Question about Amana RFS18MPS Microwave Oven
The switch button is not working.. - Amana RFS18MPS Microwave Oven
  • 2,382 Answers
Hi, kindly unplug the unit for five minutes. this will drain all power, and reset the main board. Once the five minutes have passed, simply plug the unit back into the power outlet. If the problem continues, the touch pad should be replaced asap.
Posted on Mar 27, 2011
Why Kenmore microwave oven (model 80089700) start/enter button not working while all other buttons works fine?
Safety system locking out the start switch. Door not closed, mode and timer not set etc.
Apr 10, 2017 | Kenmore Microwave Ovens
My start button of microwave suddenly stopped working only its stop button works.What can I do?
You could have a defective door switch. Or, a bad membrane switch on the touch pad. Or, the ribbon cable (if so equipped) between the touch pad and circuit board might not be making connections on all of its wires.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/david_29ad5d1dd86564b0
Sep 14, 2016 | Microwave Ovens
Start button an 1/2 buttons on keypad no work in my GE JVM150H microwave. Interior light also stays on.
The door has latch switches that are part of the protection and operation when door is closed, is the new door identical and switches match up {same number} if everything checks and the door switches are all working, the door needs to be checked for alignment, if it's out a small margin the switches will not operate properly.
Mar 13, 2012 | GE Spacemaker JVM1640SJ Microwave Oven
Our sharp r520lw just quit working, timer works, light works, all buttons work, (clear, etc) however turntable doesn't work and no
That would be a bad bottom door switch or its mount.
See the help file on door switches here.
See the service manual here.
Dec 13, 2011 | Sharp R-520LW Microwave Oven
My frigidaire GLMV169 manufactured in 2005 and purchased in 2006 stopped working. There is no power. The clock, buttons - everything. Tried changing the outlet and flipping fuse switch and still...
Hello there:
If your microwave oven doesn't seem to work at all, check these: Fuses Door switch Fuses Usually, when your microwave oven doesn't work it all, the internal fuse (thermal fuse) is blown. This fuse protects both you and the oven. When it blows, you need to have a qualified appliance repair technician replace it. Door switch If the fuse isn't the problem, check the door hooks and the door-release button. When these are broken, the door switch doesn't activate, so the oven can't work.
Nov 19, 2010 | Frigidaire GLMV169 Microwave Oven
Start button does not work
the switch contacts are not making so switch is u/s
Jul 05, 2010 | Panasonic NN-T993SF Microwave Oven
The microwave oven start button does not work. If
You probably have a bad door switch or door switch mount and should see these files:
http://www.microwavedisplay.com/safety.txt
http://www.microwavedisplay.com/disassembly.txt
http://www.microwavedisplay.com/doorsw.txt
If it's not the switch or mount, you may need to adjust the door alignment.
If you still need help, to allow us to help you effectively (at no charge), please post a NEW problem to FixYa, and please include your brand name and the full model number from the tag in or on the unit, and requote your symptoms, as you posted previously.
Dec 06, 2009 | Sharp R-1870 Convection/Microwave Oven
Kenmore over the range microwave 721.67600 will not cook
One of two thing happened here...
1. most likely...One of the interlock switches has malfunctioned. Micro. will NOT opperate unless ALL switches are working properly for safety
2. possible...the start button on the touch pad has failed in the circuit.
Feb 23, 2009 | Kenmore 62702 Microwave Oven
The start button of the keyboard does not work
I would first suspect the door switches. The door must be shut and the switches must be working before the contoller will let the oven start cooking. See my other answers for a text file on door switch testing and replacement. Once they have been checked, if you still have toruble, please reply back.
Dec 10, 2006 | Welbilt MR99T Microwave Oven
Amana RFS18MPS Microwave Oven Logo
70 people viewed this question
Top Amana Microwave Ovens Experts
William Miller
William Miller
foster_mommy
Level 1 Expert
Jim Thurston
Are you an Amana Microwave Oven Expert? Answer questions, earn points and help others
