Question about Brother 1034D Mechanical Sewing Machine
I removed the stitch finger from my Bother 1034D to do a rolled hem. Now I can't get it reinstalled. The looper hits it. How do I get it back in.
snakehead
  • 1074 Answers
SOURCE: stitch and looper problems
CHECK your bobbin it needs to be replace probably it is broken or worn out
Posted on Jun 16, 2007
  • 3 Answers
SOURCE: Where can I find sheap part for 1034D brother serger?
Find a sew & vac shop near your house they usually have sewing machine parts
Posted on Jun 16, 2008
jmgldsmth
  • 2005 Answers
SOURCE: Timing problem on Rex commercial blind stitch
retime your hook with relation to your needle the hook is slightly out of time causing it to "slip the loop" the hook should hold the loop until the needle retracts forming the chain
Posted on Apr 30, 2009
  • 5 Answers
SOURCE: can't re-attach the stitch finger when done
Open the front cover and working table (the door that is on the left side). On the side of the needle plate is a ****. Line your stitch finger up so that its flat side is towards the machine. On the inside of that ****, there's a little bracket to hold the stitch finger secure--it slides into that. Good luck! it took me hours to figure this out the first time! There's a yahoo group for White model sergers---they are excellent resources, too.
Posted on Sep 09, 2009
  • 108 Answers
SOURCE: I lost my manual to my Janome Harmony 9102d and
i was able to find manual at www.ifixmachines.com
Posted on Feb 15, 2010
Setting a elna 792d for rolled hem
I don't know your model in particular but generally this is how you set up a serger/overlocker to create a rolled hem. Remove the left hand needle and thread if 4 threads are threaded). Now there is usually a lever around the stitching area that you slide back towards you to remove the stitching finger back (disengaged). Then you adjust the top looper tension looser (about 2-3) and lower looper tension tighter (7 or 8). Leave needle tension at normal tension (5). You may need to move the cutting blade to the right too. The technique is to cut the fabric wider but with a narrow stitch so the cut edge rolls under within the stitching. You want the top looper thread really loose so it rolls right around underneath up against the needle thread, the lower looper thread needs to be tight and almost invisible, pulling the upper looper thread down. I usually do a few test runs and check the stitching. Once happy, I turn the stitch length right down to 1 so it is very dense. This uses a lot of thread up.
Ideally use a wooly overlock thread on the upper looper as this "fluffs" out once stitched and "fills" in covering the fabric edge completely.
some good images here
Sewing Basics Narrow Rolled Hems with Serger Sew Mama Sew Outstanding...
Jul 18, 2017 | Elna Sewing Machines
How do I adjust tension on a Janome Harmony 9102D
Sounds like you want to do a rolled hem for a handkerchief edge, I do the following to create a rolled hem on my over locker. Take out left needle and cut and remove that thread. Open front cover and slide back lever for the stitch finger in the needle plate, this finger stops the fabric rolling under thread tension normally so you need to pull it back out of engagement. Your Janome may have a similar means to select the rolled hem or you may need to remove the stitch finger with a screwdriver, it varies between models.
Thread upper looper with wooly nylon and right needle and lower looper in matching colour thread. (You can go wooly on the bottom looper but it hardly shows so I never bother.) Disengage upper blade and move the fixed lower blade to the right to trim less, then lower upper blade back into position. Now tension, needle leave alone (5)' upper looper very loose (2-3) and lower looper tighten up to 6-7 and test stitch. You want the upper looper thread to go right underneath and the lower looper thread to disappear against the needle stitch. And the fabric to roll inside the stitching. Finesse tensions on the loopers until this is right, you may need to change blade position too, depends on weight of the fabric and how it rolls. Once this is right turn stitch length down to close up stitching, 0.8 or even 0.5 if you want full coverage. Thats it. You can use differential feed if you want a fluted rolled edge, nice on knits.
Mar 02, 2015 | Janome Harmony 9102D Mechanical Sewing...
Why does fabric get caugh on the roll hem devise when over locking
this sounds like an overlocker/serger machine you are using? if the fabric is catching on the overlocking tongue it could be a number of factors, have you lifted the top cutting blade out of the way and forgot to put it back into place? That would be my first thought, the top and bottom blade move against each other cutting the fabric. Rolled hemming usually requires the blade to be set on about 2, or middle of its setting range, the stitch finger is pulled back out of the stitching area, top looper thread is loosened off and bottom looper thread is tightened up, resulting in the top looper thread wrapping around the edge of the fabric and pulling the cut edge down under within the seam, forming the rolled hem.
May 13, 2014 | Elna Sewing Machines
How do I set up my babylock serger for a rolled hem? What is the tension to be set at?
I don't know your babylock well, some of these have automatic tensions and electronic stitch selection. But a rolled hem is achieved on any overlocker in the following way; the actual dials and knobs might vary a bit.
Firstly there is a stitch finger that you need to change or retract so that the thread can roll the fabric rather than staying flat. For a normal seam this finger sticks out in the area where the loopers and needle form the stitch holding the cut edge flat until the seam is made over it. But for rolled hems you want to retract this finger so it does roll.
On the Bernettes this is a little lever in front of the stitching area that you pull back to retract the finger. Have a look around where the stitch forms and you should see the finger. Some machines, its a part you change on the needle plate with a screw driver, or just move a switch or lever.
You want the right hand needle in place, remove the left hand needle.
Thread upper looper with wooly overlock thread, this is a fluffy nylon that pulls flat under tension but relaxes and "fills" out once its stitched into place. Gives that lovely covered look you see on shop bought tablecloth edges. Your regular thread in needle and lower looper. Usually cutting blade to the right side as you want it to cut more fabric than in the seam so it rolls under. Now loosen off the tension on the top looper, (I use 2 on mine but this is something you need to finesse with each machine), and tighten up the tension on lower looper, (about 7). Leave needle tension alone.
Now test stitch on your fabric, and finess the upper and lower looper tensions until you get the lower looper thread almost not showing, it should be right up against the needle on the underside with the upper looper thread completely wrapping around top and bottom, pulling the fabric under.a seam like this.
Test stitch and adjust upper and lower looper until this is happening.
Now, turn stitch length down to close up the stitching, probably 1 or 0.8 if you want a real satin stitch look to the hem.
Because of the stitch density this uses thread so do the finessing first, then turn the length down.
That's it! Now right down the tension settings you used and keep handy for next time.
Sep 24, 2011 | Baby Lock Eclipse Serger
What setting are the three threads set on for a rolled hem on a singer ultralock l4sh654 and what is the lever by the plate for?
Rolled hemming on any overlocker is usually achived the following way. Right hand needle only.
Blade over to the right usually to cut wider than normal but you can vary this to suit the fabric and stitch width you want.
Thread in this needle and the upper and lower loopers. If you can source any, use woolly overlock thread in the upper looper, this fluffs out when not tensioned and covers the fabric to give the look of solid stitching. Change upper looper tension to about 2 and lower looper tension to about 6 or 7.
The lever by the plate is usually to control the little stitch finger where the stitches are formed, move it backwards and it should move back towards you?? If this happens, then you want it in the retracted (towards you) position for rolled hemming so the stitching is much smaller and the fabric can roll. Normally this stitch finger holds the fabric firm for the loopers to form the stitch over for your normal 3 or 4 thread overlock.
Now test stitch and see how it looks. Tighten the lower looper thread so it lays right beside the needle on the underside. You may need to then tighten or loosen more the upper looper, you want the upper thread to wrap all the way around to the underneath against the lower looper thread and needle.
The cut edge of fabric should roll to underneath inside your seam. Once you've got this happening, turn the stitch length down to 0.5 or so to close it right up tight. This uses heaps of thread so I usually test everything else, then close it up at the end to minimise waste.
Hope this makes sense, good luck.
Sep 22, 2011 | Singer 14SH654
How do I create a rolled hem with this machine. I see the stitch width knob, but do I need to remove one of the threads for this?
Making a rolled hem on any overlocker is achieved in the following way:
use right hand needle only and top and bottom loopers. Turn stitch length down so threads are closed up (on mine this is 0.5). Your stitch length dial will be one on the right hand side near the flywheel usually. Loosen off the the top looper tension and tighten up the bottom looper tension (these are the right and 2nd right tension dials on front of the machine). On my Bernette I leave the needle at the usual 5, 2 on the top looper and 6.5 to 7 on the bottom looper thread. Move cutting blade position to the right so that you are trimming the fabric quite a bit wider than your stitch, this makes the fabric "roll" underneath inside the stitching to form the rolled edge or hem.
There is also another step that needs to happen where you change or remove a little stitch finger that sits in the pressure foot or just under it. On the Bernettes, you flick a lever to move this stitch finger back towards the operator so it is out of the stitch forming area. On some machines, it is a case of changing the little stitch finger which is screwed onto the pressure foot with a screwdriver.
I really don't know with your Necchi which it is but have a good look at the pressure foot, and around the blade cutting area and see if you can see a lever or check out the accessory bag and see if there is another stitch finger in there, it would be smaller than the one on the foot now. In effect, this finger sits out and the threads wrap around it to form your normal overlock but for rolled hem you want a much smaller finger in place to make a very little seam.
The other variable which makes a very neat job is to use a thread called "wooly Overlock" in the upper looper only. This thread when pulled under tension is tight looking but when you let it go, it fluffs out. So when seaming on a rolled hem it fills out the stitching and covers the edge of the fabric fully giving a smooth look. You can do it without but wooly thread makes a great job and you'll see it on all Ready to Wear seams usually for this reason.
If I am going to roll hem a fine sheer woven fabric like organza or chiffon I will change the needle to make sure it is nice and sharp and also ensure it is a regular point, not a ball point (I seam lots of knits so have ball points in most of the time on mine) Usually a size 80 is fine.
I hope this gets you going with your overlocker, I usually test stitch quite a bit with the stitch length at the normal 2.5 setting and adjust the looper tensions until I've got the stitch looking good, then turn it down to the very close 0.5, just to not waste a ton of thread.
Sep 09, 2011 | Necchi 6002 Sewing Machine
I cannot get the tension right? Also, trying rolled hem with 3 needles...tension too loose.
Rolled hem would be one needle and two loopers, is this what you meant?
Make sure you move the blade to right so that you are cutting wider than the stitch being formed, you want the fabric to roll to the underside inside the stitch.
I would set top looper tension to 3 and bottom looper tension to 6 first off (needle at five, normal tension) first off and test serge with the stitch length at normal 2 or so, so you can see if the fabric is rolling under for you. There is proabably a stitch finger in the throat that you need to change too, sometimes its on the foot, (change with a screwdriver) and sometimes just a finger down on the needle plate.
Then adjust the two looper tensions making lower thread nestle up against the needle on the bottom of the stitch, and the top looper thread wrapping right over to bottom as well. Once this is happening, then turn stitch length down to close up the stitches.
It does depend on the weight of fabric too, and if you want to seam curves.
I find its best done with wooly overlock thread on top looper to "fill" in the overlocking appearance and fully cover the fabric.
I hope this is of help, if the tensions just wont behave then one of them might be faulty and machine need a service, I get mine done at least every 2 years to keep timing and tensions right.
May 26, 2011 | New Home 104D Mechanical Sewing Machine
Need settings for Simplicity easyLock SL370 rolled hem. Machine belongs to a friend who recently moved and the instruction manual has gone missing. Thank you!
narrow 3thread seam, so remove left needle. loosen top looper tension to 3 or 2, tighten bottom looper tension to 7 or 8. thread top looper with woolly overlock thread and reduce stitch length. there is also a thread finger u need to flick back on throat or needle plate usually to make rolled hem. also move blade to right to trim less fabric as you want the fabtic to roll under inside the seam.
Apr 28, 2011 | Simplicity SL370 Mechanical Sewing Machine
Which needle do I take out to do a rolled needle
left one, rolled hem is usually a narrow seam so you remove the left needle, change the needle plate or flick a switch that changes the position of the thread finger under the foot and tighten up the looper tensions. You want the top looper thread to go around to underneath and the bottom looper thread to disappear against the needle stitching. You also need to close up the stitching density, by decreasing the stitch length.
Mar 02, 2011 | Baby Lock Eclipse Serger
Rolled hem or rolled edge
You need to disengage the cutting blade by openingfirstly opening the front and left hand side covers. pull on the larger of the two silver knobs and slide the red lever towards you. I'm not sure what the tension settings are, but I'm certain you need to reduce them a fair bit to aid in the rolling effect. I only use 3 threads when doing a rolled hem.
My description isn't too detailed but I hope it helps!
Jun 11, 2008 | Janome MyLock 634D Mechanical Sewing...
Open Questions:
See all Brother 1034D Mechanical Sewing Machine Questions
Brother 1034D Mechanical Sewing Machine Logo
212 people viewed this question
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
