Question about Fisher and Paykel (IWL12)
MY FISHER AND PAYEL GW 712 WASHING MEACHAINE IS NOT SPINNING AT ALL
I have a Fisher & Paykel GW712 and had same problem and fixed it today the drain pump motor had failed although it worked for 1 full cycle. when I tried to wash a second load the water would not completly clear from the machine I finally replaced the pump and now works correctly the pump is easy to install ensure machine is disconnected from power first
Posted on Mar 28, 2011
How to reset fisher payel washer after new pump installed
If you have fitted a new pump the machine will just work, if it is not then there is an internal fault with the electronic motor controller module.
Apr 26, 2017 | Fisher Washing Machines
Model gw 712. Why are lights 3, 5, 7, and 8 flashing?
Hotpoint, GE, RCA Washer Repair - Does not spin or drain ...
? 6:13
https://www.youtube.com/watch?v=69az-ZA3eSQ
Jul 10, 2013 - Uploaded by ApplianceVideo.com
Hotpoint, GE, RCA Washer Repair - Does not spin or drain - VWSR4150DAWW ... Fisher & Paykel ... my washer won't drainnor spin. what is the problem? .... But in the end, this video helped me fix our washing machine.
How to repair a Fisher Paykel Washing Machine
www.instructables.com/.../How-to-repair-a-Fisher-Paykel-W...
InstructablesHow do I remove the lid on a F&P intuitive eco washing machine to get to the motor panel?? IMadeIt ... It runs until the spin cycle and it drains but won't spin.
Dec 18, 2015 | Fisher and Paykel Washing Machines
Fisher @ Paykel GW 712 washing machine error code 49?
My sister discovered her cold water was turned down,,however a plug or pinch hose could give the same code on fisher/paykel. Check your owners guide for your model.
Jul 27, 2015 | Fisher Washing Machines
My fisher and paykel gw 712 washing machine wont spin at all
Here is a link to UTUBE . Watch the video and search for you problem on here . The people who work on them and the companies sometimes post videos on utube to help the consumers out with problems . Hope this helps ,Grant
https://www.youtube.com/watch?v=YZKqpoVX3t4
Aug 11, 2014 | Washing Machines
I have just owned a Fisher & Paykel washing machine GW 712 7.5kg for less than a year and now its not working apart from 3 lights flashing on and off and a beeping sound
F&P washing machines have a self diagnosis capability. However you have to be able to programme the fault mode and be able to interpret the binery display.
It would be best if you called a tech, because ,although the fault could be a simple one, there is always the chance that a component has failed and caused another to fail as well. (Not uncommon with F&P machines)
If you replace a part it might fail again because of a secondary fault.
An experienced tech will check the machine completely, and replace the part or parts and should warranty the work and parts.
You won't be covered by a warranty if you install the parts yourself..
Probably not what you wanted to hear, but a lot less heartache and stress in the long run...
TIP.. Get quotes for fees, experience and warranty before you commit to a service..
Good luck....Nomess
Sep 09, 2010 | Fisher and Paykel (IWL12)
Have a model GW 712 MW 712 Got a part Motor controller Series 43 but it did not make any difference to the machine - then tried a motor contoller from a new F & P machine series 47 and it worked. The...
Motor controllers and display modules have to be compatible...My best suggestion is that you get any numbers that you can from the part that worked and contact a supplier on mainland oz. Statewide spares, S.A. Be very sure of numbers because you won't get much joy if it's the wrong unit. Good luck...Nomess
May 24, 2010 | Fisher and Paykel Fisher & Paykel Washer
My Fisher & Payel smart load dryer is not
Hi
Thanks for using FixYa. No Heat issue in an electric dryer is usually caused due to three things mainly: Thermal Fuse, Wiring Harness and/or Heating Element. Start with checking the Thermal Fuse which ismounted inside the back cover panel to the exhaust duct and is mounted in white plastic housing. If thats fine then the Heating Element should be checked. Please do revert for further assistance.
Thanks
Rylee
Mar 18, 2010 | Fisher and Paykel Dryers
Wont fill cold water
l have a fisher paykel machine that wont fill properly on cold water only hot please help moder gw 712
Mar 20, 2009 | Washing Machines
Washing Machines Logo
327 people viewed this question
Top Fisher and Paykel Washing Machines Experts
Dan Webster
Dan Webster
Owen Barnes
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
