Question about Garden
I need a hookup nozel from pump to hose - Garden
    Master:
  • 403 Answers
Need more info, what are we dealing with
Posted on Mar 27, 2011
I need to replace the relay that controls the washer pump . I currently only have power to the rear washer pump . No noise from the pump when actuated from the multi-switch. (New multiswitch/Pump/hoses to...
you might want to make sure the rear nozel is free and clear,you can do this with a needle,fine wire or my favorite a gituar string.
also trying the rear with the feed hose dissconected might help elimate a cloged nozel.
Ill check to see if I might find a wiring dia.
Gary
Oct 28, 2013 | 1998 Ford Explorer
My intex salt water system alarm goes off and code 90 is flashing and there is little flow. If I take out the type A filter to the pump that came with my Ultra Frame above ground pool, the flow is...
What you need to do is either clean out the filter cartridge or replace it with a new one. If you have a spray nozel for your hose you can clean the cartridge by adjusting the nozel so it is a small but strong stream. Run the stream up and down on the cartridge until all the area has been covered and then install it in the system. If you still have little flow then you should replace the filter cartridge.
I hope this helps.
Jul 05, 2011 | Intex Automatic Salt Water System for ...
I think my windshield wiper fluid hose/hoses are clogged. The 'motor' for the pump still makes noise, but nothing comes out...
take the outlet hose off at the bonnet just under the nozel that sprays the windscreen and using an airling blow down it it clears and saves you £90 plus vat thats what my bmw dealer wanted to charge me//???
Nov 19, 2010 | 2007 BMW 530xi Sports Wagon
Very low pesure
Make sure that all the air inside the hose is out, sometimes pressure washers have a hard time bleeding out the air. Lastly it could also be your pressure relief inside the valve body of the pump the spring can get bound up and basically stay on relief, like when you let off the trigger it doesnt just blow the line or stall the motor good luck\
Apr 18, 2010 | Karcher 2500 PSI Pressure Washer
I have a k7.91 pressure washer the motor runs but stops or pulses
This sounds like a problem with the pressure sensor which is located on the water inlet side of the pump. This switches the power to the motor when there is sufficient inlet pressure and water flow. This pressure switch can get partially siezed up, and not operate correctly.
You will need to dismatle the unit and identify the pressure switch, dismantle it and lubricate it with silicone grease.
Feb 28, 2010 | Karcher PSI Electric Pressure Washer
Hi, I have a Bosch Dishwasher. Can't see the model number. Recently the spray pressure from the middle and top nozels have reduced. I've taken the nozels of and run the m/c up; seems that the pump...
Either there is corrosion in the water lines or the arms themselves. Calcium and water deposit buildup can reduce pressure. If all these are clean and it is the same, then you likely have a clogged or worn pump
Nov 16, 2009 | Kitchen Ranges
I have a 01 golf 1.8T cant fuel
need to chek filler neck or vent hose
Nov 01, 2009 | 2001 Volkswagen Golf
The power washer is surging cuting in and out when i turn da nozzele to get stronger water pressure?
When I use my machine I hook up the water to the pump, hook up the high pressure line and gun, then turn on the water full and squeeze the triger to make sure all air is out before starting the pressure washer(mine is gasoline powered). Then I install the nozel on the spray gun. If you are having surgeing water pressure Check the hose washer where the water hose hooks to the machine, and be sure the supply hose is not restricted and valve is on full.
If this was helpful please leave Feedback. Thanks, SP
Oct 20, 2009 | Garden
Windshield wiper sprayers
This could be 2 things.
First of all, check for any debris blocking the sprayer holes.
Secondly, open the hood and make sure the hose running from the washer fluid tank is connected to the bottom of the sprayer.
Feb 24, 2009 | 1997 Acura RL
Garden Logo
14 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
Marvin
Marvin
