011
    Your plumbing supplier or hardware store should have these washers.
Adjust the water level in the bowl of a duravit toilet
You can't. Water level is set by the design of the trap built into the ceramic base. Can only adjust height of water in the tank.
Jan 07, 2015 | Duravit 0910100005 Happy D Toilet Cistern ...
How do i fix a leak from the cistern to the toilet bowl
There are bolts attaching the tank to the bowl check to see if they are correvtly tightened after you check to see if the gasket is properly seated.
Dec 25, 2014 | Home
How do I replace a toilet seat on duravit happy D toilet
I think our toilet is a Duravit.
Close the seat and the lid then have a look at the back of the hinges. If you can see a small hole in the back of the hinge there will be a grub screw in the hole and you can undo it with an allen key (not sure what size - you'll have to try a couple)
May 21, 2012 | Duravit 0910100005 Happy D Toilet Cistern ...
How do you get the water supply hose, which is behind the toilet to connect with the water supply valve on the wall? Duravit says the back of the toilet is slightly curved, but I don't see how the water...
Are the install correct ?I can't believe an install time frame where the technician is actually on time! Work was done quickly and efficiently. Definitely one of the best install experience I've had. Thank You.
Heated Toilet Seat Installation
Feb 20, 2018 | Duravit 0910100005 Happy D Toilet Cistern ...
After cistern refill outflow into toilet bowl continues to dribble in - and you can see a slight flow into the bowl and every so often we hear the cistern refilling a small amount to compensate.
hi i would suggest your ball valve in the cistern needs ajusting remove the top of the cistern you will see the ajustment screw at the end fo the ball **** arm hope this helps
Nov 15, 2009 | Duravit 0910100005 Happy D Toilet Cistern ...
When cistern fills with water it leaks into the bowl
This is caused by the 'syphon' mechanism sticking, quite often nowadays the 'brilliant' plastic push button/ syphon combo sticks, and most toilets are fitted with an internal overflow, lift the lid on the cistern and check for anything causing an obstruction.
More often than not, it's a tiny bit of scale that causes such a headache, and the fact that nothing is made with any quality nowadays!
If you can't see what's wrong call a plumber, he/she will solve it.
I hope this helps
Steve
Jul 09, 2009 | Duravit 0910100005 Happy D Toilet Cistern ...
Maybe I'm an idiot but I don't know how to get the top off of my
The cistern lid is held down by the chrome assembly (which includes the two buttons that you press to make the toilet flush) sticking up in the middle of the lid. You need to unscrew that (anticlockwise) to be able to lift the lid off, to get to the inlet valve, etc.
If the water is running in very slowly, chances are high that the small screen filter under the inlet valve is partially blocked. Working inside the cistern, you need to unscrew the inlet valve assembly (noting the order in which the various parts come out!), then unscrew the cranked fitting just under that, to get the screen/filter.
Dec 27, 2008 | Duravit 0910100005 Happy D Toilet Cistern ...
Duravit 0910100005 Happy D Toilet Cistern  - White Logo
727 people viewed this question
Top Duravit Home Experts
Craig Butler
Craig Butler
Paul Carew
Lawrence Oravetz
Are you a Duravit Home Expert? Answer questions, earn points and help others
