Question about Bionaire Humidifiers
The water from my bionaire humidifier keeps leaking well not leaking pouring out of the humidifier base. I checked and no there is no cracks on the water tank and it does not leak from the tank itself. But when I set it on the base the water pours out the bottom. This humidifier was alot of money and my sinuses are terrivble right, I really need this working in order to sleep. Please help. Thank you
    Sergeant:
    Champion:
  • 247 Answers
Try to check the insulation of your drain pan because of your water came from your unit is cold that create moist on the tank when hit by hot air from sorrounding air apply insulation on the tank.
Posted on Mar 28, 2011
  • Marilyn McMannes
    Marilyn McMannes Apr 18, 2014
    Mine did the same thing after years of use. I checked the water tank w/cap at an angle in a bucket; didn't leak then set the bottom 'pan' filled with water & that didn't leak. Had to throw away the outside main piece
When I turned on my ultrasonic humidiifier it worked for 10 sec, then I observed the water coming through the bottom. When I removed the tank and the bottom full with water. How can I fix this?
Bionaire BWM401 leaking - YouTube
? 0:39
https://www.youtube.com/watch?v=Gy7VKJJeb3o
Jan 20, 2013 - Uploaded by urhorh
My Bionaire BWM401 leaking through the bottom. ... Review ofBionaire Cool Mist Humidifier BCM7932P-CN from Costco HD - Duration: 1:41.
Nov 28, 2015 | Bionaire Humidifiers
Where can I buy replacement water-tank caps for a Bionaire W12? Also, what's the difference between Bionaire W12 and W12-UC?
i just ordered a replacement cap for the w-12 it has a funnel on the end the one i have don't but the man said it will do the same thing. the funnel is for pouring the water in. the website is appliancefactoryparts.com it cost around 28.00 thats including the shipping and handling of 7.99
Nov 15, 2010 | Bionaire W12-UC Humidifier
How can i change the filter in my bionaire model bcm 7207
on that model that you have you need to turn the unit off , take the water tank off, then the base where the fan is should come off. under the main base the filter will be under that. all you do is take the old filter off and put the new filter on. if you have any other questions please let us know.
Feb 26, 2010 | Bionaire BCM7207-U Humidifier
I dropped the tank. Whre can I get a new tank?
you can check any hardware store or if you live in canada you can check with canadian tire.
May 29, 2009 | Bionaire BCM7204-U 3 Gallon Humidifier
Cleaning a Cool Mist BCM6100U Humidifier
usually it calls for one cap full per gallon of water that the unit has. what you do then is that you put the solution in the water then you put the tank back on the base and then you turn the unit on and let the solution run through your unit.
Mar 22, 2009 | Bionaire Cool Mist BCM6100U Humidifier
Water tank broken
Hi, I think you can purchase from amazon. take a look here: Maintain Your Home Environment From Anywhere. I hope this helped you. Have a nice day
Mar 20, 2009 | Bionaire Humidifier BCM657U Humidifier
Bionaire BCM 6000 tower leaking issue
Thank you for the follow up but there was a price at the end for my question so I decided to find out myself. I bought this product which is not the greatest and if on top of that I have to pay for a little information that's a bit far !
Regards,
Michel
Feb 02, 2009 | Bionaire BCM6010RCU 3.5 Gallon Tower...
Gurgling sound
the gurgling noise is the water going into the base. since you haven't used it in so long your going to hear some weird noises at first then they should go away. but before using it make sure that all dust particals and everything is cleaned. if you have any more problems please let us know.
Jan 27, 2009 | Bionaire W9U Humidifier
Bionaire BCM645 Cool Mist Humidifier leaking water
There is probably a crack somewhere in the unit. Not likely, but worth visually inspecting closely.
Try filling it with less water and run it and see what happens.
Mike
Jan 05, 2008 | Humidifiers
Bionaire Bcm630
Same problem — junk.  Will return it to Sears (Costco was out).
Nov 18, 2007 | Bionaire BCM6010 Humidifier
Humidifiers Logo
1,199 people viewed this question
Top Bionaire Humidifiers Experts
Craig Butler
Craig Butler
Oloyede Monsuru
ray gallant
Are you a Bionaire Humidifier Expert? Answer questions, earn points and help others
